Hello everybody,
as EndeavourOS is using a patched version of the arc-darker gtk theme by default, I wonder why there isn’t a similar patch for arc-dark: The light Qogir icons do not work all too well with the dark elements in arc-darker, so I switched to arc-dark. However, this theme still uses the default grey colors for text. Maybe the eos package can be patched to achieve a little more contrast? Then eos could switch to arc-dark by default and the problem regarding low contrast icons in arc-darker would be solved.
Best regards,
Fabian
