Today I updated the system with yay. There were a lot of packages today, and it looked alright during update. But now I cannot boot. It stops with a blinking curser in left corner…I didn’t have any problems during the last year.
How is the best way to look into what happened, or can I simply downgrade again?
Right now I booted from live iso and mounted /mnt and /mnt/boot/efi and arch-chroot into /mnt
If he’s got 6.10 kernel (seen in attachment) I think it’s been only around 6 months - and 6.10.10 was around 3 months ago.
Although the real gurus will likely instruct otherwise, if I had issues after not updating for that long, first I’d be inclined to ensure my mirrors were up to date and try again.
But if that failed, I’d likely resort to doing a fresh system start from scratch (from latest ISO) … assuming I had been properly backing up my personal data via Vorta/Borg or some such. But I appreciate that there may be a simple solution that escapes my grasp.
This is information only, but I have noticed a LOT of apple hardware with issues in the last 2-3 days. I suggest regressing and/or waiting till it’s resolved before updating.
I don’t know a thing about the apple ecosystem, just noticed commonalities.
Allright that worked! Now it did boot into a very minimal login screen. And now I’m in and it works. So it was my old display manager that made the problem?
option is to move back to gtk-greeter or try reinstall slick greeter… at lightdm greeters causes sometimes issue, i think rename lightdm folder in /etc makes a new config atleast…when reinstall a greeter as example gtk-greeter … wil setup gtk-greeter
