Downloaded with torrent.
md5sum -c endeavouros-2019.12.22-x86_64.iso.md5sum
endeavouros-2019.12.22-x86_64.iso: FAILED
gpg --verify endeavouros-2019.12.22-x86_64.iso.sig endeavouros-2019.12.22-x86_64.iso
gpg: Signature made Mon 23 Dec 2019 17:10:52 CET
gpg: using RSA key 497AF50C92AD2384C56E1ACA003DB8B0CB23504F
gpg: issuer “info@endeavouros.com ”
gpg: BAD signature from “EndeavourOS info@endeavouros.com ” [unknown]
unknown --> as you do not have added the key to your ring:
gpg --recv CB23504F
Yes, I did.
gpg --recv CB23504F
gpg: keyserver receive failed: No data
Doesn’'t work, so I did
gpg --keyserver keys.gnupg.net --recv-keys CB23504F
gpg: key 003DB8B0CB23504F: public key “EndeavourOS info@endeavouros.com ” imported
gpg: Total number processed: 1
gpg: imported: 1
yes keyserver have issues at the moment…
just recheck ISO files both are valid fresh downloaded directly and over torrent…
I imported the key before 1st check, and it failed. MD5 too.
Alpix
December 27, 2019, 1:17pm
#6
Just tried both and both were fine.
gpg: WARNUNG: Unsichere Zugriffsrechte des Home-Verzeichnis `/home/lukas/.gnupg'
gpg: Signatur vom Mo 23 Dez 2019 17:10:52 CET
gpg: mittels RSA-Schlüssel 497AF50C92AD2384C56E1ACA003DB8B0CB23504F
gpg: Aussteller "info@endeavouros.com"
gpg: Korrekte Signatur von "EndeavourOS <info@endeavouros.com>" [unbekannt]
gpg: WARNUNG: Dieser Schlüssel trägt keine vertrauenswürdige Signatur!
gpg: Es gibt keinen Hinweis, daß die Signatur wirklich dem vorgeblichen Besitzer gehört.
Haupt-Fingerabdruck = 497A F50C 92AD 2384 C56E 1ACA 003D B8B0 CB23 504F
endeavouros-2019.12.22-x86_64.iso: OK
Where did you donwload the ISO?
Alpix
December 27, 2019, 1:58pm
#8
I downloaded it via the torrent and the checksums were fine again.
I assume there was an error with your download.
I think you should redownload!
