# GRUB boot loader configuration
GRUB_DEFAULT='0'
GRUB_TIMEOUT='5'
GRUB_DISTRIBUTOR='EndeavourOS'
GRUB_CMDLINE_LINUX_DEFAULT='nowatchdog nvme_load=YES loglevel=3'
GRUB_CMDLINE_LINUX=""
ibt=off
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY='true'
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_BACKGROUND='/usr/share/endeavouros/splash.png'
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
GRUB_DISABLE_SUBMENU='false'
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
#GRUB_DISABLE_OS_PROBER=false
No you still didnât do it correctly. You need to remove where you put it. I gave you the example of the line where it goes. It goes here in this line as my example shows. Then you save the file and exit nano and then update grub. Can you try again?
GRUB_CMDLINE_LINUX_DEFAULT=ânowatchdog nvme_load=YES loglevel=3â
I applaud your patience sir!
Itâs not a problem really. I donât mind helping someone if they are willing to try and Iâm not waiting and waiting for a response. This is the only way the user is going to learn by doing, doing it wrong, doing it again until they get it right. Then they have learned something and hopefully they gain some confidence.
i think it worked
Show the ouput again
inxi -Ga
Device-2: NVIDIA TU117M [GeForce MX450] vendor: Lenovo driver: nvidia
Can you show all of it? Just edit your post if you like.
i cant post the out put
How come? Are you over your limit of posts? You just copy and paste.
i get this messag an error occurred sorry you cannot post a link host
Just type in the terminal
inxi -Ga
When it shows the output you just copy and past it in the window of your post.
Edit: Maybe you did something that caused the error because thatâs not normal.
Keep in mind you can also take a screen print of the output and post the image after you have saved it.
Not sure whatâs going on but the output should show the driver as nvidia and the driver version number.
I would like to see the output though to confirm.
sorry im looking for screen print
Iâm not sure why you canât post it. Copy and paste the output here. Youâve been doing it all along.
yes just this post
Okay itâs loaded now properly. So a bunch of things to keep in mind. This is a laptop with Hybrid graphics. It is currently running on the Intel graphics. In order to run on the nvidia you have to use a method to switch. But thatâs another issue and only if you really need to run on the nvidia or want to. So you would either have to use optimus-manager or some other way. Right now the driver is loaded and hopefully this stops the overheating issue as the cpu was probably doing some tasks because the driver wasnât loading. I would use it now and see if the overheat problem is not happening now.
better than beffor but
