Consistent crash during system upgrade
I’ve been dealing with a recurring crash when updating pacman dependencies for the past couple months. I haven’t been able to sort it out myself and I’d love to get some help.
When does it happen?
  • During a system upgrade (pacman -Syu), after packages are downloaded and installed. As far as I can tell, it happens while hooks are running.
  • If I remember correctly, the first time it happened was near the beginning of November 2023. The computer is a desktop that I built and had been running with EndeavourOS for almost a year without issues until this came up.
What happens?
  • Monitors go black and they switch to low power mode because they’re no longer receiving a signal.
  • Lights on my mouse and keyboard (numlock) turn off.
  • Computer stays on, fan still runs, power light stays on, but nothing further changes, even if I wait a while.
  • Pressing-and-holding the power button doesn’t turn off computer as it usually would. I have to turn it off from the power supply switch.
After forced shutoff and reboot:
  • Often, this borks the bootloader, so I have to install my OS from scratch again. The first time it happened, I booted into the live USB environment and mounted the disk in order to backup my home directory. That worked without issues, but I wasn’t able to repair the pacman db/packages. Trying to chroot failed, seemingly for lots of reasons, including the fact that bash was corrupted, so I couldn’t get a shell to run any recovery commands.
  • Sometimes, the boot loader isn’t broken, so I can boot up fine, but many of the packages that were being installed or updated were broken. I’ve been able to fix individual packages by installing one or two at a time and passing --overwrite=*, but I haven’t tried reinstalling all packages at once with that flag, as that would be the equivalent of the upgrade process that consistently crashes and potentially breaks by boot.
  • When I first do a fresh distro installation, I can run pacman -Syu without issues, so I suspect that there’s some package I’m installing later that causes this issue (or some way that pacman is interacting with it).
    • One time, I manually sorted through the non-default packages I’d been installing to pair it down to ones I was sure I wanted (and let pacman sort out their dependencies). Installing that paired-down list worked, so I thought I had solved the issue at that point. But the folowing week I ran pacman -Syu again and got the same issues, which again broke the boot process and required me to install from scratch again.
Observations:
  • I ran a memory test with Memtest86+. A full run found no issues.
  • The blank screen+peripherals issue only happens when installing packages with pacman, not during normal computer usage.
  • The issue does not happen when updating the default-installed packages initially.
  • The issue happened when installing the non-default packages I use (recovered the first time the issue happened, queried from pacman).
  • The issue did not happen when I installed a manually pared-down list of packages (pared down from pacman -Qqen, the 2nd or 3rd time I reinstalled the OS while dealing with this).
  • …but it did happen again when running packman -Syu after installing that pared down list (and after a week went by, so that there were updates to install).
  • My best guess is that there’s an issue with some package I’m installing and/or how pacman interacts with that package that’s causing this. Maybe a dependency of one of my pared-down list packages? What’s confusing is that I went a year without any problems like this and I haven’t been able to find mentions of other people running into the same problem recently.
Hardware/Software details:
  • List of parts: https://pcpartpicker.com/list/XdmNDq
  • EndeavourOS with XFCE desktop environment
  • Full disk encryption using the installer’s default settings
  • No swap (I have 128GB of RAM and an SSD)
  • Plugged into a UPS (Uninterruptible Power Supply)
Full list of packages
Output from pacman -Qqen
accounts-qml-module
alembic
appmenu-gtk-module
aribb24
aws-cli-v2
babl
bcprov
blas
blender
blosc
blueberry
bluez-tools
boost-libs
box2d
bridge-utils
capstone
c-ares
cblas
cfitsio
chromium
clang15
clucene
cmake
coin-or-asl
coin-or-cbc
coin-or-cgl
coin-or-clp
coin-or-coinutils
coin-or-data-sample
coin-or-mp
coin-or-osi
compiler-rt15
containerd
cppdap
cups
cups-filters
cups-pdf
cython
deno
discord
discount
djvulibre
docker
draco
dtc
edk2-ovmf
electron
electron25
embree
espeak-ng
exiv2
ffmpeg4.4
foomatic-db
foomatic-db-engine
foomatic-db-gutenprint-ppds
foomatic-db-nonfree
foomatic-db-nonfree-ppds
foomatic-db-ppds
fsarchiver
gegl
ghostscript
gimp
github-cli
glew
glpk
glslang
gnome-bluetooth
gnu-netcat
gnustep-base
grub
gsfonts
gsl
gtk2
gutenprint
gvim
handbrake
hdf5
hdparm
hplip
htop
hunspell
ijs
iniparser
intel-oneapi-common
intel-oneapi-compiler-dpcpp-cpp-runtime-libs
intel-oneapi-compiler-shared-runtime-libs
intel-oneapi-tbb
jasper
java-commons-lang
java-runtime-common
jbig2dec
jre-openjdk-headless
jsoncpp
kaccounts-integration
kactivities5
karchive5
kauth5
kbookmarks5
kcmutils5
kcodecs5
kcompletion5
kconfig5
kconfigwidgets5
kcoreaddons5
kcrash5
kdbusaddons5
kdeclarative5
kded5
kglobalaccel5
kguiaddons5
ki18n5
kiconthemes5
kio5
kirigami2
kitemmodels5
kitemviews5
kjobwidgets5
kjs
knotifications5
kpackage5
kparts5
kpty5
krita
kservice5
ktextwidgets5
kwallet5
kwidgetsaddons5
kwindowsystem5
kxmlgui5
lapack
lensfun
level-zero-loader
libabw
libaccounts-glib
libaccounts-qt
libaec
libatomic_ops
libcacard
libcdr
libcgif
libcupsfilters
libdbusmenu-qt5
libdovi
libdvbpsi
libebml
libe-book
libebur128
libepubgen
libetonyek
libexttextcat
libfreehand
libgexiv2
libharu
libidn
libieee1284
libimagequant
libixion
libkdcraw
libkexiv2
liblangtag
libmad
libmatroska
libmng
libmspub
libmwaw
libmypaint
libmythes
libnet
libnumbertext
libodfgen
liborcus
libpagemaker
libpaper
libplacebo
libppd
libqxp
libraw
libreoffice-fresh
librevenge
libslirp
libsonic
libspectre
libspiro
libspnav
libstaroffice
libtar
libtommath
libtraceevent
libtracefs
libunibreak
libupnp
liburing
libvips
libvisio
libwmf
libwpd
libwpg
libwps
libxaw
libzmf
llvm15-libs
log4cplus
lpsolve
luajit
luit
media-player-info
minizip
minizip-ng
mlt
multipath-tools
mypaint-brushes1
ndctl
net-snmp
nmap
numactl
obsidian
okular
onetbb
opencollada
opencolorio
openimagedenoise
openimageio
openpgl
openshadinglanguage
openssl-1.1
opensubdiv
openvdb
openxr
os-prober
pass
pcaudiolib
pdftk
perl-alien-build
perl-alien-libxml2
perl-capture-tiny
perl-dbi
perl-ffi-checklib
perl-file-chdir
perl-file-which
perl-path-tiny
perl-xml-libxml
perl-xml-namespacesupport
perl-xml-sax
perl-xml-sax-base
phonon-qt5
phonon-qt5-gstreamer
plotutils
polkit-qt5
poppler-data
poppler-qt5
potrace
pstoedit
ptex
pugixml
purpose5
puzzles
pv
pybind11
pystring
python-annotated-types
python-arrow
python-attrs
python-autocommand
python-awscrt
python-aws-sam-translator
python-boto3
python-botocore
python-build
python-certifi
python-cffi
python-cfn-lint
python-charset-normalizer
python-contourpy
python-cryptography
python-cycler
python-dateutil
python-distro
python-docutils
python-fastjsonschema
python-fonttools
python-gitdb
python-gitpython
python-gmpy2
python-gpgme
python-idna
python-importlib-metadata
python-inflect
python-jaraco.context
python-jaraco.functools
python-jaraco.text
python-jmespath
python-jschema-to-python
python-jsonpatch
python-jsonpickle
python-jsonpointer
python-jsonschema
python-jsonschema-specifications
python-junit-xml
python-kiwisolver
python-markdown-it-py
python-matplotlib
python-mdurl
python-more-itertools
python-mpmath
python-networkx
python-numpy
python-ordered-set
python-pandas
python-pbr
python-pillow
python-pip
python-platformdirs
python-ply
python-pooch
python-prompt_toolkit
python-pycparser
python-pycups
python-pycurl
python-pydantic
python-pydantic-core
python-pygments
python-pyopenssl
python-pyparsing
python-pyproject-hooks
python-pyrsistent
python-pysocks
python-pytz
python-referencing
python-regex
python-reportlab
python-requests
python-rich
python-rpds-py
python-ruamel-yaml
python-ruamel.yaml.clib
python-s3transfer
python-sarif-om
python-scipy
python-setproctitle
python-setuptools
python-six
python-smmap
python-sympy
python-tomli
python-tomlkit
python-trove-classifiers
python-typing_extensions
python-tzlocal
python-uc-micro-py
python-urllib3
python-validate-pyproject
python-wcwidth
python-websocket-client
python-wheel
python-zipp
qca-qt5
qemu-audio-alsa
qemu-audio-dbus
qemu-audio-jack
qemu-audio-oss
qemu-audio-pa
qemu-audio-pipewire
qemu-audio-sdl
qemu-audio-spice
qemu-base
qemu-block-curl
qemu-block-dmg
qemu-block-nfs
qemu-block-ssh
qemu-chardev-spice
qemu-common
qemu-desktop
qemu-hw-display-qxl
qemu-hw-display-virtio-gpu
qemu-hw-display-virtio-gpu-gl
qemu-hw-display-virtio-gpu-pci
qemu-hw-display-virtio-gpu-pci-gl
qemu-hw-display-virtio-vga
qemu-hw-display-virtio-vga-gl
qemu-hw-s390x-virtio-gpu-ccw
qemu-hw-usb-host
qemu-hw-usb-redirect
qemu-hw-usb-smartcard
qemu-img
qemu-pr-helper
qemu-system-x86
qemu-system-x86-firmware
qemu-tools
qemu-ui-curses
qemu-ui-dbus
qemu-ui-egl-headless
qemu-ui-gtk
qemu-ui-opengl
qemu-ui-sdl
qemu-ui-spice-app
qemu-ui-spice-core
qemu-vhost-user-gpu
qhull
qpdf
qt5-declarative
qt5-graphicaleffects
qt5-location
qt5-multimedia
qt5-quickcontrols
qt5-quickcontrols2
qt5-speech
qt5-svg
qt5-tools
qt5-wayland
qt5-webchannel
qt5-webengine
qt5-x11extras
quazip-qt5
rasqal
re2
redland
rhash
runc
rustup
sane
sdl2_image
seabios
shaderc
signond
signon-kwallet-extension
signon-plugin-oauth2
signon-ui
snappy
solid5
sonnet5
spice
spice-protocol
spirv-tools
splix
sshfs
suitesparse
syncthing
system-config-printer
threadweaver5
tinyxml
tmux
tor
torbrowser-launcher
tree
unarchiver
usbredir
vde2
vim-runtime
virglrenderer
virtiofsd
vlc
webp-pixbuf-loader
wireless_tools
wolfssl
xbitmaps
xclip
xdotool
xsane
xterm
yaml-cpp
zopfli
Manually filtered list of packages
This list installed successfully after a fresh OS install, but then pacman -Syu crashed a week later. Maybe the issue could be from a dependency of one of these?
