Hey both of you,
So I ran the command to extract the old log and it is indeed interesting. It is quiet long, so I can’t post the complete thing from the first command. This is anyhow the second one
cat /var/log/Xorg.0.log.old
[ 11.737]
X.Org X Server 1.21.1.6
X Protocol Version 11, Revision 0
[ 11.737] Current Operating System: Linux nlea-xps9320 6.1.8-arch1-1 #1 SMP PREEMPT_DYNAMIC Tue, 24 Jan 2023 21:07:04 +0000 x86_64
[ 11.737] Kernel command line: initrd=\e8c3f90ce578424fabfab4a08346f992\6.1.8-arch1-1\initrd nvme_load=YES rw root=UUID=95513f4d-5dd3-41f4-9619-2e1ed76a6411 systemd.machine_id=e8c3f90ce578424fabfab4a08346f992
[ 11.737]
[ 11.737] Current version of pixman: 0.42.2
[ 11.737] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 11.737] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 11.737] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Feb 1 09:35:11 2023
[ 11.737] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 11.737] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.738] (==) No Layout section. Using the first Screen section.
[ 11.738] (==) No screen section available. Using defaults.
[ 11.738] (**) |-->Screen "Default Screen Section" (0)
[ 11.738] (**) | |-->Monitor "<default monitor>"
[ 11.738] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 11.738] (==) Automatically adding devices
[ 11.738] (==) Automatically enabling devices
[ 11.738] (==) Automatically adding GPU devices
[ 11.738] (==) Automatically binding GPU devices
[ 11.738] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.738] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 11.738] Entry deleted from font path.
[ 11.738] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 11.738] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 11.738] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 11.738] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 11.738] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 11.738] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 11.738] (==) FontPath set to:
[ 11.738] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 11.738] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 11.738] (II) Module ABI versions:
[ 11.738] X.Org ANSI C Emulation: 0.4
[ 11.738] X.Org Video Driver: 25.2
[ 11.738] X.Org XInput driver : 24.4
[ 11.738] X.Org Server Extension : 10.0
[ 11.738] (++) using VT number 7
[ 11.738] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.739] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.739] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 11.747] (--) PCI:*(0@0:2:0) 8086:46a6:1028:0af3 rev 12, Mem @ 0x603d000000/16777216, 0x4000000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 11.747] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 11.747] (II) LoadModule: "glx"
[ 11.747] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.750] (II) Module glx: vendor="X.Org Foundation"
[ 11.750] compiled for 1.21.1.6, module version = 1.0.0
[ 11.750] ABI class: X.Org Server Extension, version 10.0
[ 11.750] (==) Matched intel as autoconfigured driver 0
[ 11.750] (==) Matched modesetting as autoconfigured driver 1
[ 11.750] (==) Matched fbdev as autoconfigured driver 2
[ 11.750] (==) Matched vesa as autoconfigured driver 3
[ 11.750] (==) Assigned the driver to the xf86ConfigLayout
[ 11.750] (II) LoadModule: "intel"
[ 11.750] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 11.751] (II) Module intel: vendor="X.Org Foundation"
[ 11.751] compiled for 1.21.1.1, module version = 2.99.917
[ 11.751] Module class: X.Org Video Driver
[ 11.751] ABI class: X.Org Video Driver, version 25.2
[ 11.751] (II) LoadModule: "modesetting"
[ 11.751] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 11.752] (II) Module modesetting: vendor="X.Org Foundation"
[ 11.752] compiled for 1.21.1.6, module version = 1.21.1
[ 11.752] Module class: X.Org Video Driver
[ 11.752] ABI class: X.Org Video Driver, version 25.2
[ 11.752] (II) LoadModule: "fbdev"
[ 11.752] (WW) Warning, couldn't open module fbdev
[ 11.752] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 11.752] (II) LoadModule: "vesa"
[ 11.752] (WW) Warning, couldn't open module vesa
[ 11.752] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 11.752] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 11.752] (II) intel: Driver for Intel(R) HD Graphics
[ 11.752] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 11.752] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 11.752] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 11.769] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20201103
[ 11.769] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[ 11.769] (WW) Falling back to old probe method for modesetting
[ 11.770] (WW) intel(0): Unknown chipset
[ 11.770] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 12 threads
[ 11.770] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 11.770] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 11.770] (==) intel(0): RGB weight 888
[ 11.770] (==) intel(0): Default visual is TrueColor
[ 11.770] (II) intel(0): Output eDP1 has no monitor section
[ 11.770] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 11.770] (II) intel(0): Enabled output eDP1
[ 11.770] (II) intel(0): Output DP1 has no monitor section
[ 11.770] (II) intel(0): Enabled output DP1
[ 11.770] (II) intel(0): Output DP2 has no monitor section
[ 11.770] (II) intel(0): Enabled output DP2
[ 11.770] (II) intel(0): Output DP3 has no monitor section
[ 11.770] (II) intel(0): Enabled output DP3
[ 11.770] (II) intel(0): Output DP4 has no monitor section
[ 11.770] (II) intel(0): Enabled output DP4
[ 11.770] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 11.770] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 11.770] (II) intel(0): Enabled output VIRTUAL1
[ 11.771] (--) intel(0): Output eDP1 using initial mode 3840x2400 on pipe 0
[ 11.771] (--) intel(0): Output DP1 using initial mode 3840x2160 on pipe 1
[ 11.771] (==) intel(0): TearFree enabled
[ 11.771] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.771] (==) intel(0): DPI set to (96, 96)
[ 11.771] (II) Loading sub module "dri3"
[ 11.771] (II) LoadModule: "dri3"
[ 11.771] (II) Module "dri3" already built-in
[ 11.771] (II) Loading sub module "dri2"
[ 11.771] (II) LoadModule: "dri2"
[ 11.771] (II) Module "dri2" already built-in
[ 11.771] (II) Loading sub module "present"
[ 11.771] (II) LoadModule: "present"
[ 11.771] (II) Module "present" already built-in
[ 11.771] (II) UnloadModule: "modesetting"
[ 11.771] (II) Unloading modesetting
[ 11.771] (II) intel(0): SNA initialized with generic backend
[ 11.771] (==) intel(0): Backing store enabled
[ 11.771] (==) intel(0): Silken mouse enabled
[ 11.771] (II) intel(0): HW Cursor enabled
[ 11.771] (==) intel(0): DPMS enabled
[ 11.771] (==) intel(0): Display hotplug detection enabled
[ 11.771] (II) intel(0): Textured video not supported on this hardware or backend
[ 11.772] (II) intel(0): [DRI2] Setup complete
[ 11.772] (II) intel(0): [DRI2] DRI driver: i965
[ 11.772] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 11.772] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 11.772] (II) intel(0): hardware support for Present enabled
[ 11.772] (II) Initializing extension Generic Event Extension
[ 11.772] (II) Initializing extension SHAPE
[ 11.772] (II) Initializing extension MIT-SHM
[ 11.772] (II) Initializing extension XInputExtension
[ 11.772] (II) Initializing extension XTEST
[ 11.772] (II) Initializing extension BIG-REQUESTS
[ 11.772] (II) Initializing extension SYNC
[ 11.772] (II) Initializing extension XKEYBOARD
[ 11.772] (II) Initializing extension XC-MISC
[ 11.772] (II) Initializing extension SECURITY
[ 11.772] (II) Initializing extension XFIXES
[ 11.772] (II) Initializing extension RENDER
[ 11.772] (II) Initializing extension RANDR
[ 11.772] (II) Initializing extension COMPOSITE
[ 11.772] (II) Initializing extension DAMAGE
[ 11.772] (II) Initializing extension MIT-SCREEN-SAVER
[ 11.773] (II) Initializing extension DOUBLE-BUFFER
[ 11.773] (II) Initializing extension RECORD
[ 11.773] (II) Initializing extension DPMS
[ 11.773] (II) Initializing extension Present
[ 11.773] (II) Initializing extension DRI3
[ 11.773] (II) Initializing extension X-Resource
[ 11.773] (II) Initializing extension XVideo
[ 11.773] (II) Initializing extension XVideo-MotionCompensation
[ 11.773] (II) Initializing extension GLX
[ 11.773] (EE) AIGLX error: dlopen of /usr/lib/dri/i965_dri.so failed (/usr/lib/dri/i965_dri.so: cannot open shared object file: No such file or directory)
[ 11.773] (EE) AIGLX error: unable to load driver i965
[ 11.830] (II) IGLX: Loaded and initialized swrast
[ 11.830] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 11.830] (II) Initializing extension XFree86-VidModeExtension
[ 11.830] (II) Initializing extension XFree86-DGA
[ 11.830] (II) Initializing extension XFree86-DRI
[ 11.830] (II) Initializing extension DRI2
[ 11.837] (EE) intel(0): Failed to submit rendering commands (Invalid argument), disabling acceleration.
