Converting to dracut from mkinitcpio
I am converting to dracut from mkinitcpio following this wiki https://discovery.endeavouros.com/installation/dracut/2022/12/
I just change to systemd-boot with kernel-install from grub, so I do
sudo pacman -R mkinitcpio-openswap
and
sudo pacman -S kernel-install-for-dracut
then
sudo reinstall-kernels
But the last command gives me some error
-> bsh > sudo reinstall-kernels
Installing kernel 6.1.37-1-lts
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd 6.1.37-1-lts
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'dmraid' will not be installed, because command 'kpartx' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: i18n ***
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   sha256
dracut: Files:                    788
dracut: Linked:                   3 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 46 files
dracut: Saved:                    356.78 KiB
dracut: Duration:                 0.004208 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Using microcode found in '/boot/intel-ucode.img' ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd' ***
dracut: Using auto-determined compression method 'gzip'
dracut: *** Creating initramfs image file '/efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd' done ***
dracut: Executing: /usr/bin/dracut --no-hostonly --force /efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd-fallback 6.1.37-1-lts
dracut: dracut module 'multipath' will not be installed, because command 'multipath' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: *** Including module: bash ***
dracut: *** Including module: modsign ***
dracut: *** Including module: dbus-daemon ***
dracut: *** Including module: dbus ***
dracut: *** Including module: network-manager ***
dracut: *** Including module: network ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: kernel-network-modules ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: cifs ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: nbd ***
dracut: *** Including module: nfs ***
dracut: *** Including module: resume ***
dracut: *** Including module: virtiofs ***
dracut: Mode:                     real
dracut: Files:                    2543
dracut: Linked:                   10 files
dracut: Compared:                 489 files
dracut: Saved:                    1.42 MiB
dracut: Duration:                 0.014932 seconds
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Creating image file '/efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd-fallback' ***
cp: error writing '/efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd-fallback': No space left on device
dracut: Creation of /efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts/initrd-fallback failed
Installing kernel 6.4.1-arch2-1
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd 6.4.1-arch2-1
dracut: Mode:                     real
dracut: Files:                    800
dracut: Compared:                 45 files
dracut: Duration:                 0.017142 seconds
dracut: *** Creating image file '/efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd' ***
dracut: *** Creating initramfs image file '/efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd' done ***
dracut: Executing: /usr/bin/dracut --no-hostonly --force /efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd-fallback 6.4.1-arch2-1
dracut: Mode:                     real
dracut: Files:                    2564
dracut: Compared:                 470 files
dracut: Duration:                 0.034026 seconds
dracut: *** Creating image file '/efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd-fallback' ***
cp: error writing '/efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd-fallback': No space left on device
dracut: Creation of /efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1/initrd-fallback failed
Whats going wrong there? How can I fix?
System: Intel 11gen + 3080Ti, latest EndeavourOS, more info: http://ix.io/4zTi
Thanks in advance!
EDIT:
seems like efi partition is not large enough (257/300MiB), just wondering would 600MiB in total enough? just have two kernels (stock kernel and lts kernel)
Low on the space it seems…
Clean some disk space and then redo :upside_down_face:
How big is your EFI partition?
Right! didn’t expect my efi partition to be that small… I am resizing it now
300 MiB
And it is already 257MiB used I guess thats the reason? I am resizing it now
Just wondering, could I convert a systemd-boot Arch installation to dracut using kernel-install-for-dracut from the AUR or will I run into trouble?
You absolutely can but it will also convert you to kernel-install as well.
If you want to keep your current systemd-boot setup use dracut-hook and dracut instead.
After increased to 600MiB from 300MiB I still got the same error, so I have to increase the second time, this time I increase to 1GiB, and now it installs without errors
And it turns out to be 604M used …
Just to be safe, the fact that there is no /efi directory only /boot in Arch is not an issue.
It will work either way but it would make more sense to move the mountpoint to /efi.
You either have a lot of kernels or you are using nvidia drivers.
so…:
sudo rm -r /boot/efi  /boot/initramfs* /boot/vmlinuz*
Now we remount the EFI partition to /efi.
sudo mkdir /efi
efidevice=$(findmnt /boot/efi -no SOURCE) # save the efi partition location
sudo umount /boot/efi
sudo mount ${efidevice} /efi
# To make the mount change permanent, edit `/etc/fstab`
like that?