aws-cli-v2
blender
chromium
containerd
cups
cups-filters
cups-pdf
deno
discord
docker
ffmpeg
ghostscript
gimp
github-cli
gnu-netcat
gutenprint
gvim
handbrake
hplip
htop
hunspell
krita
libcupsfilters
libimagequant
libreoffice-fresh
libvips
nmap
obsidian
okular
pass
pdftk
phonon-qt5
puzzles
qemu-desktop
qemu-tools
qpdf
rustup
sshfs
syncthing
tmux
torbrowser-launcher
tree
vlc
xclip
xdotool
xsane
zopfli
Any ideas on how to identify the issue or solve it? Any more info I should provide?
When it happens, I would check the pacman log and see what the last thing that happened was.
Also, you don’t need to reinstall in that situation. You can chroot in and run sudo reinstall-kernels or sudo dracut-rebuild for systemd-boot and grub respectively.
Thanks, I’ll check the pacman log next time!
As I mentioned, I wasn’t able to chroot because the system’s bash was broken, so I couldn’t get a shell with chroot in order to run those commands. Maybe I’m misunderstanding though, as that was the first time I had attempted a chroot. If I’m able to get it to work next time, I’ll definitely try running those instead!
Still working on it, but here’s an update: I just ran pacman -Syu --overwrite='*' (I needed overwrite, since I still have a bunch of broken packages from the last time, and the update wouldn’t be run without it). The command succeeded without a crash for the first time since this issue first happened!
I’m still in the middle of cleaning things up, so don’t necessarily need more help yet, but I wanted to post some relevant pacman output to keep a record of it. Of course, I welcome input if anything catches your eye as something I missed.
  1. There were several lines of output of the form: warning: /path/to/file installed as /path/to/file.pacnew. In all cases, the file with the .pacnew suffix was populated and the other file was 0 bytes. For each of them, I ran sudo mv {file.pacnew} {file}.
    • /etc/qemu/bridge.conf
    • /etc/sasl2/qemu.conf
    • /etc/vimrc
  2. There were a ton of lines of the form: ldconfig: File /usr/lib/{some-file} is empty, not checked. I don’t yet know if this is something I need to clean up somehow.
All those ldconfig lines
ldconfig: File /usr/lib/libOpenColorIO.so.2.2 is empty, not checked.
ldconfig: File /usr/lib/librbio.so.4 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTemplates2.so.5 is empty, not checked.
ldconfig: File /usr/lib/libbox2d.so.2.4.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5Svg.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/librevenge-0.0.so.0.0.5 is empty, not checked.
ldconfig: File /usr/lib/libpagemaker-0.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmatroska.so.7 is empty, not checked.
ldconfig: File /usr/lib/libKF5Crash.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpcolor-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgraphblas.so is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools-opt.so is empty, not checked.
ldconfig: File /usr/lib/libOpenImageIO.so.2.4 is empty, not checked.
ldconfig: File /usr/lib/libabw-0.1.so is empty, not checked.
ldconfig: File /usr/lib/libimagequant.so is empty, not checked.
ldconfig: File /usr/lib/libtbb.so.12.10 is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libpoppler-qt5.so.1.33.0 is empty, not checked.
ldconfig: File /usr/lib/libavutil.so.56 is empty, not checked.
ldconfig: File /usr/lib/liblensfun.so.1 is empty, not checked.
ldconfig: File /usr/lib/libze_validation_layer.so is empty, not checked.
ldconfig: File /usr/lib/libKF5ConfigQml.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so.5 is empty, not checked.
ldconfig: File /usr/lib/libcfitsio.so.10 is empty, not checked.
ldconfig: File /usr/lib/libmng.so is empty, not checked.
ldconfig: File /usr/lib/libusbredirhost.so.1 is empty, not checked.
ldconfig: File /usr/lib/libamd.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/libspex.so is empty, not checked.
ldconfig: File /usr/lib/libqca-qt5.so is empty, not checked.
ldconfig: File /usr/lib/libgexiv2.so is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc.so.2.10 is empty, not checked.
ldconfig: File /usr/lib/libhpdf.so is empty, not checked.
ldconfig: File /usr/lib/libvdeplug.so.3.0.1 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins.so is empty, not checked.
ldconfig: File /usr/lib/libmwaw-0.3.so.3.0.22 is empty, not checked.
ldconfig: File /usr/lib/librasqal.so.3 is empty, not checked.
ldconfig: File /usr/lib/libzopflipng.so is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools.so is empty, not checked.
ldconfig: File /usr/lib/libgimpconfig-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libjbig2dec.so.0 is empty, not checked.
ldconfig: File /usr/lib/libOpenColorIO.so.2.2.1 is empty, not checked.
ldconfig: File /usr/lib/liblpsolve55.so is empty, not checked.
ldconfig: File /usr/lib/libgimpui-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5hl_fortran.so is empty, not checked.
ldconfig: File /usr/lib/librasqal.so is empty, not checked.
ldconfig: File /usr/lib/libtbbbind_2_5.so.3.10 is empty, not checked.
ldconfig: File /usr/lib/libhunspell-1.7.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libwolfssl.so.41.0.0 is empty, not checked.
ldconfig: File /usr/lib/libhunspell-1.7.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so.5 is empty, not checked.
ldconfig: File /usr/lib/libwmf.so is empty, not checked.
ldconfig: File /usr/lib/libklu_cholmod.so.2.2.2 is empty, not checked.
ldconfig: File /usr/lib/libmng.so.2.0.2 is empty, not checked.
ldconfig: File /usr/lib/libepubgen-0.1.so.1.0.1 is empty, not checked.
ldconfig: File /usr/lib/libimagequant.so.0.0 is empty, not checked.
ldconfig: File /usr/lib/libaribb24.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libvdesnmp.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnet.so.9 is empty, not checked.
ldconfig: File /usr/lib/libQt5Multimedia.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libosdCPU.so.3.5.0 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpmibs.so.40.1.0 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl_fortran.so is empty, not checked.
ldconfig: File /usr/lib/libwmflite-0.2.so.7.0.6 is empty, not checked.
ldconfig: File /usr/lib/libhunspell.so is empty, not checked.
ldconfig: File /usr/lib/libgsl.so is empty, not checked.
ldconfig: File /usr/lib/libcgif.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Multimedia.so.5 is empty, not checked.
ldconfig: File /usr/lib/liblog4cplus.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so is empty, not checked.
ldconfig: File /usr/lib/libcholmod.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WebEngineCore.so.5.15.15 is empty, not checked.
ldconfig: File /usr/lib/libcares.so.2.9.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libAlembic.so.1.8 is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so is empty, not checked.
ldconfig: File /usr/lib/libwpd-0.10.so is empty, not checked.
ldconfig: File /usr/lib/libReviewboardHelpers.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5Svg.so is empty, not checked.
ldconfig: File /usr/lib/libwmf-0.2.so.7 is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so is empty, not checked.
ldconfig: File /usr/lib/libetonyek-0.1.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so is empty, not checked.
ldconfig: File /usr/lib/libclucene-shared.so is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins.so.1 is empty, not checked.
ldconfig: File /usr/lib/libpyside2.cpython-311-x86_64-linux-gnu.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libsignon-extension.so.1.0 is empty, not checked.
ldconfig: File /usr/lib/libcapstone.so is empty, not checked.
ldconfig: File /usr/lib/libdvbpsi.so.10 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaGstTools.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/liblensfun.so is empty, not checked.
