Copy and pasting
This is weird, but have to repeatedly press ctrl+c before I can paste the correct item.
I use Plasma Wayland, kitty as my terminal, vivaldi as my browser and copyq as for my clipboard (and have used this combo for a long time).
Example (I just copied some of the text above first):
Copy and paste this line, press ctrl+c once.
Paste (ctrl+v):
This is weird, but have to repeatedly press ctrl+c before I can paste the correct item.  I use kitty as my terminal
It pastes the “previous” item.
If I press ctrl+c more than once:
The correct item is pasted.
I have screwed up somewhere, but I have no idea where :frowning:
Does this happen with konsole?
Yes
And with x11?
Not tried, will test tomorrow.
I would temporarily disable copyq and see if it still happens
