It’s an old wd mycloud, formerly:
sudo mount -t cifs -o rw,guest,vers=3.0,file_mode=0777,dir_mode=0777 //192.168.4.35/steve /media/steve/
worked, now it doesn’t Have downgraded and am back working. Any ideas what has changed?
How “doesn’t” it work anymore? What error message are you getting?
I also just had a Cifs-utils update and my external drive connected to the router is mounted.
mount: bad usage
Try 'mount --help' for more information.
It seems to be related to the word guest
, still reading…
Right:
sudo mount -t cifs -o rw,user=guest,password=,vers=3.0,file_mode=0777,dir_mode=0777 //192.168.4.35/steve /media/steve/
Seems to work, needs user=
and password=
- syntax must of changed.