ldconfig: File /usr/lib/libgimpmath-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libQt5TextToSpeech.so.5 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-gui-1.so is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaQuick.so.5 is empty, not checked.
ldconfig: File /usr/lib/libcolamd.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/liborcus-mso-0.18.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so is empty, not checked.
ldconfig: File /usr/lib/libopenpgl.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsuitesparseconfig.so.7.3.1 is empty, not checked.
ldconfig: File /usr/lib/libmad.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5Archive.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libieee1284.so is empty, not checked.
ldconfig: File /usr/lib/libgegl-0.4.so.0.445.1 is empty, not checked.
ldconfig: File /usr/lib/libtinyxml.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgraphblas.so.8 is empty, not checked.
ldconfig: File /usr/lib/libmarkdown.so.3 is empty, not checked.
ldconfig: File /usr/lib/librevenge-stream-0.0.so is empty, not checked.
ldconfig: File /usr/lib/libsnmp.so.40.1.0 is empty, not checked.
ldconfig: File /usr/lib/libopenvdb.so.11.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libclang.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Bookmarks.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgutenprintui2.so.2.5.0 is empty, not checked.
ldconfig: File /usr/lib/libppd.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libgimpthumb-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtinyxml.so.0.2.6.2 is empty, not checked.
ldconfig: File /usr/lib/libwps-0.4.so.4.0.14 is empty, not checked.
ldconfig: File /usr/lib/libavformat.so.58 is empty, not checked.
ldconfig: File /usr/lib/libzopfli.so is empty, not checked.
ldconfig: File /usr/lib/libsignon-qt5.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5_fortran.so.310.2.0 is empty, not checked.
ldconfig: File /usr/lib/libcfitsio.so.10.4.3.1 is empty, not checked.
ldconfig: File /usr/lib/libgexiv2.so.2.14.2 is empty, not checked.
ldconfig: File /usr/lib/libze_tracing_layer.so is empty, not checked.
ldconfig: File /usr/lib/libKF5GuiAddons.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libfreehand-0.1.so is empty, not checked.
ldconfig: File /usr/lib/libklu.so is empty, not checked.
ldconfig: File /usr/lib/libgimpbase-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5ItemViews.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libsuitesparseconfig.so.7 is empty, not checked.
ldconfig: File /usr/lib/libvdemgmt.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libccolamd.so is empty, not checked.
ldconfig: File /usr/lib/libbabl-0.1.so is empty, not checked.
ldconfig: File /usr/lib/libpagemaker-0.0.so.0.0.4 is empty, not checked.
ldconfig: File /usr/lib/libgsl.so.27 is empty, not checked.
ldconfig: File /usr/lib/libre2.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5_java.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libQt5Multimedia.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so.5 is empty, not checked.
ldconfig: File /usr/lib/libwps-0.4.so.4 is empty, not checked.
ldconfig: File /usr/lib/libclucene-shared.so.2.3.3.4 is empty, not checked.
ldconfig: File /usr/lib/libvips.so.42.17.0 is empty, not checked.
ldconfig: File /usr/lib/libavdevice.so.58.13.100 is empty, not checked.
ldconfig: File /usr/lib/libvdesnmp.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libexttextcat-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libkaccounts.so.23.08.3 is empty, not checked.
ldconfig: File /usr/lib/libKF5ConfigGui.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libatomic_ops_gpl.so.1 is empty, not checked.
ldconfig: File /usr/lib/libpyside6qml.abi3.so.6.6.0 is empty, not checked.
ldconfig: File /usr/lib/libshiboken6.abi3.so.6.6.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5Svg.so.5 is empty, not checked.
ldconfig: File /usr/lib/libamd.so.3 is empty, not checked.
ldconfig: File /usr/lib/libixion-0.18.so is empty, not checked.
ldconfig: File /usr/lib/libaribb24.so is empty, not checked.
ldconfig: File /usr/lib/libixion-0.18.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libbox2d.so is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaGstTools.so is empty, not checked.
ldconfig: File /usr/lib/librdf.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpbase-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libcacard.so.0 is empty, not checked.
ldconfig: File /usr/lib/liborcus-parser-0.18.so is empty, not checked.
ldconfig: File /usr/lib/libKF5ConfigWidgets.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpmath-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libmongoose.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/libvips.so is empty, not checked.
ldconfig: File /usr/lib/libKF5AuthCore.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins-common.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libcamd.so is empty, not checked.
ldconfig: File /usr/lib/libgimpmodule-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libmatroska.so.7.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgimp-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libspnav.so is empty, not checked.
ldconfig: File /usr/lib/libgpuqrengine.so.3.2.2 is empty, not checked.
ldconfig: File /usr/lib/libKF5Wallet.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libavdevice.so.58 is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools-shared.so is empty, not checked.
ldconfig: File /usr/lib/libnumbertext-1.0.so is empty, not checked.
ldconfig: File /usr/lib/libcmis-c-0.6.so.6 is empty, not checked.
ldconfig: File /usr/lib/libLLVM-15.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so.5 is empty, not checked.
ldconfig: File /usr/lib/libsane.so.1.2.1 is empty, not checked.
ldconfig: File /usr/lib/libcxl.so is empty, not checked.
ldconfig: File /usr/lib/libodfgen-0.1.so.1.0.8 is empty, not checked.
ldconfig: File /usr/lib/libOpenImageDenoise.so.2 is empty, not checked.
ldconfig: File /usr/lib/libpaper.so.2.1.2 is empty, not checked.
ldconfig: File /usr/lib/libclang-cpp.so is empty, not checked.
ldconfig: File /usr/lib/libKF5KIOCore.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libmlt++-7.so.7 is empty, not checked.
ldconfig: File /usr/lib/libopenxr_loader.so.1.0.30 is empty, not checked.
ldconfig: File /usr/lib/libKF5I18n.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpthumb-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libspnav.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTemplates2.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libquazip1-qt5.so.1.4.0 is empty, not checked.
ldconfig: File /usr/lib/libcmis-0.6.so.6.1.1 is empty, not checked.
ldconfig: File /usr/lib/libminizip-ng.so.1 is empty, not checked.
ldconfig: File /usr/lib/libmad.so.0.2.1 is empty, not checked.
ldconfig: File /usr/lib/libspectre.so is empty, not checked.
ldconfig: File /usr/lib/libnumbertext-1.0.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libcxl.so.1 is empty, not checked.
ldconfig: File /usr/lib/libswscale.so.5.9.100 is empty, not checked.
ldconfig: File /usr/lib/libKF5XmlGui.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgutenprintui2.so is empty, not checked.
ldconfig: File /usr/lib/libdraco.so.8 is empty, not checked.
ldconfig: File /usr/lib/libavfilter.so.7.110.100 is empty, not checked.
ldconfig: File /usr/lib/libKF5Notifications.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libtracefs.so.1.7.0 is empty, not checked.
ldconfig: File /usr/lib/libdbusmenu-qt5.so.2.6.0 is empty, not checked.
ldconfig: File /usr/lib/libhpipp.so is empty, not checked.
ldconfig: File /usr/lib/libhpipp.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libpugixml.so.1.14 is empty, not checked.
ldconfig: File /usr/lib/libKF5JobWidgets.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl.so.310.0.3 is empty, not checked.
ldconfig: File /usr/lib/libhpdiscovery.so is empty, not checked.
ldconfig: File /usr/lib/libklu_cholmod.so is empty, not checked.
ldconfig: File /usr/lib/libexiv2.so.28 is empty, not checked.
ldconfig: File /usr/lib/libsane.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libmarkdown.so.3.0.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5PurposeWidgets.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libdjvulibre.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl_cpp.so.310.0.3 is empty, not checked.
ldconfig: File /usr/lib/libQt5Svg.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libcupsfilters.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/librdf.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libkwalletbackend5.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_cpp.so.310.0.3 is empty, not checked.
ldconfig: File /usr/lib/libgs.so.10.02 is empty, not checked.
ldconfig: File /usr/lib/libKF5Pty.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5QuickAddons.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-core-1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libOpenImageDenoise.so is empty, not checked.
ldconfig: File /usr/lib/libclang.so.15 is empty, not checked.
ldconfig: File /usr/lib/libsnappy.so.1 is empty, not checked.
ldconfig: File /usr/lib/libphonon4qt5.so.4 is empty, not checked.
ldconfig: File /usr/lib/libpyside6.abi3.so.6.6.0 is empty, not checked.
ldconfig: File /usr/lib/libOpenImageDenoise.so.2.1.0 is empty, not checked.
ldconfig: File /usr/lib/libcfitsio.so is empty, not checked.
ldconfig: File /usr/lib/libodfgen-0.1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libspiro.so is empty, not checked.
ldconfig: File /usr/lib/libixion-0.18.so.0 is empty, not checked.
ldconfig: File /usr/lib/libiniparser.so is empty, not checked.
ldconfig: File /usr/lib/libsuitesparseconfig.so is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-agent-1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgimpconfig-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libmypaint.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libumfpack.so is empty, not checked.
ldconfig: File /usr/lib/libgimpui-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libminizip-ng.so is empty, not checked.
ldconfig: File /usr/lib/libabw-0.1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libphonon4qt5experimental.so.4 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_fortran.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so is empty, not checked.
ldconfig: File /usr/lib/libvdesnmp.so is empty, not checked.
ldconfig: File /usr/lib/libpystring.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libze_loader.so is empty, not checked.
ldconfig: File /usr/lib/libOpenImageIO.so.2.4.17 is empty, not checked.
