Changed motherboard: Kernel panic!
Hi, I recently upgraded my motherboard and have moved over all my drives. My EndeavourOS is installed on an M.2 drive which I’ve moved over as well.
When booting, I am presented with a Kernel panic with thie last line saying ‘not syncing: VFS: Unable to mount root fs on unknown-block(0,0)’.
I then booted into a live environment via USB which booted normally, and tried these commands after mounting my file systems and arch-chrooting in:
  1. pacman -Syu
  2. mkinitcpio -P
  3. grub-mkconfig -o /boot/grub/grub.cfg
The exact same kernel panic still happens even after these steps. Note that I do NOT see a grub screen of any kind when this happens, despite making the grub config with a timer and not hidden.
What next steps should I try?
It looks like your M.2 drive is not being detected, so it can’t mount the root FileSystem.
Boot up and press F2 or Del to enter your UEFI, and go to the Boot Tab.
Make sure your M.2 is being detected and is the first choice to boot from.
If you haven’t configured your UEFI yet, Make sure CMS is off and secure boot is disabled.
Pudge
I can see the M.2 drive in my BIOS and CSM and Secure boot are both already disabled.
It’s a swing…see if the drive’s UUID has changed (thus making fstab incorrect).
In the live environment I can confirm the fstab on my installation is correct, all the UUIDs match, including the root and EFI partitions.
can you provide from USB live Endeavouros
sudo parted -l
inxi -Fza
You are only giving very few information about your setup.
What is your new motherboard? Does it support booting from M.2 / NVME drives?
Is this UEFI boot or BIOS boot?
What was your old motherboard, by the way?
What is the NVME?
Did you try with a new grub installation?
Chroot to your system, add vmd to MODULES array in /etc/mkinitcpio.conf, run mkinitcpio -P again.
do you compared fstab entries with the real uuids ?
ls -l /dev/disk/by-uuid/
Way too many unknowns. What is the hardware? Are Secure boot and CSM disabled? What are the contents of the fstab. Does it match the real uuid’s. :slightly_frowning_face:
Sorry for the wait, just finished my new years shift at work.
sudo parted -l:
Model: ATA SanDisk SDSSDP12 (scsi)
Disk /dev/sda: 126GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      1049kB  126GB  126GB  primary  ext4
Model: ATA ST2000DM008-2FR1 (scsi)
Disk /dev/sdb: 2000GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
 1      1049kB  1049GB  1049GB  primary  ntfs         boot
 2      1049GB  1579GB  530GB   primary  ext4
 3      1579GB  1960GB  382GB   primary  ext4
 4      1960GB  2000GB  40.0GB  primary  ntfs
Model: ATA WDC WD20EZAZ-00G (scsi)
Disk /dev/sdc: 2000GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name  Flags
 1      1049kB  1100GB  1100GB  ext4
Model: Lexar USB Flash Drive (scsi)
Disk /dev/sdd: 32.0GB
Disk Flags:
 2      1931MB  2041MB  110MB  primary  fat16        esp
Error: /dev/nvme0n1: unrecognised disk label
Model: CT500P3SSD8 (nvme)
Disk /dev/nvme0n1: 500GB
Partition Table: unknown
Disk Flags:
Model: KINGSTON SA2000M8500G (nvme)
Disk /dev/nvme1n1: 500GB
Disk Flags:
 1      1049kB  525MB   524MB   fat32                 msftdata
 2      525MB   9115MB  8590MB  linux-swap(v1)        swap
 3      9115MB  114GB   105GB   ext4
 4      114GB   324GB   210GB   ext4
My root partition is /dev/nvme1n1p4, and EFI partition is /dev/nvme1n1p1. All the other drives are unmounted and are just for data and other crap.
