I have two identical Lenovo x230 tablet laptops. One is fully functional with Endeavour-os with a lot of applications and settings. So I cloned the hard disk with Clonezilla and put one into the second laptop.
Everything works as supposed but wifi claims that a wifi adapter is not found.
May it be that the two laptops have a different wifi adapter? I do not know, but what do you suggest to do?
Everybody without words?
yes the two outputs are pretty similar, but may it be possible that the wifi of the non working setup only needs to be somehow activated? Perhaps update or reinstall the wifi adapter?
After all the other functions of the computer work, including tablet Wacom settings, orientation turning etc which are rather complicated.