ldconfig: File /usr/lib/libjsoncpp.so is empty, not checked.
ldconfig: File /usr/lib/libyaml-cpp.so.0.8.0 is empty, not checked.
ldconfig: File /usr/lib/libcolamd.so.3 is empty, not checked.
ldconfig: File /usr/lib/libavutil.so.56.70.100 is empty, not checked.
ldconfig: File /usr/lib/libfdt.so.1.7.0 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-agent-1.so.1.175.0 is empty, not checked.
ldconfig: File /usr/lib/libvips.so.42 is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libqca-qt5.so.2.3.7 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmptrapd.so is empty, not checked.
ldconfig: File /usr/lib/libodfgen-0.1.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so.5 is empty, not checked.
ldconfig: File /usr/lib/libswresample.so.3 is empty, not checked.
ldconfig: File /usr/lib/libsignon-extension.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Multimedia.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libembree4.so.4 is empty, not checked.
ldconfig: File /usr/lib/libre2.so.11 is empty, not checked.
ldconfig: File /usr/lib/libminizip-ng.so.4.0.3 is empty, not checked.
ldconfig: File /usr/lib/libgpuqrengine.so.3 is empty, not checked.
ldconfig: File /usr/lib/libquazip1-qt5.so.1.4 is empty, not checked.
ldconfig: File /usr/lib/libKF5Purpose.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libsignon-extension.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libvdeplug.so.3 is empty, not checked.
ldconfig: File /usr/lib/libaccounts-qt5.so.1 is empty, not checked.
ldconfig: File /usr/lib/liborcus-0.18.so.0 is empty, not checked.
ldconfig: File /usr/lib/libclucene-core.so.2.3.3.4 is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so.5 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-core-1.so.1.175.0 is empty, not checked.
ldconfig: File /usr/lib/libvips-cpp.so.42 is empty, not checked.
ldconfig: File /usr/lib/libdaxctl.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmphelpers.so.40.1.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpwidgets-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcolamd.so is empty, not checked.
ldconfig: File /usr/lib/libusbredirparser.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libijs-0.35.so is empty, not checked.
ldconfig: File /usr/lib/libdraco.so.8.0.0 is empty, not checked.
ldconfig: File /usr/lib/libsuitesparse_gpuruntime.so.3 is empty, not checked.
ldconfig: File /usr/lib/libjbig2dec.so is empty, not checked.
ldconfig: File /usr/lib/libtar.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libvdemgmt.so.0 is empty, not checked.
ldconfig: File /usr/lib/libmwaw-0.3.so.3 is empty, not checked.
ldconfig: File /usr/lib/libspex.so.2 is empty, not checked.
ldconfig: File /usr/lib/libmarkdown.so is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaGstTools.so.5 is empty, not checked.
ldconfig: File /usr/lib/libvips-cpp.so is empty, not checked.
ldconfig: File /usr/lib/libblosc.so.1.21.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlModels.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/liblensfun.so.0.3.4 is empty, not checked.
ldconfig: File /usr/lib/libQt5Pdf.so.5.15.15 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-agent-1.so is empty, not checked.
ldconfig: File /usr/lib/libldl.so.3 is empty, not checked.
ldconfig: File /usr/lib/libcamd.so.3 is empty, not checked.
ldconfig: File /usr/lib/libbabl-0.1.so.0 is empty, not checked.
ldconfig: File /usr/lib/libusbredirhost.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmp.so.40.1.0 is empty, not checked.
ldconfig: File /usr/lib/libvdemgmt.so is empty, not checked.
ldconfig: File /usr/lib/libhpipp.so.0 is empty, not checked.
ldconfig: File /usr/lib/libdbusmenu-qt5.so.2 is empty, not checked.
ldconfig: File /usr/lib/libklu.so.2.2.2 is empty, not checked.
ldconfig: File /usr/lib/libKF5Service.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libdaxctl.so.1.2.5 is empty, not checked.
ldconfig: File /usr/lib/libgegl-0.4.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5Parts.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5Declarative.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5TextWidgets.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libjbig2dec.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libavcodec.so.58 is empty, not checked.
ldconfig: File /usr/lib/libbtf.so.2.2.1 is empty, not checked.
ldconfig: File /usr/lib/libdraco.so is empty, not checked.
ldconfig: File /usr/lib/libclucene-contribs-lib.so is empty, not checked.
ldconfig: File /usr/lib/libclucene-contribs-lib.so.1 is empty, not checked.
ldconfig: File /usr/lib/libsnappy.so.1.1.10 is empty, not checked.
ldconfig: File /usr/lib/libdjvulibre.so.21.7.0 is empty, not checked.
ldconfig: File /usr/lib/libze_loader.so.1 is empty, not checked.
ldconfig: File /usr/lib/libmongoose.so is empty, not checked.
ldconfig: File /usr/lib/liborcus-spreadsheet-model-0.18.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtracefs.so is empty, not checked.
ldconfig: File /usr/lib/libsnmp.so.40 is empty, not checked.
ldconfig: File /usr/lib/libOpenImageIO_Util.so.2.4.17 is empty, not checked.
ldconfig: File /usr/lib/libspectre.so.1.1.12 is empty, not checked.
ldconfig: File /usr/lib/libKF5Package.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libusbredirparser.so.1.2.1 is empty, not checked.
ldconfig: File /usr/lib/libamd.so is empty, not checked.
ldconfig: File /usr/lib/libspqr.so.4 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so.5 is empty, not checked.
ldconfig: File /usr/lib/libKF5Kirigami2.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libcxsparse.so is empty, not checked.
ldconfig: File /usr/lib/liblog4cplusU.so is empty, not checked.
ldconfig: File /usr/lib/libimagequant.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmptrapd.so.40 is empty, not checked.
ldconfig: File /usr/lib/libze_validation_layer.so.1 is empty, not checked.
ldconfig: File /usr/lib/libze_loader.so.1.14.0 is empty, not checked.
ldconfig: File /usr/lib/libtbbmalloc_proxy.so.2.10 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpmibs.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Auth.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgsl.so.27.0.0 is empty, not checked.
ldconfig: File /usr/lib/libndctl.so.6.1.21 is empty, not checked.
ldconfig: File /usr/lib/libqpdf.so.29.6.3 is empty, not checked.
ldconfig: File /usr/lib/libpagemaker-0.0.so is empty, not checked.
ldconfig: File /usr/lib/libumfpack.so.6.2.2 is empty, not checked.
ldconfig: File /usr/lib/libatomic_ops.so.1.2.0 is empty, not checked.
ldconfig: File /usr/lib/liborcus-mso-0.18.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5KCMUtils.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libbtf.so is empty, not checked.
ldconfig: File /usr/lib/libaccounts-qt5.so.1.4.0 is empty, not checked.
ldconfig: File /usr/lib/libmatroska.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTemplates2.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libcupsfilters.so.2 is empty, not checked.
ldconfig: File /usr/lib/libze_tracing_layer.so.1 is empty, not checked.
ldconfig: File /usr/lib/liborcus-parser-0.18.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libhpdiscovery.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl.so is empty, not checked.
ldconfig: File /usr/lib/libtar.so is empty, not checked.
ldconfig: File /usr/lib/libspiro.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/libnet.so is empty, not checked.
ldconfig: File /usr/lib/libgimpcolor-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5WidgetsAddons.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libpaper.so is empty, not checked.
ldconfig: File /usr/lib/libsuitesparse_gpuruntime.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/libklu.so.2 is empty, not checked.
ldconfig: File /usr/lib/libhpip.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/librdf.so is empty, not checked.
ldconfig: File /usr/lib/libshiboken2.cpython-311-x86_64-linux-gnu.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaQuick.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libndctl.so is empty, not checked.
ldconfig: File /usr/lib/libcamd.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/libyaml-cpp.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Solid.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libopenvdb.so.11.0.0 is empty, not checked.
ldconfig: File /usr/lib/libppd.so.2 is empty, not checked.
ldconfig: File /usr/lib/libcmis-0.6.so is empty, not checked.
ldconfig: File /usr/lib/libgimpmodule-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libgs.so.10 is empty, not checked.
ldconfig: File /usr/lib/libclucene-core.so is empty, not checked.
ldconfig: File /usr/lib/libblosc.so.1 is empty, not checked.
ldconfig: File /usr/lib/libclucene-contribs-lib.so.2.3.3.4 is empty, not checked.
ldconfig: File /usr/lib/libqca-qt5.so.2 is empty, not checked.
ldconfig: File /usr/lib/libcmis-c-0.6.so.6.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgutenprint.so.9.5.0 is empty, not checked.
ldconfig: File /usr/lib/libexttextcat-2.0.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libosdGPU.so.3.5.0 is empty, not checked.
ldconfig: File /usr/lib/libebur128.so.1 is empty, not checked.
ldconfig: File /usr/lib/libvirglrenderer.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libzopflipng.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/librbio.so is empty, not checked.
ldconfig: File /usr/lib/libnumbertext-1.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libclucene-shared.so.1 is empty, not checked.
ldconfig: File /usr/lib/libclang.so.16 is empty, not checked.
ldconfig: File /usr/lib/libaec.so.0.0.12 is empty, not checked.
ldconfig: File /usr/lib/libgraphblas.so.8.2.1 is empty, not checked.
ldconfig: File /usr/lib/libaccounts-glib.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpagent.so.40 is empty, not checked.
ldconfig: File /usr/lib/libclang-cpp.so.16 is empty, not checked.
