I dont find a printer administration for cinnamon - maybe the endeavour-team can insert this...? (I
ve installed this myself - no problem, but for beginners ?)
you need to choose it inside installer… if not there is no printer support (as may one do not need this)
If you want to install printer later simple follow our guide on the wiki, it is simple to understand and takes only a little read and understanding.
Ah, okay - Danke !
There is a program on Arch called system-config-printer
I guess, I’ ve installed this…