[ 11.837] (II) intel(0): switch to mode 3840x2400@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 11.846] (II) intel(0): switch to mode 3840x2160@60.0 on DP1 using pipe 1, position (0, 0), rotation normal, reflection none
[ 11.863] (II) intel(0): Setting screen physical size to 1016 x 635
[ 11.898] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 11.898] (**) Video Bus: Applying InputClass "devname"
[ 11.898] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 11.898] (**) Video Bus: Applying InputClass "system-keyboard"
[ 11.898] (II) LoadModule: "libinput"
[ 11.898] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 11.900] (II) Module libinput: vendor="X.Org Foundation"
[ 11.900] compiled for 1.21.1.3, module version = 1.2.1
[ 11.900] Module class: X.Org XInput Driver
[ 11.900] ABI class: X.Org XInput driver, version 24.4
[ 11.900] (II) Using input driver 'libinput' for 'Video Bus'
[ 11.900] (**) Video Bus: always reports core events
[ 11.900] (**) Option "Device" "/dev/input/event13"
[ 11.901] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 11.901] (II) event13 - Video Bus: device is a keyboard
[ 11.901] (II) event13 - Video Bus: device removed
[ 11.987] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input20/event13"
[ 11.987] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 11.987] (**) Option "xkb_layout" "us"
[ 11.987] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 11.987] (II) event13 - Video Bus: device is a keyboard
[ 11.987] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 11.987] (**) Power Button: Applying InputClass "devname"
[ 11.987] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 11.987] (**) Power Button: Applying InputClass "system-keyboard"
[ 11.987] (II) Using input driver 'libinput' for 'Power Button'
[ 11.987] (**) Power Button: always reports core events
[ 11.987] (**) Option "Device" "/dev/input/event1"
[ 11.988] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 11.988] (II) event1 - Power Button: device is a keyboard
[ 11.988] (II) event1 - Power Button: device removed
[ 12.040] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 12.040] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 12.040] (**) Option "xkb_layout" "us"
[ 12.044] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 12.044] (II) event1 - Power Button: device is a keyboard
[ 12.044] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 12.044] (**) Lid Switch: Applying InputClass "devname"
[ 12.044] (II) Using input driver 'libinput' for 'Lid Switch'
[ 12.044] (**) Lid Switch: always reports core events
[ 12.044] (**) Option "Device" "/dev/input/event0"
[ 12.044] (II) event0 - Lid Switch: is tagged by udev as: Switch
[ 12.044] (II) event0 - Lid Switch: device is a switch device
[ 12.045] (II) event0 - Lid Switch: device removed
[ 12.064] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0/event0"
[ 12.064] (II) XINPUT: Adding extended input device "Lid Switch" (type: KEYBOARD, id 8)
[ 12.064] (II) event0 - Lid Switch: is tagged by udev as: Switch
[ 12.064] (II) event0 - Lid Switch: device is a switch device
[ 12.064] (II) config/udev: Adding input device Logitech G403 HERO Gaming Mouse (/dev/input/event3)
[ 12.064] (**) Logitech G403 HERO Gaming Mouse: Applying InputClass "devname"
[ 12.064] (**) Logitech G403 HERO Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 12.064] (II) Using input driver 'libinput' for 'Logitech G403 HERO Gaming Mouse'
[ 12.064] (**) Logitech G403 HERO Gaming Mouse: always reports core events
[ 12.064] (**) Option "Device" "/dev/input/event3"
[ 12.125] (II) event3 - Logitech G403 HERO Gaming Mouse: is tagged by udev as: Mouse
[ 12.125] (II) event3 - Logitech G403 HERO Gaming Mouse: device set to 800 DPI
[ 12.125] (II) event3 - Logitech G403 HERO Gaming Mouse: device is a pointer
[ 12.125] (II) event3 - Logitech G403 HERO Gaming Mouse: device removed
[ 12.207] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.3/3-1.3:1.0/0003:046D:C08F.0003/input/input4/event3"
[ 12.207] (II) XINPUT: Adding extended input device "Logitech G403 HERO Gaming Mouse" (type: MOUSE, id 9)
[ 12.207] (**) Option "AccelerationScheme" "none"
[ 12.207] (**) Logitech G403 HERO Gaming Mouse: (accel) selected scheme none/0
[ 12.207] (**) Logitech G403 HERO Gaming Mouse: (accel) acceleration factor: 2.000
[ 12.207] (**) Logitech G403 HERO Gaming Mouse: (accel) acceleration threshold: 4
[ 12.267] (II) event3 - Logitech G403 HERO Gaming Mouse: is tagged by udev as: Mouse
[ 12.267] (II) event3 - Logitech G403 HERO Gaming Mouse: device set to 800 DPI
[ 12.267] (II) event3 - Logitech G403 HERO Gaming Mouse: device is a pointer
[ 12.269] (II) config/udev: Adding input device Logitech G403 HERO Gaming Mouse (/dev/input/mouse0)
[ 12.269] (**) Logitech G403 HERO Gaming Mouse: Applying InputClass "devname"
[ 12.269] (II) Using input driver 'libinput' for 'Logitech G403 HERO Gaming Mouse'
[ 12.269] (**) Logitech G403 HERO Gaming Mouse: always reports core events
[ 12.269] (**) Option "Device" "/dev/input/mouse0"
[ 12.334] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 12.334] (EE) libinput: Logitech G403 HERO Gaming Mouse: Failed to create a device for /dev/input/mouse0
[ 12.334] (EE) PreInit returned 2 for "Logitech G403 HERO Gaming Mouse"
[ 12.334] (II) UnloadModule: "libinput"
[ 12.336] (II) config/udev: Adding input device Logitech G403 HERO Gaming Mouse Keyboard (/dev/input/event4)
[ 12.336] (**) Logitech G403 HERO Gaming Mouse Keyboard: Applying InputClass "devname"