ldconfig: File /usr/lib/libKF5KIONTLM.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libxdo.so is empty, not checked.
ldconfig: File /usr/lib/libPtex.so is empty, not checked.
ldconfig: File /usr/lib/librevenge-0.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/liborcus-mso-0.18.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickControls2.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libgimpcolor-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libxdo.so.3 is empty, not checked.
ldconfig: File /usr/lib/libKF5KIOFileWidgets.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libcacard.so is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaWidgets.so.5 is empty, not checked.
ldconfig: File /usr/lib/libumfpack.so.6 is empty, not checked.
ldconfig: File /usr/lib/libvirglrenderer.so.1.7.7 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools-diff.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libgimp-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libhpmud.so.0.0.6 is empty, not checked.
ldconfig: File /usr/lib/libtracefs.so.1 is empty, not checked.
ldconfig: File /usr/lib/libcacard.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libtar.so.0 is empty, not checked.
ldconfig: File /usr/lib/libquazip1-qt5.so is empty, not checked.
ldconfig: File /usr/lib/libebur128.so is empty, not checked.
ldconfig: File /usr/lib/libKF5I18nLocaleData.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libhpdf.so.2.4 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins.so.1.0 is empty, not checked.
ldconfig: File /usr/lib/libwpg-0.3.so.3 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so is empty, not checked.
ldconfig: File /usr/lib/libshiboken2.cpython-311-x86_64-linux-gnu.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libjsoncpp.so.25 is empty, not checked.
ldconfig: File /usr/lib/libKF5Activities.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libspqr.so.4.2.2 is empty, not checked.
ldconfig: File /usr/lib/libfdt.so.1 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmphelpers.so.40 is empty, not checked.
ldconfig: File /usr/lib/libpotrace.so.0.0.6 is empty, not checked.
ldconfig: File /usr/lib/libsuitesparse_gpuruntime.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickParticles.so.5 is empty, not checked.
ldconfig: File /usr/lib/libhpdf.so.2.4.4 is empty, not checked.
ldconfig: File /usr/lib/librevenge-stream-0.0.so.0.0.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_fortran.so.310 is empty, not checked.
ldconfig: File /usr/lib/libgpuqrengine.so is empty, not checked.
ldconfig: File /usr/lib/libgexiv2.so.2 is empty, not checked.
ldconfig: File /usr/lib/libluajit-5.1.so.2.1.1700008891 is empty, not checked.
ldconfig: File /usr/lib/libAlembic.so is empty, not checked.
ldconfig: File /usr/lib/libclucene-core.so.1 is empty, not checked.
ldconfig: File /usr/lib/libatomic_ops.so.1 is empty, not checked.
ldconfig: File /usr/lib/libmypaint-gegl.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5WebChannel.so is empty, not checked.
ldconfig: File /usr/lib/libhpmud.so is empty, not checked.
ldconfig: File /usr/lib/libKF5SonnetUi.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libcxsparse.so.4 is empty, not checked.
ldconfig: File /usr/lib/librevenge-stream-0.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgutenprintui2.so.2 is empty, not checked.
ldconfig: File /usr/lib/liblog4cplus-2.1.so.9.0.0 is empty, not checked.
ldconfig: File /usr/lib/libimagequant.so.0.0.4 is empty, not checked.
ldconfig: File /usr/lib/libpoppler-qt5.so is empty, not checked.
ldconfig: File /usr/lib/libwolfssl.so.41 is empty, not checked.
ldconfig: File /usr/lib/libzopfli.so.1 is empty, not checked.
ldconfig: File /usr/lib/libmypaint-gegl.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Codecs.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libspnav.so.0.3 is empty, not checked.
ldconfig: File /usr/lib/libldl.so is empty, not checked.
ldconfig: File /usr/lib/libclang.so.16.0.6 is empty, not checked.
ldconfig: File /usr/lib/liborcus-0.18.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libvdehist.so.0 is empty, not checked.
ldconfig: File /usr/lib/libavformat.so.58.76.100 is empty, not checked.
ldconfig: File /usr/lib/libijs.so is empty, not checked.
ldconfig: File /usr/lib/libQt5TextToSpeech.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WebChannel.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl.so.310 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickControls2.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpagent.so is empty, not checked.
ldconfig: File /usr/lib/liborcus-0.18.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WebChannel.so.5 is empty, not checked.
ldconfig: File /usr/lib/libdjvulibre.so.21 is empty, not checked.
ldconfig: File /usr/lib/libetonyek-0.1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libhpdiscovery.so.0 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmphelpers.so is empty, not checked.
ldconfig: File /usr/lib/libsane.so is empty, not checked.
ldconfig: File /usr/lib/libOpenImageIO_Util.so.2.4 is empty, not checked.
ldconfig: File /usr/lib/libhdf5hl_fortran.so.310 is empty, not checked.
ldconfig: File /usr/lib/libspectre.so.1 is empty, not checked.
ldconfig: File /usr/lib/libndctl.so.6 is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools-reduce.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so.5 is empty, not checked.
ldconfig: File /usr/lib/libspex.so.2.2.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTest.so is empty, not checked.
ldconfig: File /usr/lib/libgimpwidgets-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libpystring.so is empty, not checked.
ldconfig: File /usr/lib/libKF5DBusAddons.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libccolamd.so.3 is empty, not checked.
ldconfig: File /usr/lib/libmlt-7.so.7 is empty, not checked.
ldconfig: File /usr/lib/librevenge-generators-0.0.so is empty, not checked.
ldconfig: File /usr/lib/libyaml-cpp.so.0.8 is empty, not checked.
ldconfig: File /usr/lib/libbox2d.so.2 is empty, not checked.
ldconfig: File /usr/lib/libatomic_ops_gpl.so is empty, not checked.
ldconfig: File /usr/lib/libiniparser.so.1 is empty, not checked.
ldconfig: File /usr/lib/libtraceevent.so.1.7.3 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickTemplates2.so is empty, not checked.
ldconfig: File /usr/lib/libwpg-0.3.so is empty, not checked.
ldconfig: File /usr/lib/libfreehand-0.1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libatomic_ops_gpl.so.1.2.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5Quick.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libQt5QmlWorkerScript.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libshiboken2.cpython-311-x86_64-linux-gnu.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WebChannel.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libze_tracing_layer.so.1.14.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5WindowSystem.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libepubgen-0.1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgimp-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libexiv2.so.0.28.1 is empty, not checked.
ldconfig: File /usr/lib/libaribb24.so.0 is empty, not checked.
ldconfig: File /usr/lib/libtommath.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Qml.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libclang-cpp.so.15 is empty, not checked.
ldconfig: File /usr/lib/libgimpconfig-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libatomic_ops.so is empty, not checked.
ldconfig: File /usr/lib/libwolfssl.so is empty, not checked.
ldconfig: File /usr/lib/libavcodec.so.58.134.100 is empty, not checked.
ldconfig: File /usr/lib/libopenvdb.so is empty, not checked.
ldconfig: File /usr/lib/libgegl-npd-0.4.so is empty, not checked.
ldconfig: File /usr/lib/libzopfli.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/libwpd-0.10.so.10.0.3 is empty, not checked.
ldconfig: File /usr/lib/librasqal.so.3.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgegl-0.4.so is empty, not checked.
ldconfig: File /usr/lib/libvdehist.so.0.0.1 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins-common.so.1 is empty, not checked.
ldconfig: File /usr/lib/libgimpwidgets-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libcapstone.so.4 is empty, not checked.
ldconfig: File /usr/lib/libsignon-qt5.so.1 is empty, not checked.
ldconfig: File /usr/lib/libbtf.so.2 is empty, not checked.
ldconfig: File /usr/lib/libsnappy.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so is empty, not checked.
ldconfig: File /usr/lib/libmypaint-gegl.so.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5GlobalAccel.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickControls2.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libepubgen-0.1.so is empty, not checked.
ldconfig: File /usr/lib/libosdGPU.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5.so.310.3.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5ConfigCore.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libhpmud.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcgif.so.0.3.2 is empty, not checked.
ldconfig: File /usr/lib/libAlembic.so.1.8.6 is empty, not checked.
ldconfig: File /usr/lib/libcmis-c-0.6.so is empty, not checked.
ldconfig: File /usr/lib/libblosc.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl_cpp.so is empty, not checked.
ldconfig: File /usr/lib/libcupsfilters.so is empty, not checked.
ldconfig: File /usr/lib/libQt5TextToSpeech.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libhdf5.so.310 is empty, not checked.
ldconfig: File /usr/lib/libklu_cholmod.so.2 is empty, not checked.
ldconfig: File /usr/lib/libLLVM-15.0.7.so is empty, not checked.
ldconfig: File /usr/lib/libphonon4qt5experimental.so is empty, not checked.
ldconfig: File /usr/lib/libOpenImageDenoise_device_cpu.so.2.1.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandCompositor.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libetonyek-0.1.so.1.0.10 is empty, not checked.
ldconfig: File /usr/lib/libsignon-qt5.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libdbusmenu-qt5.so is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickControls2.so.5 is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools-link.so is empty, not checked.
ldconfig: File /usr/lib/libPtex.so.2.4 is empty, not checked.
ldconfig: File /usr/lib/libmwaw-0.3.so is empty, not checked.
ldconfig: File /usr/lib/libQt5WaylandClient.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libaccounts-glib.so.1.25 is empty, not checked.
ldconfig: File /usr/lib/libfdt.so is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-core-1.so is empty, not checked.
