I created a shortkey to start/ stop a screencast:
ctrl + Print
ffmpeg -y -f x11grab -s 1680x1050 -i :0.0 -f alsa -i default video.mp4
When the screencast is active I would like to have an icon on the polybar. How to create?
ctrl + Print
You’ll need some sort of script that can check whether the command is running or not.
For polybar, you can create a script type module
Thanks you. The concept behind it I can grasp. But that’s too sophisticated for my level. I see, I have to educate me for scripting…