[ 12.336] (**) Logitech G403 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 12.336] (**) Logitech G403 HERO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 12.336] (II) Using input driver 'libinput' for 'Logitech G403 HERO Gaming Mouse Keyboard'
[ 12.336] (**) Logitech G403 HERO Gaming Mouse Keyboard: always reports core events
[ 12.336] (**) Option "Device" "/dev/input/event4"
[ 12.339] (II) event4 - Logitech G403 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 12.339] (II) event4 - Logitech G403 HERO Gaming Mouse Keyboard: device is a keyboard
[ 12.339] (II) event4 - Logitech G403 HERO Gaming Mouse Keyboard: device removed
[ 12.404] (II) libinput: Logitech G403 HERO Gaming Mouse Keyboard: needs a virtual subdevice
[ 12.404] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:046D:C08F.0004/input/input5/event4"
[ 12.404] (II) XINPUT: Adding extended input device "Logitech G403 HERO Gaming Mouse Keyboard" (type: MOUSE, id 10)
[ 12.404] (**) Option "AccelerationScheme" "none"
[ 12.404] (**) Logitech G403 HERO Gaming Mouse Keyboard: (accel) selected scheme none/0
[ 12.404] (**) Logitech G403 HERO Gaming Mouse Keyboard: (accel) acceleration factor: 2.000
[ 12.404] (**) Logitech G403 HERO Gaming Mouse Keyboard: (accel) acceleration threshold: 4
[ 12.406] (II) event4 - Logitech G403 HERO Gaming Mouse Keyboard: is tagged by udev as: Keyboard
[ 12.406] (II) event4 - Logitech G403 HERO Gaming Mouse Keyboard: device is a keyboard
[ 12.407] (II) config/udev: Adding input device Apple Inc. Magic Keyboard with Numeric Keypad (/dev/input/event6)
[ 12.407] (**) Apple Inc. Magic Keyboard with Numeric Keypad: Applying InputClass "devname"
[ 12.407] (II) Using input driver 'libinput' for 'Apple Inc. Magic Keyboard with Numeric Keypad'
[ 12.407] (**) Apple Inc. Magic Keyboard with Numeric Keypad: always reports core events
[ 12.407] (**) Option "Device" "/dev/input/event6"
[ 12.467] (II) event6 - Apple Inc. Magic Keyboard with Numeric Keypad: not tagged as supported input device
[ 12.524] (II) event6 - not using input device '/dev/input/event6'.
[ 12.524] (EE) libinput: Apple Inc. Magic Keyboard with Numeric Keypad: Failed to create a device for /dev/input/event6
[ 12.524] (EE) PreInit returned 2 for "Apple Inc. Magic Keyboard with Numeric Keypad"
[ 12.524] (II) UnloadModule: "libinput"
[ 12.526] (II) config/udev: Adding input device Apple Inc. Magic Keyboard with Numeric Keypad (/dev/input/event5)
[ 12.526] (**) Apple Inc. Magic Keyboard with Numeric Keypad: Applying InputClass "devname"
[ 12.526] (**) Apple Inc. Magic Keyboard with Numeric Keypad: Applying InputClass "libinput keyboard catchall"
[ 12.526] (**) Apple Inc. Magic Keyboard with Numeric Keypad: Applying InputClass "system-keyboard"
[ 12.526] (II) Using input driver 'libinput' for 'Apple Inc. Magic Keyboard with Numeric Keypad'
[ 12.526] (**) Apple Inc. Magic Keyboard with Numeric Keypad: always reports core events
[ 12.526] (**) Option "Device" "/dev/input/event5"
[ 12.528] (II) event5 - Apple Inc. Magic Keyboard with Numeric Keypad: is tagged by udev as: Keyboard
[ 12.528] (II) event5 - Apple Inc. Magic Keyboard with Numeric Keypad: device is a keyboard
[ 12.529] (II) event5 - Apple Inc. Magic Keyboard with Numeric Keypad: device removed
[ 12.564] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.4/3-1.4:1.1/0003:05AC:026C.0006/input/input11/event5"
[ 12.564] (II) XINPUT: Adding extended input device "Apple Inc. Magic Keyboard with Numeric Keypad" (type: KEYBOARD, id 11)
[ 12.564] (**) Option "xkb_layout" "us"
[ 12.567] (II) event5 - Apple Inc. Magic Keyboard with Numeric Keypad: is tagged by udev as: Keyboard
[ 12.567] (II) event5 - Apple Inc. Magic Keyboard with Numeric Keypad: device is a keyboard
[ 12.569] (II) config/udev: Adding input device LXT2021:00 29BD:3303 (/dev/input/event12)
[ 12.569] (**) LXT2021:00 29BD:3303: Applying InputClass "devname"
[ 12.569] (**) LXT2021:00 29BD:3303: Applying InputClass "libinput touchscreen catchall"
[ 12.569] (II) Using input driver 'libinput' for 'LXT2021:00 29BD:3303'
[ 12.569] (**) LXT2021:00 29BD:3303: always reports core events
[ 12.569] (**) Option "Device" "/dev/input/event12"
[ 12.570] (II) event12 - LXT2021:00 29BD:3303: is tagged by udev as: Touchscreen
[ 12.570] (II) event12 - LXT2021:00 29BD:3303: device is a touch device
[ 12.571] (II) event12 - LXT2021:00 29BD:3303: device removed
[ 12.620] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-9/i2c-LXT2021:00/0018:29BD:3303.0009/input/input29/event12"
[ 12.620] (II) XINPUT: Adding extended input device "LXT2021:00 29BD:3303" (type: TOUCHSCREEN, id 12)
[ 12.621] (**) Option "AccelerationScheme" "none"
[ 12.621] (**) LXT2021:00 29BD:3303: (accel) selected scheme none/0
[ 12.621] (**) LXT2021:00 29BD:3303: (accel) acceleration factor: 2.000
[ 12.621] (**) LXT2021:00 29BD:3303: (accel) acceleration threshold: 4
[ 12.623] (II) event12 - LXT2021:00 29BD:3303: is tagged by udev as: Touchscreen
[ 12.624] (II) event12 - LXT2021:00 29BD:3303: device is a touch device
[ 12.625] (II) config/udev: Adding input device LXT2021:00 29BD:3303 (/dev/input/mouse3)
[ 12.625] (**) LXT2021:00 29BD:3303: Applying InputClass "devname"
[ 12.625] (II) Using input driver 'libinput' for 'LXT2021:00 29BD:3303'
[ 12.625] (**) LXT2021:00 29BD:3303: always reports core events
[ 12.625] (**) Option "Device" "/dev/input/mouse3"
[ 12.680] (II) mouse3 - not using input device '/dev/input/mouse3'.
