You shouldn’t have to hard power off at all, read up on REISUB, it is a safer way to gracefully power down when your machine freezes up.
https://wiki.archlinux.org/index.php/Keyboard_Shortcuts#Kernel_(SysRq)
We are talking actual hard freeze here. REISUB doesn’t work if the computer is genuinely frozen.
(Trust me, I tried. Computer 100% unresponsive)
I was reading up on this, this week and haven’t set it up yet. Might come in handy.
Instead of this I would try
amd_iommu=pt
This enables IOMMU for devices used in passthrough and will provide better host performance.
Only if using passthrough, which very few desktop users would.
What uses passthrough?
PCI passthrough allows a virtual machine guest access to and control over a PCI host device.
The most common use of this on a desktop system is allow a graphics card to be accessed directly within a VM. Instead of using a VM being limited to its virtual graphics adapter you could utilize the power of an actual gpu.
IOMMU is required to achieve this, amd_iommu on an AMD system, and it can be fiddly to setup.
https://wiki.archlinux.org/index.php/PCI_passthrough_via_OVMF
I’ll test it on Manjaro unstable and report back.
5.10-vd + nVidia 460.32 works on that box.
I did encounter a hard crash while playing a game, but unsure whether it’s related to the driver/kernel combination as nothing showed up in the logs.
I don’t seem to have any issues with my vmware VMs, but I will try the amd_iommu=pt option suggested by @axt , better safe than sorry.
Thanks a lot for this thread!
I’ve had exactly same problems with Asus ROG Crosshair VII Hero (without WiFi) and kernel-5.13.4.
