I tested to install Endeavor by specifying luks and btrfs. During installation I chose keyboad US and colemak.
Unfortunately, when booting entering the luks passphrase using colemak keyboard layout wasn’t accepted.
Is this a bug?
Is this a bug?
Similar issue:
It’s a known issue so we should certainly hope so.
And welcome to EnOS’ community!
According to the following ArchWiki articles, (1) Unlocking in early userspace and (2) Set persistant keymap, it should be possible to use non-US keymaps for typing encryption passwords at grubs early boot stage.
Disclaimer: I have not gotten this to work on my system myself yet. In case of full disk encryption it may be necessary to generate a core image including the desired keymap for early boot: see here.
From what I’ve gathered you’d have to …
cat /etc/mkinitcpio.conf | grep -v '#' | grep HOOKS
keymap
hook comes before the encrypt
hook andkeyboard
hook comes before the autodetect
hook for external keyboard supportIf not, edit mkinitcpio.conf
and rebuild initramfs
sudo nano /etc/mkinitcpio.conf sudo mkinitcpio -P
localectl set-keymap --no-convert <keymap>
<keymap>
being something like uk
, us
, de
, … (default if empty is us
);list all possible keymaps:
localectl list-keymaps
now, for example: set colemak
as persistant keymak
localectl set-keymap --no-convert colemak
Thanks @2000 . This worked fine for me like follows:
I first changed KEYMAP
to colemak
in /etc/vconsole.conf
, then changed the hook sequence in mkinitcpio.conf
and finally ran sudo mkinitcpio -P
Please mark @2000’s post as “solution” of the topic for it to close and for other users with similar issue to find the solution more easily.