[ 12.680] (EE) libinput: LXT2021:00 29BD:3303: Failed to create a device for /dev/input/mouse3
[ 12.680] (EE) PreInit returned 2 for "LXT2021:00 29BD:3303"
[ 12.680] (II) UnloadModule: "libinput"
[ 12.682] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Mouse (/dev/input/event9)
[ 12.682] (**) VEN_04F3:00 04F3:31D1 Mouse: Applying InputClass "devname"
[ 12.682] (**) VEN_04F3:00 04F3:31D1 Mouse: Applying InputClass "libinput pointer catchall"
[ 12.682] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Mouse'
[ 12.682] (**) VEN_04F3:00 04F3:31D1 Mouse: always reports core events
[ 12.682] (**) Option "Device" "/dev/input/event9"
[ 12.685] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: is tagged by udev as: Mouse Pointingstick
[ 12.685] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device is a pointer
[ 12.686] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device removed
[ 12.737] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-10/i2c-VEN_04F3:00/0018:04F3:31D1.0008/input/input25/event9"
[ 12.737] (II) XINPUT: Adding extended input device "VEN_04F3:00 04F3:31D1 Mouse" (type: MOUSE, id 13)
[ 12.738] (**) Option "AccelerationScheme" "none"
[ 12.738] (**) VEN_04F3:00 04F3:31D1 Mouse: (accel) selected scheme none/0
[ 12.738] (**) VEN_04F3:00 04F3:31D1 Mouse: (accel) acceleration factor: 2.000
[ 12.738] (**) VEN_04F3:00 04F3:31D1 Mouse: (accel) acceleration threshold: 4
[ 12.740] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: is tagged by udev as: Mouse Pointingstick
[ 12.741] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device is a pointer
[ 12.743] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Mouse (/dev/input/mouse1)
[ 12.743] (**) VEN_04F3:00 04F3:31D1 Mouse: Applying InputClass "devname"
[ 12.743] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Mouse'
[ 12.743] (**) VEN_04F3:00 04F3:31D1 Mouse: always reports core events
[ 12.743] (**) Option "Device" "/dev/input/mouse1"
[ 12.787] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 12.787] (EE) libinput: VEN_04F3:00 04F3:31D1 Mouse: Failed to create a device for /dev/input/mouse1
[ 12.787] (EE) PreInit returned 2 for "VEN_04F3:00 04F3:31D1 Mouse"
[ 12.787] (II) UnloadModule: "libinput"
[ 12.788] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Touchpad (/dev/input/event10)
[ 12.788] (**) VEN_04F3:00 04F3:31D1 Touchpad: Applying InputClass "devname"
[ 12.788] (**) VEN_04F3:00 04F3:31D1 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 12.788] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Touchpad'
[ 12.788] (**) VEN_04F3:00 04F3:31D1 Touchpad: always reports core events
[ 12.788] (**) Option "Device" "/dev/input/event10"
[ 12.790] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: is tagged by udev as: Touchpad
[ 12.793] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device is a touchpad
[ 12.793] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device removed
[ 12.837] (**) Option "Tapping" "on"
[ 12.838] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-10/i2c-VEN_04F3:00/0018:04F3:31D1.0008/input/input26/event10"
[ 12.838] (II) XINPUT: Adding extended input device "VEN_04F3:00 04F3:31D1 Touchpad" (type: TOUCHPAD, id 14)
[ 12.841] (**) Option "AccelerationScheme" "none"
[ 12.841] (**) VEN_04F3:00 04F3:31D1 Touchpad: (accel) selected scheme none/0
[ 12.841] (**) VEN_04F3:00 04F3:31D1 Touchpad: (accel) acceleration factor: 2.000
[ 12.841] (**) VEN_04F3:00 04F3:31D1 Touchpad: (accel) acceleration threshold: 4
[ 12.842] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: is tagged by udev as: Touchpad
[ 12.843] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device is a touchpad
[ 12.843] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Touchpad (/dev/input/mouse2)
[ 12.843] (**) VEN_04F3:00 04F3:31D1 Touchpad: Applying InputClass "devname"
[ 12.843] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Touchpad'
[ 12.843] (**) VEN_04F3:00 04F3:31D1 Touchpad: always reports core events
[ 12.843] (**) Option "Device" "/dev/input/mouse2"
[ 12.890] (II) mouse2 - not using input device '/dev/input/mouse2'.
[ 12.891] (EE) libinput: VEN_04F3:00 04F3:31D1 Touchpad: Failed to create a device for /dev/input/mouse2
[ 12.891] (EE) PreInit returned 2 for "VEN_04F3:00 04F3:31D1 Touchpad"
[ 12.891] (II) UnloadModule: "libinput"
[ 12.892] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 UNKNOWN (/dev/input/event11)
[ 12.892] (**) VEN_04F3:00 04F3:31D1 UNKNOWN: Applying InputClass "devname"
[ 12.893] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 UNKNOWN'
[ 12.893] (**) VEN_04F3:00 04F3:31D1 UNKNOWN: always reports core events
[ 12.893] (**) Option "Device" "/dev/input/event11"
[ 12.895] (II) event11 - VEN_04F3:00 04F3:31D1 UNKNOWN: not tagged as supported input device
[ 12.937] (II) event11 - not using input device '/dev/input/event11'.
