I am trying to clone my physical installation of Endeavouros into a virtual machine. I thought the task would be relatively simple, but so far I have been unsuccessful.
The reason I want to copy my install to a virtual machine is so that I can try some different configs without risking my physical installation.
Anyway I have tried a couple different ways without success:
1- Over on my windows install, I used terabyte image for windows to image my linux partition. Terabyte has built-in support for virtual disk files. So, when I went to restore the image I’d created, I selected my virtual disk file as the destination to restore my image to. I let the process complete, then started up virtual box, but Endeavouros didn’t boot. I tried booting a live instance of Endeavouros into the virtual machine, and used chroot to reinstall grub, but still, no boot.
2- On windows, I created a virtual disk file with virtualbox. I then mounted the virtual disk file using windows disk management, and assigned a drive letter. I then selected that drive as destination to restore the image file of Endeavouros that I’d created. The restore completed, but again, the system didn’t boot in virtualbox.
I would have though that either of these methods would have resulted in a working virtual machine of Endeavouros.
Can anyone advise me as to how to go about this, so that I can get a working copy of my existing installation of Endeavouros into a virtual machine?
Hi elio -
I made sure to create the virtual hard drive a little larger than the space required for the image restore, so that shouldn’t be an issue
thanks
check UEFI vs. BIOS legacy boot method of the existing system and create the VM accordingly (but it should be possible to change the booting method in VM to your liking)
copy the existing system to the VM
make it boot with arch-chroot
edit /etc/fstab according to what e.g. lsblk -f shows
Well I got it working, apparently I had done the partition backup, and the restore to the virtual disk correctly.
It’s that I had to chroot into the virtual machine from a live session and correct a couple parameters.
Now that I see how it’s done, I can say that it’s a straightforward and fairly easy process.
Would you mind sharing what you needed to change in rder to getting it to work for future reference in case other users will stumble upon the same issue?
I attached the endeavouros iso to the virtual machine and booted it up. Once in a live session I chrooted into the system and reinstalled grub.
Then I re-generated the initramfs image:
from the arch wiki: Re-generate the initramfs image:
Because the hardware has changed, while you are still in the chroot, re-generate the initramfs image and do a proper shutdown:
mkinitcpio -p linux
exit
umount -R /mnt
poweroff
The mkinitcpio -p linux command did a few things which I think included a system file check.
Anyway after that, the system booted normally and is working fine.
I had to go into system settings and manually adjust the screen resolution, to get a fullscreen display in the vm, no big deal.
So far as I can tell, that’s about it, I accomplished my goal
So if I understood correctly, the process starts with creating a Kinuxos blank virtual machine and then plugging the EndeavorOS live cd into it. Then you take the actions you described. Could it all be that simple? This thread is very remarkable, I will follow it. Once upon a time, Windows could be converted into a virtual machine.