You are right! I use Nvidia cards :rofl:
This is huge. How many kernels do you have installed? I have 4 kernels installed and my /boot resp. efi partition uses only 134 MB.
Filesystem     Type  Size  Used Avail Use% Mounted on
/dev/nvme0n1p1 vfat  511M  134M  378M  27% /boot
Out of curiosity, can you share the output of ls -lR /efi ?
The nvidia drivers add a huge amount per initrd. Like 60-100MB per image. So if you are generating fallback initrds, it could be an extra 150MB or more per kernel just for the drivers.
actually one two kernels, stock one and the lts one, here is the out put for ls -lR /efi
-> bsh > ls -lR /efi
/efi:
total 12
drwxr-xr-x 4 root root 4096 Jul  6 14:45 2564d956daa649c6bfd89178923d12f1
drwxr-xr-x 5 root root 4096 Jul  6 14:34 EFI
drwxr-xr-x 3 root root 4096 Jul  6 17:36 loader
/efi/2564d956daa649c6bfd89178923d12f1:
total 8
drwxr-xr-x 2 root root 4096 Jul  6 17:17 6.1.37-1-lts
drwxr-xr-x 2 root root 4096 Jul  6 17:18 6.4.1-arch2-1
/efi/2564d956daa649c6bfd89178923d12f1/6.1.37-1-lts:
total 306056
-rwxr-xr-x 1 root root 114589124 Jul  6 17:17 initrd
-rwxr-xr-x 1 root root 180282786 Jul  6 17:17 initrd-fallback
-rwxr-xr-x 1 root root   7315456 Jul  6 14:45 intel-ucode.img
-rwxr-xr-x 1 root root  11209248 Jul  6 17:17 linux
/efi/2564d956daa649c6bfd89178923d12f1/6.4.1-arch2-1:
total 311720
-rwxr-xr-x 1 root root 115532965 Jul  6 17:18 initrd
-rwxr-xr-x 1 root root 183689852 Jul  6 17:18 initrd-fallback
-rwxr-xr-x 1 root root  12656128 Jul  6 17:18 linux
/efi/EFI:
total 12
drwxr-xr-x 2 root root 4096 Jul  6 14:34 BOOT
drwxr-xr-x 2 root root 4096 Jul  6 14:34 Linux
drwxr-xr-x 2 root root 4096 Jul  6 14:34 systemd
/efi/EFI/BOOT:
total 92
-rwxr-xr-x 1 root root 92160 Jun 19 22:41 BOOTX64.EFI
/efi/EFI/Linux:
total 0
/efi/EFI/systemd:
total 92
-rwxr-xr-x 1 root root 92160 Jun 19 22:41 systemd-bootx64.efi
/efi/loader:
total 16
drwxr-xr-x 2 root root 4096 Jul  6 14:45 entries
-rwxr-xr-x 1 root root    6 Jul  6 14:34 entries.srel
-rwxr-xr-x 1 root root   86 Jul  6 17:35 loader.conf
-rwxr-xr-x 1 root root   32 Jul  6 17:36 random-seed
/efi/loader/entries:
total 16
-rwxr-xr-x 1 root root 478 Jul  6 17:17 2564d956daa649c6bfd89178923d12f1-6.1.37-1-lts.conf
-rwxr-xr-x 1 root root 505 Jul  6 17:17 2564d956daa649c6bfd89178923d12f1-6.1.37-1-lts-fallback.conf
-rwxr-xr-x 1 root root 482 Jul  6 17:18 2564d956daa649c6bfd89178923d12f1-6.4.1-arch2-1.conf
-rwxr-xr-x 1 root root 509 Jul  6 17:18 2564d956daa649c6bfd89178923d12f1-6.4.1-arch2-1-fallback.conf
and the size
-> bsh > du -sh /efi/
604M    /efi/
ok. Now I get it. The nvidia modules are blowing up you initrd’s. If you want to reduce the size you could only remove the fallback kernels.You have 2 kernels installed. With fallback initrds this is actually 4 kernels. From my point of view there is no need to have more than 2 kernel for safety reasons.
You could set NO_DRACUT_FALLBACK="true" in `/etc/kernel-install-for-dracut.conf.