ldconfig: File /usr/lib/libdaxctl.so.1 is empty, not checked.
ldconfig: File /usr/lib/libspqr.so is empty, not checked.
ldconfig: File /usr/lib/libmlt-7.so.7.22.0 is empty, not checked.
ldconfig: File /usr/lib/libstaroffice-0.0.so.0.0.7 is empty, not checked.
ldconfig: File /usr/lib/librevenge-0.0.so is empty, not checked.
ldconfig: File /usr/lib/libstaroffice-0.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-gui-1.so.1.175.0 is empty, not checked.
ldconfig: File /usr/lib/libsignon-extension.so.1 is empty, not checked.
ldconfig: File /usr/lib/libsignon-qt5.so.1.0 is empty, not checked.
ldconfig: File /usr/lib/libmypaint.so is empty, not checked.
ldconfig: File /usr/lib/libnet.so.9.0.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5TextToSpeech.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpagent.so.40.1.0 is empty, not checked.
ldconfig: File /usr/lib/libosdCPU.so is empty, not checked.
ldconfig: File /usr/lib/libhunspell-1.7.so.0 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins-common.so.1.0 is empty, not checked.
ldconfig: File /usr/lib/libvips-cpp.so.42.17.0 is empty, not checked.
ldconfig: File /usr/lib/libmypaint.so.0 is empty, not checked.
ldconfig: File /usr/lib/libhpip.so is empty, not checked.
ldconfig: File /usr/lib/libexiv2.so is empty, not checked.
ldconfig: File /usr/lib/libebur128.so.1.2.6 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaGstTools.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_cpp.so is empty, not checked.
ldconfig: File /usr/lib/libspiro.so.1 is empty, not checked.
ldconfig: File /usr/lib/libminizip.so is empty, not checked.
ldconfig: File /usr/lib/libieee1284.so.3 is empty, not checked.
ldconfig: File /usr/lib/libpyside2.cpython-311-x86_64-linux-gnu.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libKF5IconThemes.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libminizip.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpthumb-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libmlt++-7.so is empty, not checked.
ldconfig: File /usr/lib/libwmf-0.2.so.7.1.5 is empty, not checked.
ldconfig: File /usr/lib/libwmflite-0.2.so.7 is empty, not checked.
ldconfig: File /usr/lib/libccolamd.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/libusbredirhost.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/libre2.so.11.0.0 is empty, not checked.
ldconfig: File /usr/lib/libgutenprint.so.9 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmptrapd.so.40.1.0 is empty, not checked.
ldconfig: File /usr/lib/libmlt++-7.so.7.22.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5ThreadWeaver.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaWidgets.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libcgif.so.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpmath-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libcxl.so.1.1.3 is empty, not checked.
ldconfig: File /usr/lib/librevenge-generators-0.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libavfilter.so.7 is empty, not checked.
ldconfig: File /usr/lib/libtommath.so.1 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins-common.so is empty, not checked.
ldconfig: File /usr/lib/libdvbpsi.so is empty, not checked.
ldconfig: File /usr/lib/libopenpgl.so.0.5.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so.5 is empty, not checked.
ldconfig: File /usr/lib/libabw-0.1.so.1.0.3 is empty, not checked.
ldconfig: File /usr/lib/libsignon-plugins.so.1.0.0 is empty, not checked.
ldconfig: File /usr/lib/libphonon4qt5.so is empty, not checked.
ldconfig: File /usr/lib/libldl.so.3.2.1 is empty, not checked.
ldconfig: File /usr/lib/libaccounts-qt5.so.1.4 is empty, not checked.
ldconfig: File /usr/lib/libswresample.so.3.9.100 is empty, not checked.
ldconfig: File /usr/lib/libKF5KCMUtilsCore.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgimpbase-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libpostproc.so.55 is empty, not checked.
ldconfig: File /usr/lib/libQt5QuickShapes.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libKF5SonnetCore.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL2_image-2.0.so.0.600.3 is empty, not checked.
ldconfig: File /usr/lib/liblog4cplusU-2.1.so.9.0.0 is empty, not checked.
ldconfig: File /usr/lib/liblog4cplusU-2.1.so.9 is empty, not checked.
ldconfig: File /usr/lib/libpotrace.so is empty, not checked.
ldconfig: File /usr/lib/libcholmod.so.5 is empty, not checked.
ldconfig: File /usr/lib/liblog4cplus-2.1.so.9 is empty, not checked.
ldconfig: File /usr/lib/libmongoose.so.3 is empty, not checked.
ldconfig: File /usr/lib/libwps-0.4.so is empty, not checked.
ldconfig: File /usr/lib/liborcus-spreadsheet-model-0.18.so is empty, not checked.
ldconfig: File /usr/lib/libKF5CalendarEvents.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libtinyxml.so is empty, not checked.
ldconfig: File /usr/lib/libswscale.so.5 is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so.2.2.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5KIOWidgets.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libmad.so is empty, not checked.
ldconfig: File /usr/lib/libpoppler-qt5.so.1 is empty, not checked.
ldconfig: File /usr/lib/libwpg-0.3.so.3.0.4 is empty, not checked.
ldconfig: File /usr/lib/libKF5KIOGui.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libmng.so.2 is empty, not checked.
ldconfig: File /usr/lib/libze_validation_layer.so.1.14.0 is empty, not checked.
ldconfig: File /usr/lib/libstaroffice-0.0.so is empty, not checked.
ldconfig: File /usr/lib/libKF5Completion.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libpugixml.so.1 is empty, not checked.
ldconfig: File /usr/lib/libSPIRV-Tools-lint.so is empty, not checked.
ldconfig: File /usr/lib/libnetsnmp.so is empty, not checked.
ldconfig: File /usr/lib/libcxsparse.so.4.2.1 is empty, not checked.
ldconfig: File /usr/lib/libppd.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/librevenge-generators-0.0.so.0.0.5 is empty, not checked.
ldconfig: File /usr/lib/libPhabricatorHelpers.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libtommath.so.1.2.1 is empty, not checked.
ldconfig: File /usr/lib/libpaper.so.2 is empty, not checked.
ldconfig: File /usr/lib/libQt5WebEngine.so.5.15.15 is empty, not checked.
ldconfig: File /usr/lib/liborcus-parser-0.18.so.0 is empty, not checked.
ldconfig: File /usr/lib/libwmflite.so is empty, not checked.
ldconfig: File /usr/lib/libgutenprint.so is empty, not checked.
ldconfig: File /usr/lib/libvdeplug.so is empty, not checked.
ldconfig: File /usr/lib/libvirglrenderer.so.1 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmp.so.40 is empty, not checked.
ldconfig: File /usr/lib/libhpip.so.0 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaQuick.so.5.15.11 is empty, not checked.
ldconfig: File /usr/lib/libgimpui-2.0.so.0.1000.36 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaQuick.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5_cpp.so.310 is empty, not checked.
ldconfig: File /usr/lib/libgimpmodule-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libminizip.so.1 is empty, not checked.
ldconfig: File /usr/lib/libusbredirparser.so is empty, not checked.
ldconfig: File /usr/lib/libcholmod.so.5.0.1 is empty, not checked.
ldconfig: File /usr/lib/libpostproc.so.55.9.100 is empty, not checked.
ldconfig: File /usr/lib/libKF5GlobalAccelPrivate.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libKF5CoreAddons.so.5.112.0 is empty, not checked.
ldconfig: File /usr/lib/libgegl-sc-0.4.so is empty, not checked.
ldconfig: File /usr/lib/libopenpgl.so is empty, not checked.
ldconfig: File /usr/lib/libphonon4qt5experimental.so.4.12.0 is empty, not checked.
ldconfig: File /usr/lib/libieee1284.so.3.2.2 is empty, not checked.
ldconfig: File /usr/lib/libpotrace.so.0 is empty, not checked.
ldconfig: File /usr/lib/libexttextcat-2.0.so.0 is empty, not checked.
ldconfig: File /usr/lib/libOpenImageDenoise_core.so.2.1.0 is empty, not checked.
ldconfig: File /usr/lib/libgs.so is empty, not checked.
ldconfig: File /usr/lib/libQt5X11Extras.so.5 is empty, not checked.
ldconfig: File /usr/lib/libhdf5hl_fortran.so.310.0.3 is empty, not checked.
ldconfig: File /usr/lib/libpolkit-qt5-gui-1.so.1 is empty, not checked.
ldconfig: File /usr/lib/libQt5WebEngineWidgets.so.5.15.15 is empty, not checked.
ldconfig: File /usr/lib/libnetsnmpmibs.so.40 is empty, not checked.
ldconfig: File /usr/lib/libcmis-0.6.so.6 is empty, not checked.
ldconfig: File /usr/lib/libaccounts-glib.so is empty, not checked.
ldconfig: File /usr/lib/librbio.so.4.2.1 is empty, not checked.
ldconfig: File /usr/lib/libmlt-7.so is empty, not checked.
ldconfig: File /usr/lib/libsnmp.so is empty, not checked.
ldconfig: File /usr/lib/libpystring.so.0 is empty, not checked.
ldconfig: File /usr/lib/libpugixml.so is empty, not checked.
ldconfig: File /usr/lib/libhdf5.so is empty, not checked.
ldconfig: File /usr/lib/libfreehand-0.1.so.1.0.2 is empty, not checked.
ldconfig: File /usr/lib/libphonon4qt5.so.4.12.0 is empty, not checked.
ldconfig: File /usr/lib/libhdf5_hl_cpp.so.310 is empty, not checked.
ldconfig: File /usr/lib/libQt5MultimediaWidgets.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libembree4.so is empty, not checked.
ldconfig: File /usr/lib/libvdehist.so is empty, not checked.
ldconfig: File /usr/lib/libaccounts-qt5.so is empty, not checked.
ldconfig: File /usr/lib/libpyside2.cpython-311-x86_64-linux-gnu.so is empty, not checked.
ldconfig: File /usr/lib/libdvbpsi.so.10.0.0 is empty, not checked.
ldconfig: File /usr/lib/liborcus-spreadsheet-model-0.18.so.0.0.0 is empty, not checked.
ldconfig: File /usr/lib/libGLEW.so.2.2 is empty, not checked.
ldconfig: File /usr/lib/libQt5PdfWidgets.so.5.15.15 is empty, not checked.
ldconfig: File /usr/lib/libbabl-0.1.so.0.205.1 is empty, not checked.
ldconfig: File /usr/lib/libwpd-0.10.so.10 is empty, not checked.
ldconfig: File /usr/lib/libzopflipng.so.1 is empty, not checked.
