Can't use wifi
Okay, be right back xd
Did you actually have the rtw88-dkms-git installed as i read your previous post and it doesn’t really say you had installed it? :thinking:
I did install it when you told me to try to install it.
now it just shows
rtw88_8822be
Okay so what does this show?
iw dev
Nothing still :confused:
What about
rfkill
Everything it shows is unblocked
2 bluetooths (blueteeth?), 1 wlan
Can you run this command and post the link.
sudo dmesg | eos-sendlog
https://clbin.com/FcXdF
I see this
 7.231837] rtw_8822be 0000:07:00.0: mac power on failed
[    7.231849] rtw_8822be 0000:07:00.0: failed to power on mac
[    7.231855] rtw_8822be 0000:07:00.0: failed to setup chip efuse info
[    7.231860] rtw_8822be 0000:07:00.0: failed to setup chip information
[    7.262784] rtw_8822be 0000:07:00.0: Firmware version 27.2.0, H2C version 13
[    7.268115] rtw_8822be: probe of 0000:07:00.0 failed with error -114
That means that the kernel module isnt working?
Can you add a kernel parameter to the default grub command line and then update grub? You can use nano then save the file and update grub? Do you know how?
sudo nano /etc/default/grub
add
rtw88_pci.disable_aspm=1
ctrl + o then enter to save
ctrl + x to exit nano
Then update grub
reboot
It says command not found when I tried to update grub
I had a typo sorry!
/etc/default/grub: line 8: rtw88_pci.disable_aspm=1: command not found
Can i see the file. Post the link
cat /etc/default/grub | eos-sendlog
https://clbin.com/9rc27
You put it in the wrong line so remove it from where you have it and put here. Then update grub again and reboot if it works.
GRUB_CMDLINE_LINUX_DEFAULT="rtw88_pci.disable_aspm=1 loglevel=3 nowatchdog nvme_load=YES"
iw dev doesnt still doesnt show anything.
