Hi, I have been using EndeavourOS (dual-booted) with gnome for a couple of months now and just brought another monitor recently which is connected via HDMI.
The problem I’m facing is that whenever I am doing something slightly memory intensive (30% usage), the dual monitor bugs/lags out for a moment. Things to note here are:-
- Just the dual monitor freezes, my laptop monitor keeps working as normal.
- The freeze is only momentary (3-5sec), after which my system logs out and restarts automatically.
- The freeze doesnt occur when i have disabled the dual monitor from settings and while i only work on laptop monitor.
I have tried various fixes which I found online which include:
- Setting up the dedicated graphics as default for all apps
- Disabling all gnome extensions
- Trying both gnome on xorg and wayland
Since none of these work, I’m resorting to asking the pros…
I have also attached the output of inxi -Fxz below:
Kernel: 6.10.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: GNOME v: 46.4 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: HP product: OMEN by HP Laptop 16-c0xxx v: N/A
serial: <superuser required>
Mobo: HP model: 8902 v: 89.62 serial: <superuser required> UEFI: AMI
v: F.22 date: 10/12/2023
Battery:
ID-1: BAT0 charge: 67.1 Wh (100.0%) condition: 67.1/67.1 Wh (100.0%)
volts: 12.7 min: 11.6 model: HP Primary status: full
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 1561 high: 2895 min/max: 400/4463 cores: 1: 2058 2: 400
3: 400 4: 2792 5: 400 6: 400 7: 2315 8: 400 9: 400 10: 400 11: 2315 12: 2314
13: 2895 14: 2885 15: 2309 16: 2306 bogomips: 102213
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: RDNA-2 bus-ID: 03:00.0
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 bus-ID: 08:00.0
temp: 56.0 C
Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
bus-ID: 1-3:4
Display: wayland server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
compositor: gnome-shell driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution:
1: 1920x1080~144Hz 2: 1920x1080~144Hz
API: EGL v: 1.5 drivers: kms_swrast,radeonsi,swrast platforms:
active: gbm,wayland,x11,surfaceless,device inactive: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600M (radeonsi
navi23 LLVM 18.1.8 DRM 3.57 6.10.8-zen1-1-zen)
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 08:00.1
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel bus-ID: 08:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 08:00.6
Device-5: Walmart AB13X Headset Adapter
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-1:2
API: ALSA v: k6.10.8-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.2.3 status: active
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
IF: eno1 state: down mac: <filter>
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel port: e000
bus-ID: 05:00.0
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 1-4:5
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 953.87 GiB used: 64.89 GiB (6.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1006 size: 953.87 GiB temp: 44.9 C
ID-1: / size: 95.56 GiB used: 64.81 GiB (67.8%) fs: ext4 dev: /dev/nvme0n1p8
ID-2: /boot/efi size: 256 MiB used: 83 MiB (32.4%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 63.6 C mobo: N/A
Fan Speeds (rpm): fan-1: 3679 fan-2: 3892
GPU: device: amdgpu temp: 57.0 C device: amdgpu temp: 62.0 C fan: 0
Memory: total: 16 GiB note: est. available: 14.97 GiB used: 2.67 GiB (17.8%)
Processes: 329 Uptime: 3h 51m Init: systemd
Packages: 1048 Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 inxi: 3.3.35