  1. I also got error: unable to write to pipe (Broken pipe) after a bunch of output lines with the prefix dracut: . Not sure if this will need manual intervention either.
dracut and broken pipe output
dracut: Executing: /usr/bin/dracut --no-hostonly --force /efi/cc7f0fcec396452e8035342a8ada4b27/6.6.8-arch1-1/initrd-fallback 6.6.8-arch1-1
dracut: dracut module 'dash' will not be installed, because command 'dash' could not be found!
dracut: dracut module 'mksh' will not be installed, because command 'mksh' could not be found!
dracut: dracut module 'systemd-pcrphase' will not be installed, because command '/usr/lib/systemd/systemd-pcrphase' could not be found!
dracut: dracut module 'busybox' will not be installed, because command 'busybox' could not be found!
dracut: dracut module 'dbus-broker' will not be installed, because command 'dbus-broker' could not be found!
dracut: dracut module 'rngd' will not be installed, because command 'rngd' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmanctl' could not be found!
dracut: dracut module 'connman' will not be installed, because command 'connmand-wait-online' could not be found!
dracut: dracut module 'network-wicked' will not be installed, because command 'wicked' could not be found!
dracut: dracut module 'dmraid' will not be installed, because command 'kpartx' could not be found!
dracut: dracut module 'multipath' will not be installed, because command 'multipath' could not be found!
dracut: dracut module 'tpm2-tss' will not be installed, because command 'tpm2' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoemon' could not be found!
dracut: dracut module 'fcoe' will not be installed, because command 'fcoeadm' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'dcbtool' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'fipvlan' could not be found!
dracut: dracut module 'fcoe-uefi' will not be installed, because command 'lldpad' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsi-iname' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsiadm' could not be found!
dracut: dracut module 'iscsi' will not be installed, because command 'iscsid' could not be found!
dracut: dracut module 'nbd' depends on 'network', which can't be installed
dracut: dracut module 'nvmf' will not be installed, because command 'nvme' could not be found!
dracut: dracut module 'biosdevname' will not be installed, because command 'biosdevname' could not be found!
dracut: dracut module 'memstrack' will not be installed, because command 'memstrack' could not be found!
dracut: memstrack is not available
dracut: If you need to use rd.memdebug>=4, please install memstrack and procps-ng
dracut: dracut module 'squash' will not be installed, because command 'mksquashfs' could not be found!
dracut: dracut module 'squash' will not be installed, because command 'unsquashfs' could not be found!
dracut: *** Including module: systemd ***
dracut: *** Including module: systemd-initrd ***
dracut: *** Including module: modsign ***
dracut: *** Including module: i18n ***
dracut: *** Including module: btrfs ***
dracut: *** Including module: crypt ***
dracut: *** Including module: dm ***
dracut: Skipping udev rule: 64-device-mapper.rules
dracut: Skipping udev rule: 60-persistent-storage-dm.rules
dracut: Skipping udev rule: 55-dm.rules
dracut: *** Including module: kernel-modules ***
dracut: *** Including module: kernel-modules-extra ***
dracut: *** Including module: lvm ***
dracut: Skipping udev rule: 56-lvm.rules
dracut: Skipping udev rule: 60-persistent-storage-lvm.rules
dracut: *** Including module: mdraid ***
dracut: Skipping udev rule: 64-md-raid.rules
dracut: *** Including module: nvdimm ***
dracut: *** Including module: qemu ***
dracut: *** Including module: qemu-net ***
dracut: *** Including module: lunmask ***
dracut: *** Including module: resume ***
dracut: *** Including module: rootfs-block ***
dracut: *** Including module: terminfo ***
dracut: *** Including module: udev-rules ***
dracut: Skipping udev rule: 40-redhat.rules
dracut: Skipping udev rule: 50-firmware.rules
dracut: Skipping udev rule: 50-udev.rules
dracut: Skipping udev rule: 91-permissions.rules
dracut: Skipping udev rule: 80-drivers-modprobe.rules
dracut: *** Including module: virtiofs ***
dracut: *** Including module: dracut-systemd ***
dracut: *** Including module: usrmount ***
dracut: *** Including module: base ***
dracut: *** Including module: fs-lib ***
dracut: *** Including module: shutdown ***
dracut: *** Including modules done ***
dracut: *** Installing kernel module dependencies ***
dracut: *** Installing kernel module dependencies done ***
dracut: *** Resolving executable dependencies ***
dracut: *** Resolving executable dependencies done ***
dracut: *** Hardlinking files ***
dracut: Mode:                     real
dracut: Method:                   memcmp
dracut: Files:                    2005
dracut: Linked:                   8 files
dracut: Compared:                 0 xattrs
dracut: Compared:                 441 files
dracut: Saved:                    1.42 MiB
dracut: Duration:                 0.011516 seconds
dracut: *** Hardlinking files done ***
dracut: *** Generating early-microcode cpio image ***
dracut: *** Constructing AuthenticAMD.bin ***
dracut: *** Store current command line parameters ***
dracut: *** Stripping files ***
dracut: *** Stripping files done ***
dracut: *** Creating image file '/efi/cc7f0fcec396452e8035342a8ada4b27/6.6.8-arch1-1/initrd-fallback' ***
dracut: *** Creating initramfs image file '/efi/cc7f0fcec396452e8035342a8ada4b27/6.6.8-arch1-1/initrd-fallback' done ***
dracut: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/cc7f0fcec396452e8035342a8ada4b27/6.6.8-arch1-1/initrd 6.6.8-arch1-1
dracut: Skipping udev rule: 70-persistent-net.rules
dracut: Mode:                     real
dracut: Files:                    812
dracut: Linked:                   2 files
dracut: Compared:                 37 files
dracut: Saved:                    356.65 KiB
dracut: Duration:                 0.004479 seconds
dracut: *** Creating image file '/efi/cc7f0fcec396452e8035342a8ada4b27/6.6.8-arch1-1/initrd' ***
dracut: *** Creating initramfs image file '/efi/cc7f0fcec396452e8035342a8ada4b27/6.6.8-arch1-1/initrd' done ***
Next step is a reboot, which will hopefully go smoothly!
Try booting the fallback entry if the normal one fails.
Thanks, the reboot worked fine, thankfully! I still have some broken packages, though. Maybe packages that didn’t have updates?
Referencing this ArchWiki page, I checked find /usr/lib -size 0 and there are currently 25443 results. That’s a lot to manage one by one, but gotta try something. All the ldconfig lines from my previous post are in this directory, though there are many more empty files than listed in those ldconfig lines.
A few entries were under /usr/lib/libreoffice/. LibreOffice currently won’t start up correctly (splash screen shows, then it fails before showing a window), so I figured I’d start there. I tried sudo pacman -S libreoffice-fresh. The command succeeded, but there’s no change to the number of 0-length files under /usr/lib/ and LibreOffice still won’t start up.
Is this a time to do a full pacman -Qqn | pacman -S - as mentioned here, or is there a more targeted approach you’d recommend?
Use pacman -Qkk to find the packages with issues.
Nice, that helps narrow things down. I reinstalled packages that showed “no mtree file” which seems to have fixed a lot (e.g. I can now open LibreOffice).
There are some other types of messages that I’m not certain how to handle (or if they’re a problem at all). Here’s an example:
eos-qogir-icons: 33824 total files, 2 altered files
I reinstalled eos-qogir-icons, but pacman -Qkk still lists 2 altered files for it, though it’s only a modification time mismatch, so that probably doesn’t matter.