[ 12.937] (EE) libinput: VEN_04F3:00 04F3:31D1 UNKNOWN: Failed to create a device for /dev/input/event11
[ 12.937] (EE) PreInit returned 2 for "VEN_04F3:00 04F3:31D1 UNKNOWN"
[ 12.937] (II) UnloadModule: "libinput"
[ 12.939] (II) config/udev: Adding input device Intel HID events (/dev/input/event7)
[ 12.940] (**) Intel HID events: Applying InputClass "devname"
[ 12.940] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 12.940] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 12.940] (II) Using input driver 'libinput' for 'Intel HID events'
[ 12.940] (**) Intel HID events: always reports core events
[ 12.940] (**) Option "Device" "/dev/input/event7"
[ 12.942] (II) event7 - Intel HID events: is tagged by udev as: Keyboard
[ 12.942] (II) event7 - Intel HID events: device is a keyboard
[ 12.942] (II) event7 - Intel HID events: device removed
[ 12.957] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input12/event7"
[ 12.957] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 15)
[ 12.957] (**) Option "xkb_layout" "us"
[ 12.959] (II) event7 - Intel HID events: is tagged by udev as: Keyboard
[ 12.959] (II) event7 - Intel HID events: device is a keyboard
[ 12.961] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event8)
[ 12.961] (**) Intel HID 5 button array: Applying InputClass "devname"
[ 12.961] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 12.961] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 12.961] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 12.961] (**) Intel HID 5 button array: always reports core events
[ 12.961] (**) Option "Device" "/dev/input/event8"
[ 12.962] (II) event8 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 12.962] (II) event8 - Intel HID 5 button array: device is a keyboard
[ 12.962] (II) event8 - Intel HID 5 button array: device removed
[ 13.000] (**) Option "config_info" "udev:/sys/devices/platform/INTC1070:00/input/input13/event8"
[ 13.000] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 16)
[ 13.000] (**) Option "xkb_layout" "us"
[ 13.003] (II) event8 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 13.003] (II) event8 - Intel HID 5 button array: device is a keyboard
[ 13.004] (II) config/udev: Adding input device Dell Privacy Driver (/dev/input/event14)
[ 13.004] (**) Dell Privacy Driver: Applying InputClass "devname"
[ 13.004] (**) Dell Privacy Driver: Applying InputClass "libinput keyboard catchall"
[ 13.004] (**) Dell Privacy Driver: Applying InputClass "system-keyboard"
[ 13.004] (II) Using input driver 'libinput' for 'Dell Privacy Driver'
[ 13.004] (**) Dell Privacy Driver: always reports core events
[ 13.004] (**) Option "Device" "/dev/input/event14"
[ 13.005] (II) event14 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 13.006] (II) event14 - Dell Privacy Driver: device is a keyboard
[ 13.006] (II) event14 - Dell Privacy Driver: device removed
[ 13.040] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/6932965F-1671-4CEB-B988-D3AB0A901919/input/input21/event14"
[ 13.040] (II) XINPUT: Adding extended input device "Dell Privacy Driver" (type: KEYBOARD, id 17)
[ 13.040] (**) Option "xkb_layout" "us"
[ 13.044] (II) event14 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 13.044] (II) event14 - Dell Privacy Driver: device is a keyboard
[ 13.046] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event15)
[ 13.046] (**) Dell WMI hotkeys: Applying InputClass "devname"
[ 13.046] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 13.046] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 13.046] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 13.046] (**) Dell WMI hotkeys: always reports core events
[ 13.046] (**) Option "Device" "/dev/input/event15"
[ 13.046] (II) event15 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 13.046] (II) event15 - Dell WMI hotkeys: device is a keyboard
[ 13.046] (II) event15 - Dell WMI hotkeys: device removed
[ 13.117] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input22/event15"
[ 13.117] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 18)
[ 13.117] (**) Option "xkb_layout" "us"
[ 13.121] (II) event15 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 13.121] (II) event15 - Dell WMI hotkeys: device is a keyboard
[ 13.123] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 13.123] (**) AT Translated Set 2 keyboard: Applying InputClass "devname"
[ 13.123] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.123] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 13.123] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 13.123] (**) AT Translated Set 2 keyboard: always reports core events
[ 13.123] (**) Option "Device" "/dev/input/event2"
[ 13.125] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 13.125] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 13.127] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 13.170] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input2/event2"
[ 13.170] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 19)
[ 13.170] (**) Option "xkb_layout" "us"
[ 13.174] (II) event2 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 13.174] (II) event2 - AT Translated Set 2 keyboard: device is a keyboard
[ 13.178] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event17)
[ 13.178] (**) PS/2 Generic Mouse: Applying InputClass "devname"
[ 13.178] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[ 13.178] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 13.178] (**) PS/2 Generic Mouse: always reports core events
[ 13.178] (**) Option "Device" "/dev/input/event17"
[ 13.179] (II) event17 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 13.180] (II) event17 - PS/2 Generic Mouse: device is a pointer
[ 13.180] (II) event17 - PS/2 Generic Mouse: device removed
[ 13.230] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input24/event17"
[ 13.230] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 20)
[ 13.231] (**) Option "AccelerationScheme" "none"
[ 13.231] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[ 13.231] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[ 13.231] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[ 13.232] (II) event17 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 13.233] (II) event17 - PS/2 Generic Mouse: device is a pointer
[ 13.234] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse4)
[ 13.234] (**) PS/2 Generic Mouse: Applying InputClass "devname"
[ 13.234] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 13.234] (**) PS/2 Generic Mouse: always reports core events
[ 13.234] (**) Option "Device" "/dev/input/mouse4"
[ 13.287] (II) mouse4 - not using input device '/dev/input/mouse4'.
[ 13.287] (EE) libinput: PS/2 Generic Mouse: Failed to create a device for /dev/input/mouse4
[ 13.287] (EE) PreInit returned 2 for "PS/2 Generic Mouse"
[ 13.287] (II) UnloadModule: "libinput"
[ 13.289] (II) config/udev: Adding input device PC Speaker (/dev/input/event16)
[ 13.289] (**) PC Speaker: Applying InputClass "devname"
[ 13.289] (II) Using input driver 'libinput' for 'PC Speaker'
[ 13.289] (**) PC Speaker: always reports core events
[ 13.289] (**) Option "Device" "/dev/input/event16"
[ 13.291] (II) event16 - PC Speaker: not tagged as supported input device
[ 13.340] (II) event16 - not using input device '/dev/input/event16'.
