So I like to use micro clip MP3 players and just dump my favorite songs from multiple artists in each genre folder.
For example Smooth Jazz, Rock, and Country. After I have gone through all the songs I like from all the bands in each genre (Jazz, Rock, Country). I load them all in there separate genre folder and use FLAC2MP3 script to convert them to MP3. I don’t load MP3’s in folders in hierarchy structures like Artist - Album - Song on my device.
There is a AUR script called flac2mp3 for just that purpose but I don’t use it.
I know THIS (FLAC2MP3) script and have used it extensively just recently and it works great.
HOW TO GET IT:
Just open terminal and while in home dir
$touch FLAC2MP3
$nano FLAC2MP3
and then copy and paste the script below to nano and edit the settings to your preferences concerning encoding parameters. (Have a read through the script)
With the size of MP3 players now usually 16GB it’s fine to leave on the default settings. Of course original flac sounds best but (-V 0 --vbr-new ) is pretty close and is nearly half the size of flac files.
When your finished save and close nano with Ctrl+x choose y and enter.
Give it permission with this command
$chmod +x FLAC2MP3
then mv FLAC2MP3 to your path either /usr/bin or /bin
$sudo mv FLAC2MP3 /usr/bin or /bin
I think this command refreshes the terminal to allow you to use tab completion but I guess it can’t hurt.
$source .bashrc
USING SCRIPT:
So Iike I said I just dump all my favroite song from multiple Smooth Jazz artists into a SMOOTH_JAZZ folder then just use the command to encode all the flac files.
$FLAC2MP3 /home/user/Music/SMOOTH_JAZZ/*.flac
Then just delete all the flac files with
$rm /home/user/Music/SMOOTH_JAZZ/*.flac
Thats it enjoy!
Got a better way of doing this.
Lets hear about it!
#!/bin/bash
# Flac to Mp3 Conversion Software #
# Script Created by Nick Sklavenitis #
# Date: September 18 2007 #
#The script listed below takes arguments in the following fashion. #
# either you can specify a single file name to convert or you #
# can specify a wildcard as example 2 shows. #
#Example 1: Flac2Mp3 01-The Black Parade.flac #
#Example 2: Flac2Mp3 *.flac #
## To use this script just copy and paste the section below and to a filename Flac2Mp3 and the chmod+x Flac2Mp3
# modify the lame options to your preference example change -b 320 to -b 128 or -b 192 or -b 256
# ******* VBR OPTIONS *****
# Switch Preset Target Kbit/s Bitrate range kbit/s
# -V 0 --vbr-new 245 220...260
# -V 0 preset extreme 245 220...260
# -V 1 --vbr-new 225 200...250
# -V 1 225 200...250
# -V 2 --vbr-new presetstandard 190 170...210
# -V 2 190 170...210
# -V 3 --vbr-new 175 155...195
# -V 3 175 155...195
# -V 4 --vbr-new fastmedium 165 145...185
# -V 4 preset medium 165 145...185
# -V 5 --vbr-new 130 110...150
# -V 5 130 110...150
# -V 6 --vbr-new 115 95...135
# -V 6 115 95...135
# -V 7 --vbr-new 100 80...120
# -V 7 100 80...120
# -V 8 --vbr-new 85 65...105
# -V 8 85 65...105
# -V 9 --vbr-new 65 45...85
# -V 9 65 45...85
# ***** CBR OPTIONS *******
# -b 32, 40, 48, 64, 80, 96, 112, 128, 160, 192, 224, 256, or 320 320 CBR
## My Preferences
# Vocal: -V 9 --vbr-new
# Music: -V 0 --vbr-new
#lame_opts=" -V 8 --vbr-new" ##Vocal
lame_opts=" -V 0 --vbr-new" ##Music
# Creates the loop that allows more than 1 file to be specified, Can use single file name or example *.flac
for x in "${@}"
do
FLAC=${x}
MP3=`basename "${FLAC%.flac}.mp3"`
[ -r "$FLAC" ] || { echo can not read file \"$FLAC\" >&1 ; exit 1 ; } ;
#This section pulls the Tag info from flac and stores it as a variable.
TITLE="`metaflac --show-tag=TITLE "$FLAC" | awk -F = '{ printf($2) }'`"
ALBUM="`metaflac --show-tag=ALBUM "$FLAC" | awk -F = '{ printf($2) }'`"
ARTIST="`metaflac --show-tag=ARTIST "$FLAC" | awk -F = '{ printf($2) }'`"
TRACKNUMBER="`metaflac --show-tag=TRACKNUMBER "$FLAC" | awk -F = '{ printf($2) }'`"
GENRE="`metaflac --show-tag=GENRE "$FLAC" | awk -F = '{ printf($2) }'`"
COMMENT="`metaflac --show-tag=COMMENT "$FLAC" | awk -F = '{ printf($2) }'`"
DATE="`metaflac --show-tag=DATE "$FLAC" | awk -F = '{ printf($2) }'`"
#This section handles the conversion of the Flac file to MP3
flac -dc "$FLAC" | lame${lame_opts} \
--tt "$TITLE" \
--tn "$TRACKNUMBER" \
--tg "$GENRE" \
--ty "$DATE" \
--ta "$ARTIST" \
--tl "$ALBUM" \
--add-id3v2 \
- "$MP3"
done