Here's what's left
$ pacman -Qkk 2>&1 | grep -v ', 0 altered files'
warning: bash: /etc/skel/.bash_profile (UID mismatch)
warning: bash: /etc/skel/.bash_profile (GID mismatch)
warning: bash: /etc/skel/.bash_profile (Permissions mismatch)
warning: bash: /etc/skel/.bashrc (UID mismatch)
warning: bash: /etc/skel/.bashrc (GID mismatch)
warning: bash: /etc/skel/.bashrc (Permissions mismatch)
backup file: bash: /etc/skel/.bash_profile (Modification time mismatch)
backup file: bash: /etc/skel/.bash_profile (Size mismatch)
backup file: bash: /etc/skel/.bash_profile (MD5 checksum mismatch)
backup file: bash: /etc/skel/.bash_profile (SHA256 checksum mismatch)
backup file: bash: /etc/skel/.bashrc (Modification time mismatch)
backup file: bash: /etc/skel/.bashrc (Size mismatch)
backup file: bash: /etc/skel/.bashrc (MD5 checksum mismatch)
backup file: bash: /etc/skel/.bashrc (SHA256 checksum mismatch)
bash: 257 total files, 2 altered files
coreutils: 441warning: eos-qogir-icons: /usr/share/icons/Qogir/icon-theme.cache (Modification time mismatch)
warning: eos-qogir-icons: /usr/share/icons/Qogir-dark/icon-theme.cache (Modification time mismatch)
backup file: default-cursors: /usr/share/icons/default/index.theme (Modification time mismatch)
backup file: default-cursors: /usr/share/icons/default/index.theme (Size mismatch)
backup file: default-cursors: /usr/share/icons/default/index.theme (MD5 checksum mismatch)
backup file: default-cursors: /usr/share/icons/default/index.theme (SHA256 checksum mismatch)
backup file: endeavouros-mirrorlist: /etc/pacman.d/endeavouros-mirrorlist (Modification time mismatch)
backup file: endeavouros-mirrorlist: /etc/pacman.d/endeavouros-mirrorlist (Size mismatch)
backup file: endeavouros-mirrorlist: /etc/pacman.d/endeavouros-mirrorlist (MD5 checksum mismatch)
backup file: endeavouros-mirrorlist: /etc/pacman.d/endeavouros-mirrorlist (SHA256 checksum mismatch)
faac: 26 total files, 0 alteredwarning: filesystem: /etc/gshadow (Permissions mismatch)
warning: filesystem: /etc/shadow (Permissions mismatch)
warning: filesystem: /usr/lib/os-release (Modification time mismatch)
warning: filesystem: /usr/lib/os-release (Size mismatch)
warning: filesystem: /usr/lib/os-release (MD5 checksum mismatch)
warning: filesystem: /usr/lib/os-release (SHA256 checksum mismatch)
 files
backup file: filesystem: /etc/crypttab (Modification time mismatch)
backup file: filesystem: /etc/crypttab (Size mismatch)
backup file: filesystem: /etc/crypttab (MD5 checksum mismatch)
backup file: filesystem: /etc/crypttab (SHA256 checksum mismatch)
backup file: filesystem: /etc/fstab (Modification time mismatch)
backup file: filesystem: /etc/fstab (Size mismatch)
backup file: filesystem: /etc/fstab (MD5 checksum mismatch)
backup file: filesystem: /etc/fstab (SHA256 checksum mismatch)
backup file: filesystem: /etc/group (Modification time mismatch)
backup file: filesystem: /etc/group (Size mismatch)
backup file: filesystem: /etc/group (MD5 checksum mismatch)
backup file: filesystem: /etc/group (SHA256 checksum mismatch)
backup file: filesystem: /etc/gshadow (Modification time mismatch)
backup file: filesystem: /etc/gshadow (Size mismatch)
backup file: filesystem: /etc/gshadow (MD5 checksum mismatch)
backup file: filesystem: /etc/gshadow (SHA256 checksum mismatch)
backup file: filesystem: /etc/hosts (Modification time mismatch)
backup file: filesystem: /etc/hosts (Size mismatch)
backup file: filesystem: /etc/hosts (MD5 checksum mismatch)
backup file: filesystem: /etc/hosts (SHA256 checksum mismatch)
backup file: filesystem: /etc/issue (Modification time mismatch)
backup file: filesystem: /etc/issue (Size mismatch)
backup file: filesystem: /etc/issue (MD5 checksum mismatch)
backup file: filesystem: /etc/issue (SHA256 checksum mismatch)
backup file: filesystem: /etc/passwd (Modification time mismatch)
backup file: filesystem: /etc/passwd (Size mismatch)
backup file: filesystem: /etc/passwd (MD5 checksum mismatch)
backup file: filesystem: /etc/passwd (SHA256 checksum mismatch)
backup file: filesystem: /etc/resolv.conf (Modification time mismatch)
backup file: filesystem: /etc/resolv.conf (Size mismatch)
backup file: filesystem: /etc/resolv.conf (MD5 checksum mismatch)
backup file: filesystem: /etc/resolv.conf (SHA256 checksum mismatch)
backup file: filesystem: /etc/shadow (Modification time mismatch)
backup file: filesystem: /etc/shadow (Size mismatch)
backup file: filesystem: /etc/shadow (MD5 checksum mismatch)
backup file: filesystem: /etc/shadow (SHA256 checksum mismatch)
backup file: filesystem: /etc/subgid (Modification time mismatch)
backup file: filesystem: /etc/subgid (Size mismatch)
backup file: filesystem: /etc/subgid (MD5 checksum mismatch)
backup file: filesystem: /etc/subgid (SHA256 checksum mismatch)
backup file: filesystem: /etc/subuid (Modification time mismatch)
backup file: filesystem: /etc/subuid (Size mismatch)
backup file: filesystem: /etc/subuid (MD5 checksum mismatch)
backup file: filesystem: /etc/subuid (SHA256 checksum mismatch)
filesystem: 120 total files, 3 altered files
backup file: glibc: /etc/locale.gen (Modification time mismatch)
backup file: glibc: /etc/locale.gen (Size mismatch)
backup file: glibc: /etc/locale.gen (MD5 checksum mismatch)
backup file: glibc: /etc/locale.gen (SHA256 checksum mismatch)
iwarning: java-runtime-common: /usr/lib/jvm/default (Symlink path mismatch)
warning: java-runtime-common: /usr/lib/jvm/default (Modification time mismatch)
warning: java-runtime-common: /usr/lib/jvm/default-runtime (Symlink path mismatch)
warning: java-runtime-common: /usr/lib/jvm/default-runtime (Modification time mismatch)
java-runtime-common: 21 total files, 2 altered files
libtar: 88 total files, 0 alteredwarning: libutempter: /usr/lib/utempter/utempter (GID mismatch)
warning: libutempter: /usr/lib/utempter/utempter (Permissions mismatch)
 files
libutempter: 20 total files, 1 altered file
backup file: lightdm: /etc/lightdm/lightdm.conf (Modification time mismatch)
backup file: lightdm: /etc/lightdm/lightdm.conf (Size mismatch)
backup file: lightdm: /etc/lightdm/lightdm.conf (MD5 checksum mismatch)
backup file: lightdm: /etc/lightdm/lightdm.conf (SHA256 checksum mismatch)
llvm15-libs:warning: lsb-release: /etc/lsb-release (Modification time mismatch)
warning: lsb-release: /etc/lsb-release (Size mismatch)
warning: lsb-release: /etc/lsb-release (MD5 checksum mismatch)
warning: lsb-release: /etc/lsb-release (SHA256 checksum mismatch)
lsb-release: 9 total files, 1 altered file
backup file: pacman: /etc/pacman.conf (Modification time mismatch)
backup file: pacman: /etc/pacman.conf (Size mismatch)
backup file: pacman: /etc/pacman.conf (MD5 checksum mismatch)
backup file: pacman: /etc/pacman.conf (SHA256 checksum mismatch)
backup file: pacman-mirrorlist: /etc/pacman.d/mirrorlist (Modification time mismatch)
backup file: pacman-mirrorlist: /etc/pacman.d/mirrorlist (Size mismatch)
backup file: pacman-mirrorlist: /etc/pacman.d/mirrorlist (MD5 checksum mismatch)
backup file: pacman-mirrorlist: /etc/pacman.d/mirrorlist (SHA256 checksum mismatch)
backup file: pam: /etc/environment (Modification time mismatch)
backup file: pam: /etc/environment (Size mismatch)
backup file: pam: /etc/environment (MD5 checksum mismatch)
backup file: pam: /etc/environment (SHA256 checksum mismatch)
shaderc: 22 totalwarning: shadow: /usr/bin/groupmems (GID mismatch)
warning: shadow: /usr/bin/groupmems (Permissions mismatch)
warning: systemd: /var/log/journal (GID mismatch)
shadow: 588 total files, 1 altered file
systemd: 1455 total files, 1 altered file
backup file: util-linux: /etc/pam.d/su (Modification time mismatch)
backup file: util-linux: /etc/pam.d/su (Size mismatch)
backup file: util-linux: /etc/pam.d/su (MD5 checksum mismatch)
backup file: util-linux: /etc/pam.d/su (SHA256 checksum mismatch)
virtiowarning: vlc: /usr/lib/vlc/plugins/plugins.dat (Modification time mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (Size mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (MD5 checksum mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (SHA256 checksum mismatch)
vlc: 1084 total files, 1 altered file
  • I’m guessing I can ignore modification time differences when that’s the only mismatch.
  • Seems odd to need to reinstall bash just for the /etc/skel/* permissions mismatches. Maybe leave alone? Fix the permissions manually? Just reinstall?
  • endeavouros-mirrorlist: Should I update this one, or are these changes from ranking the mirror lists, and I should keep those changes?
  • filesystem: Some of these files looks like they’re expected to be changed from the default (crypttab, fstab, passwd, etc.). Anything I need to do here?
Any other thoughts or recommendations?
I think I’m almost back to normal, thanks so much for the help!
Endeavourosmirrorlist and filesystem are fine. The mirrorlist is supposed to be modified and we modify the filesystem files.
/etc/skel permissions are probably not a big deal.
Awesome, then I think I’ll call this solved!
I still wish I knew what caused the original recurring issue, but I’ll happily accept just having a working computer again!