[ 13.340] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event16
[ 13.340] (EE) PreInit returned 2 for "PC Speaker"
[ 13.340] (II) UnloadModule: "libinput"
[ 13.380] (**) Logitech G403 HERO Gaming Mouse Keyboard: Applying InputClass "devname"
[ 13.380] (**) Logitech G403 HERO Gaming Mouse Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.380] (**) Logitech G403 HERO Gaming Mouse Keyboard: Applying InputClass "system-keyboard"
[ 13.380] (II) Using input driver 'libinput' for 'Logitech G403 HERO Gaming Mouse Keyboard'
[ 13.380] (**) Logitech G403 HERO Gaming Mouse Keyboard: always reports core events
[ 13.380] (**) Option "Device" "/dev/input/event4"
[ 13.380] (II) libinput: Logitech G403 HERO Gaming Mouse Keyboard: is a virtual subdevice
[ 13.380] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:046D:C08F.0004/input/input5/event4"
[ 13.380] (II) XINPUT: Adding extended input device "Logitech G403 HERO Gaming Mouse Keyboard" (type: KEYBOARD, id 21)
[ 13.380] (**) Option "xkb_layout" "us"
[ 13.382] (II) config/udev: removing device Video Bus
[ 13.382] (II) event13 - Video Bus: device removed
[ 13.420] (II) UnloadModule: "libinput"
[ 13.421] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 13.421] (**) Video Bus: Applying InputClass "devname"
[ 13.421] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 13.421] (**) Video Bus: Applying InputClass "system-keyboard"
[ 13.421] (II) Using input driver 'libinput' for 'Video Bus'
[ 13.421] (**) Video Bus: always reports core events
[ 13.421] (**) Option "Device" "/dev/input/event13"
[ 13.422] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 13.422] (II) event13 - Video Bus: device is a keyboard
[ 13.422] (II) event13 - Video Bus: device removed
[ 13.487] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input20/event13"
[ 13.487] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 6)
[ 13.487] (**) Option "xkb_layout" "us"
[ 13.489] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 13.489] (II) event13 - Video Bus: device is a keyboard
[ 13.489] (II) config/udev: removing device Dell Privacy Driver
[ 13.490] (II) event14 - Dell Privacy Driver: device removed
[ 13.540] (II) UnloadModule: "libinput"
[ 13.541] (II) config/udev: Adding input device Dell Privacy Driver (/dev/input/event14)
[ 13.542] (**) Dell Privacy Driver: Applying InputClass "devname"
[ 13.542] (**) Dell Privacy Driver: Applying InputClass "libinput keyboard catchall"
[ 13.542] (**) Dell Privacy Driver: Applying InputClass "system-keyboard"
[ 13.542] (II) Using input driver 'libinput' for 'Dell Privacy Driver'
[ 13.542] (**) Dell Privacy Driver: always reports core events
[ 13.542] (**) Option "Device" "/dev/input/event14"
[ 13.544] (II) event14 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 13.544] (II) event14 - Dell Privacy Driver: device is a keyboard
[ 13.544] (II) event14 - Dell Privacy Driver: device removed
[ 13.647] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/6932965F-1671-4CEB-B988-D3AB0A901919/input/input21/event14"
[ 13.647] (II) XINPUT: Adding extended input device "Dell Privacy Driver" (type: KEYBOARD, id 17)
[ 13.647] (**) Option "xkb_layout" "us"
[ 13.647] (II) event14 - Dell Privacy Driver: is tagged by udev as: Keyboard
[ 13.648] (II) event14 - Dell Privacy Driver: device is a keyboard
[ 13.648] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse4)
[ 13.648] (**) PS/2 Generic Mouse: Applying InputClass "devname"
[ 13.648] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 13.648] (**) PS/2 Generic Mouse: always reports core events
[ 13.648] (**) Option "Device" "/dev/input/mouse4"
[ 13.717] (II) mouse4 - not using input device '/dev/input/mouse4'.
[ 13.717] (EE) libinput: PS/2 Generic Mouse: Failed to create a device for /dev/input/mouse4
[ 13.717] (EE) PreInit returned 2 for "PS/2 Generic Mouse"
[ 13.717] (II) UnloadModule: "libinput"
[ 13.718] (II) config/udev: Adding input device PC Speaker (/dev/input/event16)
[ 13.718] (**) PC Speaker: Applying InputClass "devname"
[ 13.718] (II) Using input driver 'libinput' for 'PC Speaker'
[ 13.718] (**) PC Speaker: always reports core events
[ 13.718] (**) Option "Device" "/dev/input/event16"
[ 13.720] (II) event16 - PC Speaker: not tagged as supported input device
[ 13.763] (II) event16 - not using input device '/dev/input/event16'.
[ 13.764] (EE) libinput: PC Speaker: Failed to create a device for /dev/input/event16
[ 13.764] (EE) PreInit returned 2 for "PC Speaker"
[ 13.764] (II) UnloadModule: "libinput"
[ 13.764] (II) config/udev: removing device PS/2 Generic Mouse
[ 13.764] (II) event17 - PS/2 Generic Mouse: device removed
[ 13.807] (II) UnloadModule: "libinput"
[ 13.808] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event17)
[ 13.808] (**) PS/2 Generic Mouse: Applying InputClass "devname"
[ 13.808] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[ 13.808] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[ 13.808] (**) PS/2 Generic Mouse: always reports core events
[ 13.808] (**) Option "Device" "/dev/input/event17"
[ 13.809] (II) event17 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 13.810] (II) event17 - PS/2 Generic Mouse: device is a pointer
[ 13.810] (II) event17 - PS/2 Generic Mouse: device removed
[ 13.864] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input24/event17"
[ 13.864] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 20)
[ 13.864] (**) Option "AccelerationScheme" "none"
[ 13.864] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[ 13.864] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[ 13.864] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[ 13.867] (II) event17 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[ 13.867] (II) event17 - PS/2 Generic Mouse: device is a pointer
[ 13.871] (II) intel(0): EDID vendor "SHP", prod id 5457
[ 13.871] (II) intel(0): Using EDID range info for horizontal sync
[ 13.871] (II) intel(0): Using EDID range info for vertical refresh
[ 13.871] (II) intel(0): Printing DDC gathered Modelines:
[ 13.871] (II) intel(0): Modeline "3840x2400"x0.0 592.50 3840 3888 3920 4000 2400 2403 2409 2469 -hsync -vsync (148.1 kHz eP)
[ 13.907] (II) config/udev: removing device Dell WMI hotkeys
[ 13.907] (II) event15 - Dell WMI hotkeys: device removed
[ 13.954] (II) UnloadModule: "libinput"
[ 13.955] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event15)
[ 13.955] (**) Dell WMI hotkeys: Applying InputClass "devname"
[ 13.955] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 13.955] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 13.955] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 13.955] (**) Dell WMI hotkeys: always reports core events
[ 13.955] (**) Option "Device" "/dev/input/event15"
[ 13.957] (II) event15 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 13.957] (II) event15 - Dell WMI hotkeys: device is a keyboard
[ 13.958] (II) event15 - Dell WMI hotkeys: device removed
[ 14.004] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:02/wmi_bus/wmi_bus-PNP0C14:02/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input22/event15"
[ 14.004] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 18)
[ 14.004] (**) Option "xkb_layout" "us"
[ 14.006] (II) event15 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 14.007] (II) event15 - Dell WMI hotkeys: device is a keyboard
[ 14.009] (II) config/udev: Adding input device sof-soundwire HDMI/DP,pcm=5 (/dev/input/event18)
[ 14.009] (**) sof-soundwire HDMI/DP,pcm=5: Applying InputClass "devname"
[ 14.009] (II) Using input driver 'libinput' for 'sof-soundwire HDMI/DP,pcm=5'
[ 14.009] (**) sof-soundwire HDMI/DP,pcm=5: always reports core events
[ 14.009] (**) Option "Device" "/dev/input/event18"
[ 14.010] (II) event18 - sof-soundwire HDMI/DP,pcm=5: is tagged by udev as: Switch
[ 14.057] (II) event18 - not using input device '/dev/input/event18'.
