# sudo dmesg | grep -iE "error|failed"
[ 0.281255] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [SAC1] at bit offset/length 64/64 exceeds size of target Buffer (64 bits) (20200326/dsopcode-198)
[ 0.341674] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.341676] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.352226] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.352228] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.355288] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.355290] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.357423] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.357425] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.359349] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.359351] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.361211] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.361212] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.363649] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.363651] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.365641] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.365643] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.368544] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.368545] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.370560] ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
[ 0.370561] ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
[ 0.738705] pcieport 0000:00:1b.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.739248] pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.739706] pcieport 0000:00:1d.5: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.765145] RAS: Correctable Errors collector initialized.
[ 3.515814] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 3.776024] iwlwifi 0000:00:14.3: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 4.149637] thermal thermal_zone3: failed to read out thermal zone (-61)
[ 5.218482] uvcvideo: Failed to initialize entity for entity 6
[ 5.218483] uvcvideo: Failed to register entities (-22).
[ 5.421227] nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
[ 5.421229] ucsi_ccg 0-0008: i2c_transfer failed -110
[ 5.421231] ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
[ 5.421235] ucsi_ccg: probe of 0-0008 failed with error -110
[ 7.746623] audit: type=1103 audit(1595942003.485:39): pid=961 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="lightdm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 107.689796] i915 0000:00:02.0: [drm] *ERROR* CPU pipe A FIFO underrun
# journalctl -p3 -xb
-- Logs begin at Mon 2020-04-20 12:09:33 CEST, end at Tue 2020-07-28 15:33:37 CEST. --
Jul 28 15:13:18 firstecho kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [SAC1] at bit offset/length 64/64 exceeds size of target Buffer (64 bits) (20200326/dsopcode-198)
Jul 28 15:13:18 firstecho kernel: ACPI Error: AE_TYPE, Opcode is not deferred [SAC1] (BufferField) (20200326/nsinit-411)
Jul 28 15:13:18 firstecho kernel: ACPI Error: AE_TYPE, Could not execute arguments for [SAC1] (BufferField) (20200326/nsinit-419)
Jul 28 15:13:18 firstecho kernel: usbhid 1-6:1.0: couldn't find an input interrupt endpoint
Jul 28 15:13:21 firstecho kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
Jul 28 15:13:21 firstecho kernel: ucsi_ccg 0-0008: i2c_transfer failed -110
Jul 28 15:13:21 firstecho kernel: ucsi_ccg 0-0008: ucsi_ccg_init failed - -110
Jul 28 15:13:21 firstecho libvirtd[881]: direct firewall backend requested, but /usr/bin/ebtables is not available: No such file or directory
Jul 28 15:13:21 firstecho libvirtd[881]: internal error: Failed to initialize a valid firewall backend
Jul 28 15:13:21 firstecho libvirtd[881]: Cannot find 'dmidecode' in path: No such file or directory
Jul 28 15:13:31 firstecho lightdm[1005]: gkr-pam: unable to locate daemon control file
Jul 28 15:15:03 firstecho kernel: i915 0000:00:02.0: [drm] *ERROR* CPU pipe A FIFO underrun
# systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
0 loaded units listed.
As for the battery test, I’ll do that when I get home in a few hours, thanks for the suggestion
