The NTFS UUIDs in blkid have upper-case letters. The NTFS UUIDs you added to your fstab have lower-case letters. Make your fstab match the blkid output. The UUIDs are case-sensitive.
Fstab file has uuid with lower case letters in them already.
Correct - thatâs what I said. It should be upper-case to match the blkid output.
Files were empty.
It worked. But the lines that were generated by the system in there were using lowercase. So why are these ones case sensitive?
What command did you use to generate the fstab lines?
I didnât. Those lines were already there when I opened it.
You said that:
so how did you add the UUID to the fstab?
I was able to boot into endeavour OS. I edited the file to put in mount points so I wouldnât have to mount them everytime and can simply start using hte programs I use because all my project and other data are on seperate partitions and my OS partitions are seperate.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=4209-BD19 /boot/efi vfat umask=0077 0 2
UUID=7183754b-0e94-4593-a42f-6db39f25bf95 / ext4 defaults,noatime 0 1
UUID=265FD3875D5E6978 /drive/High\040Performance ntfs defaults,noatime 0 2
UUID=94E27932E2791A26 /drive/ENTERTAINMENT ntfs defaults,noatime 0 2
UUID=E6AED571AED53B2F /drive/GAMES ntfs defaults,noatime 0 2
UUID=FC9C75609C7515FC /drive/Random ntfs defaults,noatime 0 2
The first two lines (boot/efi and root) were already there from the start. Fresh setup of Endeavour here.
OK, so you manually added the UUIDs of the four NTFS partitions yourself after installing EnOS.
The first two lines were already correct as genfstab
uses the correct UUIDs for partitions. Note that the vfat partition is upper-case and the ext4 partition is lower-case, but those will match the partitionâs actual UUID.
fstab UUIDs are case-sensitive.
Yes and the root partition has UUID with lowercase letters so I am asking why the other partitions require uppercase letters. Especially since InfoCenter shows the UUID as lowercase.
I edited my post just before you posted:
Yeah, a pro tip for anyone who is lazy like me is to install the arch-install-scripts
package and use genfstab
to avoid getting memed by typos and what have you.
EDIT: Looks like in EOS itâs installed by default. This is what you want to run to generate a new fstab:
genfstab -U /
I gotta figure out how to automate the process of auto mounting all my partitions at boot because I rely on it no matter what distro I use.
ls -la /dev/disk/by-uuid
copy/paste into fstab with the desired mount point.
If you need GUI application for managing the mounting of your devices both KDE Partiton Manager and Disks (gnome-disk-utility) can be useful.
This will mount all disks?
Why? Not FHS compliant? In that case, /data/games
isnât either.
Maybe I wasnât clear, obviously you do not mount directly on /mnt
but on subdirectories therein.
/media
is for external devices normally, mostly manually mounted CD/DVD or even USB disks or sticks. But systemd/udev is taking care of these and puts them into /run/...
EDIT: youâre right, /mnt should be for temporary mounts. However, I donât think that there is any problem mounting device X to /mnt/X or device Y to /mnt/Y. Problematic is direct mounting to /mnt. My VBoxes reside in /mnt/vbox for example.
No. I was just saying thatâd give you the UUIDs for your disks so you can easily copy/paste it into fstab and then supply it with the mount point.
Oh I usually just use inxi or lsblk or lspci to get the uuids