[ 14.057] (EE) libinput: sof-soundwire HDMI/DP,pcm=5: Failed to create a device for /dev/input/event18
[ 14.057] (EE) PreInit returned 2 for "sof-soundwire HDMI/DP,pcm=5"
[ 14.057] (II) UnloadModule: "libinput"
[ 14.058] (II) config/udev: Adding input device sof-soundwire HDMI/DP,pcm=6 (/dev/input/event19)
[ 14.059] (**) sof-soundwire HDMI/DP,pcm=6: Applying InputClass "devname"
[ 14.059] (II) Using input driver 'libinput' for 'sof-soundwire HDMI/DP,pcm=6'
[ 14.059] (**) sof-soundwire HDMI/DP,pcm=6: always reports core events
[ 14.059] (**) Option "Device" "/dev/input/event19"
[ 14.061] (II) event19 - sof-soundwire HDMI/DP,pcm=6: is tagged by udev as: Switch
[ 14.100] (II) event19 - not using input device '/dev/input/event19'.
[ 14.100] (EE) libinput: sof-soundwire HDMI/DP,pcm=6: Failed to create a device for /dev/input/event19
[ 14.100] (EE) PreInit returned 2 for "sof-soundwire HDMI/DP,pcm=6"
[ 14.100] (II) UnloadModule: "libinput"
[ 14.102] (II) config/udev: Adding input device LXT2021:00 29BD:3303 (/dev/input/mouse3)
[ 14.102] (**) LXT2021:00 29BD:3303: Applying InputClass "devname"
[ 14.102] (II) Using input driver 'libinput' for 'LXT2021:00 29BD:3303'
[ 14.102] (**) LXT2021:00 29BD:3303: always reports core events
[ 14.102] (**) Option "Device" "/dev/input/mouse3"
[ 14.140] (II) mouse3 - not using input device '/dev/input/mouse3'.
[ 14.140] (EE) libinput: LXT2021:00 29BD:3303: Failed to create a device for /dev/input/mouse3
[ 14.140] (EE) PreInit returned 2 for "LXT2021:00 29BD:3303"
[ 14.140] (II) UnloadModule: "libinput"
[ 14.142] (II) config/udev: Adding input device sof-soundwire HDMI/DP,pcm=7 (/dev/input/event20)
[ 14.142] (**) sof-soundwire HDMI/DP,pcm=7: Applying InputClass "devname"
[ 14.142] (II) Using input driver 'libinput' for 'sof-soundwire HDMI/DP,pcm=7'
[ 14.142] (**) sof-soundwire HDMI/DP,pcm=7: always reports core events
[ 14.142] (**) Option "Device" "/dev/input/event20"
[ 14.144] (II) event20 - sof-soundwire HDMI/DP,pcm=7: is tagged by udev as: Switch
[ 14.190] (II) event20 - not using input device '/dev/input/event20'.
[ 14.190] (EE) libinput: sof-soundwire HDMI/DP,pcm=7: Failed to create a device for /dev/input/event20
[ 14.190] (EE) PreInit returned 2 for "sof-soundwire HDMI/DP,pcm=7"
[ 14.190] (II) UnloadModule: "libinput"
[ 14.193] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Mouse (/dev/input/mouse1)
[ 14.193] (**) VEN_04F3:00 04F3:31D1 Mouse: Applying InputClass "devname"
[ 14.193] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Mouse'
[ 14.193] (**) VEN_04F3:00 04F3:31D1 Mouse: always reports core events
[ 14.193] (**) Option "Device" "/dev/input/mouse1"
[ 14.250] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 14.250] (EE) libinput: VEN_04F3:00 04F3:31D1 Mouse: Failed to create a device for /dev/input/mouse1
[ 14.250] (EE) PreInit returned 2 for "VEN_04F3:00 04F3:31D1 Mouse"
[ 14.250] (II) UnloadModule: "libinput"
[ 14.252] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Touchpad (/dev/input/mouse2)
[ 14.252] (**) VEN_04F3:00 04F3:31D1 Touchpad: Applying InputClass "devname"
[ 14.252] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Touchpad'
[ 14.252] (**) VEN_04F3:00 04F3:31D1 Touchpad: always reports core events
[ 14.252] (**) Option "Device" "/dev/input/mouse2"
[ 14.294] (II) mouse2 - not using input device '/dev/input/mouse2'.
[ 14.294] (EE) libinput: VEN_04F3:00 04F3:31D1 Touchpad: Failed to create a device for /dev/input/mouse2
[ 14.294] (EE) PreInit returned 2 for "VEN_04F3:00 04F3:31D1 Touchpad"
[ 14.294] (II) UnloadModule: "libinput"
[ 14.295] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 UNKNOWN (/dev/input/event11)
[ 14.295] (**) VEN_04F3:00 04F3:31D1 UNKNOWN: Applying InputClass "devname"
[ 14.295] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 UNKNOWN'
[ 14.295] (**) VEN_04F3:00 04F3:31D1 UNKNOWN: always reports core events
[ 14.295] (**) Option "Device" "/dev/input/event11"
[ 14.297] (II) event11 - VEN_04F3:00 04F3:31D1 UNKNOWN: not tagged as supported input device
[ 14.357] (II) event11 - not using input device '/dev/input/event11'.