inxi -Fza:
  Kernel: 6.0.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: initrd=\arch\boot\intel-ucode.img
    initrd=\arch\boot\amd-ucode.img
    initrd=\arch\boot\x86_64\initramfs-linux.img archisobasedir=arch
    archisolabel=EOS_202212 cow_spacesize=10G copytoram=n
    module_blacklist=nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm,pcspkr
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 nvme_load=yes
  Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
    v: 4.18.0 vt: 1 dm: LightDM v: 1.32.0 Distro: EndeavourOS base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: Z590 AORUS ELITE AX v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F7
    date: 11/03/2021
  Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 5 microcode: 0xF4
  Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 2725 high: 2900 min/max: 800/4300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2900 2: 2900 3: 2900
    4: 800 5: 2900 6: 2900 7: 2900 8: 2900 9: 2900 10: 2900 11: 2900 12: 2900
    bogomips: 69629
  Vulnerabilities:
  Type: itlb_multihit status: KVM: VMX disabled
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: retbleed mitigation: Enhanced IBRS
    prctl
    sanitization
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
    driver: nouveau v: kernel alternate: nvidia_drm,nvidia non-free: 525.xx+
    status: current (as of 2022-12) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s ports: active: DP-1,DP-2,DP-3
    empty: DVI-D-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
    temp: 27.0 C
  Display: server: X.Org v: 21.1.5 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,nouveau,nv,vesa dri: nouveau
    gpu: nouveau display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
    s-diag: 1550mm (61.04")
  Monitor-1: DP-1 pos: primary,center model: HP 27y serial: <filter>
    built: 2019 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: DP-2 pos: left model: HP 27y serial: <filter> built: 2019
    res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-3: DP-3 pos: right model: HP 27y serial: <filter> built: 2019
  API: OpenGL v: 4.3 Mesa 22.3.1 renderer: NV136 direct render: Yes
  Device-1: Intel vendor: Gigabyte driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f1
    class-ID: 0403
  Sound API: ALSA v: k6.0.12-arch1-1 running: yes
  Sound Server-2: PipeWire v: 0.3.63 running: yes
  Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    modules: wl bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
    chip-ID: 10ec:8125 class-ID: 0200
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
  Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
  Local Storage: total: 4.69 TiB used: 0 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Crucial model: CT500P3SSD8
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: P9CR30A temp: 29.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
    lanes: 4 type: SSD serial: <filter> rev: S5Z42105 temp: 34.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDP128G
    size: 117.38 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: MBR
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: 0A80 scheme: GPT
  ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Lexar
    model: USB Flash Drive size: 29.81 GiB block-size: physical: 512 B
    logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
  ID-1: / raw-size: N/A size: 10 GiB used: 91.4 MiB (0.9%) fs: overlay
    source: ERR-102
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: nouveau temp: 27.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 927
  Processes: 270 Uptime: 8m wakeups: 0 Memory: 31.22 GiB used: 2 GiB (6.4%)
  Init: systemd v: 252 default: multi-user tool: systemctl Compilers:
  gcc: 12.2.0 Packages: pm: pacman pkgs: 890 libs: 216 tools: yay Shell: Bash
  v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
I tried this and the kernel panic is the same.
@joekamprad @ricklinux Yep I checked the UUIDs of the drives and they match what is still in the fstab. I used lsblk -f to check them. Secure boot and CSM are both disabled as I mentioned in my earlier reply, and you can see my current hardware configuration in my other reply.
do you changed from AMD to intel cpu?
Nope the CPU is the same. The only thing I changed was the motherboard, and also added another 16 GB of ram, but everything else is the same.
What is the ram you had in it and what is the ram you added or switched to?
Re-install your bootloader.
I went from 16 GB of mismatched GEIL/TeamGroup sticks (never heard of them tbh) to 32 GB of Corsair Vengeance
The TeamGroup stuff is cheap. You have better ram with Corsair Vengeance. What i would do is shut down and unplug and pull the ram out and then re-seat it just to make sure it’s installed properly. When installing ram push down both ends at the same time until the hold downs snap into place. Do not pull up the hold downs to install it.
There is also another UEFI bios update that you may consider updating at some point. Then if you still have an issue i would suggest as @petsam suggests to arch-chroot and reinstall the bootloader and update grub.
This was the solution - before I only simply tried to update grub but I never thought about reinstalling it. I’m still quite a beginner at linux so these sort of issues and solutions definitely help me better my understanding of how all this stuff works. Thanks!
