Cython 0.29.33-1 :error update
Impossible to update cython 2 : a message " error happends in the build " , " error in the construction cython 2" and all is stopped. ( Error during yay -Syu)
Note : my system is updated regularly - one / week - and I use python 3 ; also cython 2 works as it’s…
Also since 3 months I do not update python2 as I understood it’s no more maintained?
If you have any idea .
Can you share the full output from yay?
here the outlet :
IndexError: list index out of range
File “setup.py”, line 296, in
**setup_args
File “/usr/lib/python2.7/site-packages/setuptools/init.py”, line 162, in setup
return distutils.core.setup(**attrs)
File “/usr/lib/python2.7/distutils/core.py”, line 151, in setup
dist.run_commands()
File “/usr/lib/python2.7/distutils/dist.py”, line 953, in run_commands
self.run_command(cmd)
File “/usr/lib/python2.7/distutils/dist.py”, line 972, in run_command
cmd_obj.run()
File “/usr/lib/python2.7/distutils/command/build.py”, line 127, in run
self.run_command(cmd_name)
File “/usr/lib/python2.7/distutils/cmd.py”, line 326, in run_command
self.distribution.run_command(command)
File “/usr/lib/python2.7/distutils/dist.py”, line 971, in run_command
cmd_obj.ensure_finalized()
File “/usr/lib/python2.7/distutils/cmd.py”, line 109, in ensure_finalized
self.finalize_options()
File “/home/ecr/.cache/yay/cython2/src/cython-0.29.33/Cython/Distutils/build_ext.py”, line 21, in finalize_options
self.distribution.ext_modules, nthreads=nthreads, force=self.force)
File “/home/ecr/.cache/yay/cython2/src/cython-0.29.33/Cython/Build/Dependencies.py”, line 1112, in cythonize
cythonize_one(*args)
File “/home/ecr/.cache/yay/cython2/src/cython-0.29.33/Cython/Build/Dependencies.py”, line 1235, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: /home/ecr/.cache/yay/cython2/src/cython-0.29.33/Cython/Compiler/FlowControl.py
==> ERREUR : Une erreur s’est produite dans build().
Abandon…
→ erreur lors de la construction : cython2
Blockquote