[ 14.357] (EE) libinput: VEN_04F3:00 04F3:31D1 UNKNOWN: Failed to create a device for /dev/input/event11
[ 14.357] (EE) PreInit returned 2 for "VEN_04F3:00 04F3:31D1 UNKNOWN"
[ 14.357] (II) UnloadModule: "libinput"
[ 14.357] (II) config/udev: removing device VEN_04F3:00 04F3:31D1 Mouse
[ 14.358] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device removed
[ 14.407] (II) UnloadModule: "libinput"
[ 14.408] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Mouse (/dev/input/event9)
[ 14.408] (**) VEN_04F3:00 04F3:31D1 Mouse: Applying InputClass "devname"
[ 14.408] (**) VEN_04F3:00 04F3:31D1 Mouse: Applying InputClass "libinput pointer catchall"
[ 14.408] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Mouse'
[ 14.408] (**) VEN_04F3:00 04F3:31D1 Mouse: always reports core events
[ 14.408] (**) Option "Device" "/dev/input/event9"
[ 14.411] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: is tagged by udev as: Mouse Pointingstick
[ 14.412] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device is a pointer
[ 14.412] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device removed
[ 14.490] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-10/i2c-VEN_04F3:00/0018:04F3:31D1.0008/input/input25/event9"
[ 14.491] (II) XINPUT: Adding extended input device "VEN_04F3:00 04F3:31D1 Mouse" (type: MOUSE, id 13)
[ 14.491] (**) Option "AccelerationScheme" "none"
[ 14.491] (**) VEN_04F3:00 04F3:31D1 Mouse: (accel) selected scheme none/0
[ 14.491] (**) VEN_04F3:00 04F3:31D1 Mouse: (accel) acceleration factor: 2.000
[ 14.491] (**) VEN_04F3:00 04F3:31D1 Mouse: (accel) acceleration threshold: 4
[ 14.494] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: is tagged by udev as: Mouse Pointingstick
[ 14.494] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device is a pointer
[ 14.497] (II) config/udev: removing device LXT2021:00 29BD:3303
[ 14.497] (II) event12 - LXT2021:00 29BD:3303: device removed
[ 14.540] (II) UnloadModule: "libinput"
[ 14.542] (II) config/udev: Adding input device LXT2021:00 29BD:3303 (/dev/input/event12)
[ 14.542] (**) LXT2021:00 29BD:3303: Applying InputClass "devname"
[ 14.542] (**) LXT2021:00 29BD:3303: Applying InputClass "libinput touchscreen catchall"
[ 14.542] (II) Using input driver 'libinput' for 'LXT2021:00 29BD:3303'
[ 14.542] (**) LXT2021:00 29BD:3303: always reports core events
[ 14.542] (**) Option "Device" "/dev/input/event12"
[ 14.544] (II) event12 - LXT2021:00 29BD:3303: is tagged by udev as: Touchscreen
[ 14.544] (II) event12 - LXT2021:00 29BD:3303: device is a touch device
[ 14.545] (II) event12 - LXT2021:00 29BD:3303: device removed
[ 14.594] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-9/i2c-LXT2021:00/0018:29BD:3303.0009/input/input29/event12"
[ 14.594] (II) XINPUT: Adding extended input device "LXT2021:00 29BD:3303" (type: TOUCHSCREEN, id 12)
[ 14.594] (**) Option "AccelerationScheme" "none"
[ 14.594] (**) LXT2021:00 29BD:3303: (accel) selected scheme none/0
[ 14.594] (**) LXT2021:00 29BD:3303: (accel) acceleration factor: 2.000
[ 14.594] (**) LXT2021:00 29BD:3303: (accel) acceleration threshold: 4
[ 14.597] (II) event12 - LXT2021:00 29BD:3303: is tagged by udev as: Touchscreen
[ 14.597] (II) event12 - LXT2021:00 29BD:3303: device is a touch device
[ 14.598] (II) config/udev: removing device VEN_04F3:00 04F3:31D1 Touchpad
[ 14.598] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device removed
[ 14.637] (II) UnloadModule: "libinput"
[ 14.638] (II) config/udev: Adding input device VEN_04F3:00 04F3:31D1 Touchpad (/dev/input/event10)
[ 14.638] (**) VEN_04F3:00 04F3:31D1 Touchpad: Applying InputClass "devname"
[ 14.638] (**) VEN_04F3:00 04F3:31D1 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 14.638] (II) Using input driver 'libinput' for 'VEN_04F3:00 04F3:31D1 Touchpad'
[ 14.638] (**) VEN_04F3:00 04F3:31D1 Touchpad: always reports core events
[ 14.638] (**) Option "Device" "/dev/input/event10"
[ 14.641] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: is tagged by udev as: Touchpad
[ 14.643] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device is a touchpad
[ 14.643] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device removed
[ 14.690] (**) Option "Tapping" "on"
[ 14.692] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-10/i2c-VEN_04F3:00/0018:04F3:31D1.0008/input/input26/event10"
[ 14.692] (II) XINPUT: Adding extended input device "VEN_04F3:00 04F3:31D1 Touchpad" (type: TOUCHPAD, id 14)
[ 14.695] (**) Option "AccelerationScheme" "none"
[ 14.695] (**) VEN_04F3:00 04F3:31D1 Touchpad: (accel) selected scheme none/0
[ 14.695] (**) VEN_04F3:00 04F3:31D1 Touchpad: (accel) acceleration factor: 2.000
[ 14.695] (**) VEN_04F3:00 04F3:31D1 Touchpad: (accel) acceleration threshold: 4
[ 14.696] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: is tagged by udev as: Touchpad
[ 14.698] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device is a touchpad
[ 22.958] (II) intel(0): resizing framebuffer to 11520x4320
[ 23.043] (II) intel(0): switch to mode 3840x2160@60.0 on DP1 using pipe 1, position (3840, 0), rotation normal, reflection none
[ 80.825] (EE) client bug: timer event10 keyboard: scheduled expiry is in the past (-2073ms), your system is too slow
[ 80.825] (EE) client bug: timer event10 tap: scheduled expiry is in the past (-27ms), your system is too slow
[ 80.825] (EE) client bug: timer event10 hold: scheduled expiry is in the past (-167ms), your system is too slow
[ 80.825] (EE) client bug: timer event10 hold: scheduled expiry is in the past (-88ms), your system is too slow
[ 80.825] (EE) WARNING: log rate limit exceeded (5 msgs per 3600000ms). Discarding future messages.
[ 80.825] (EE) event10 - VEN_04F3:00 04F3:31D1 Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.22.1/touchpad-jumping-cursors.html for details
[ 80.825] (II) event3 - Logitech G403 HERO Gaming Mouse: device removed
[ 80.853] (II) config/udev: removing device Logitech G403 HERO Gaming Mouse
[ 80.856] (II) UnloadModule: "libinput"
[ 80.914] (II) event4 - Logitech G403 HERO Gaming Mouse Keyboard: device removed
[ 81.191] (II) event5 - Apple Inc. Magic Keyboard with Numeric Keypad: device removed
[ 82.498] (II) config/udev: removing device Logitech G403 HERO Gaming Mouse Keyboard
[ 82.498] (II) UnloadModule: "libinput"
[ 82.499] (II) config/udev: removing device Logitech G403 HERO Gaming Mouse Keyboard
[ 82.499] (II) UnloadModule: "libinput"
[ 82.499] (II) config/udev: removing device Apple Inc. Magic Keyboard with Numeric Keypad
[ 82.500] (II) UnloadModule: "libinput"
[ 82.515] (II) intel(0): resizing framebuffer to 3840x2400
[ 99.498] (II) event1 - Power Button: device removed
[ 99.534] (II) event0 - Lid Switch: device removed
[ 99.587] (II) event7 - Intel HID events: device removed
[ 99.610] (II) event8 - Intel HID 5 button array: device removed
[ 99.634] (II) event2 - AT Translated Set 2 keyboard: device removed
[ 99.654] (II) event13 - Video Bus: device removed
[ 99.728] (II) event14 - Dell Privacy Driver: device removed
[ 99.784] (II) event17 - PS/2 Generic Mouse: device removed
[ 99.840] (EE) event10 - VEN_04F3:00 04F3:31D1 Touchpad: client bug: event processing lagging behind by 50ms, your system is too slow
[ 99.841] (II) event15 - Dell WMI hotkeys: device removed
[ 99.887] (II) event9 - VEN_04F3:00 04F3:31D1 Mouse: device removed
[ 99.941] (II) event12 - LXT2021:00 29BD:3303: device removed
[ 99.984] (II) event10 - VEN_04F3:00 04F3:31D1 Touchpad: device removed
[ 100.026] (II) UnloadModule: "libinput"
[ 100.027] (II) UnloadModule: "libinput"
[ 100.137] (II) Server terminated successfully (0). Closing log file.
