Hi, I have just installed Anbox but unfortunately can’t run it, it’s showing starting screen and then closes.
Could you please assist?
from the arch wiki (https://wiki.archlinux.org/title/Anbox) To use anbox-style packages you need two kernel modules: binder
and ashmem
Did you install an apporpriate kernel or the modules from the AUR?
Sorry I have followed the steps, but couldn’t fix it. Could you please provide commands I have to run?
Are you on Wayland or X11?
I think Wayland is still not supported by it and also the project is semi-dead, as I understand.
There’s also a Waydroid, but it’s has an opposite situation and requires Wayland.
Anbox is no longer under development. In the Arch Wiki it states the developers recommend Waydroid
