I’ve build this package from AUR:
It gives a series of warnings in the terminal. I haven’t installed it yet. Just wondered if it still ok.
npm WARN old lockfile
npm WARN old lockfile The package-lock.json file was created with an old version of npm,
npm WARN old lockfile so supplemental metadata must be fetched from the registry.
npm WARN old lockfile This is a one-time fix-up, please be patient...
npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
npm WARN deprecated babel-eslint@10.1.0: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
added 550 packages, and audited 551 packages in 16s
51 packages are looking for funding
run `npm fund` for details
7 vulnerabilities (6 moderate, 1 high)
To address all issues, run:
npm audit fix
Particularly the following makes we wonder:
Should I be doing this:
npm audit fix
And what does mean:
full output of makepkg -s
$ makepkg -s
==> Making package: touche 1.0.6-5 (Sat 04 Sep 2021 01:12:13 PM CEST)
==> Checking runtime dependencies...
==> Installing missing dependencies...
[sudo] password for pebcak:
resolving dependencies...
Package (1) New Version Net Change Download Size
extra/gjs 2:1.68.3-1 1.09 MiB 0.33 MiB
Total Download Size: 0.33 MiB
Total Installed Size: 1.09 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
gjs-2:1.68.3-1-x86_64 336.1 KiB 1339 KiB/s 00:00 [------------------------------------] 100%
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
(1/1) loading package files [------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------] 100%
(1/1) checking available disk space [------------------------------------] 100%
:: Processing package changes...
(1/1) installing gjs [------------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
==> Checking buildtime dependencies...
Package (8) New Version Net Change Download Size
extra/c-ares 1.17.2-1 0.44 MiB 0.19 MiB
community/ninja 1.10.2-1 0.30 MiB 0.11 MiB
community/node-gyp 8.1.0-2 4.08 MiB 0.92 MiB
community/nodejs 16.8.0-1 30.78 MiB 8.78 MiB
community/nodejs-nopt 5.0.0-2 0.03 MiB 0.01 MiB
community/semver 7.3.5-2 0.11 MiB 0.04 MiB
extra/meson 0.59.1-1 7.30 MiB 1.24 MiB
community/npm 7.22.0-1 9.16 MiB 1.94 MiB
Total Download Size: 13.23 MiB
Total Installed Size: 52.20 MiB
nodejs-nopt-5.0.0-2-any 13.1 KiB 86.7 KiB/s 00:00 [------------------------------------] 100%
ninja-1.10.2-1-x86_64 116.8 KiB 541 KiB/s 00:00 [------------------------------------] 100%
semver-7.3.5-2-any 36.7 KiB 583 KiB/s 00:00 [------------------------------------] 100%
c-ares-1.17.2-1-x86_64 196.3 KiB 732 KiB/s 00:00 [------------------------------------] 100%
meson-0.59.1-1-any 1269.6 KiB 2.86 MiB/s 00:00 [------------------------------------] 100%
node-gyp-8.1.0-2-any 938.2 KiB 1687 KiB/s 00:01 [------------------------------------] 100%
npm-7.22.0-1-any 1986.8 KiB 2.41 MiB/s 00:01 [------------------------------------] 100%
nodejs-16.8.0-1-x86_64 8.8 MiB 4.48 MiB/s 00:02 [------------------------------------] 100%
Total (8/8) 13.2 MiB 6.64 MiB/s 00:02 [------------------------------------] 100%
(8/8) checking keys in keyring [------------------------------------] 100%
(8/8) checking package integrity [------------------------------------] 100%
(8/8) loading package files [------------------------------------] 100%
(8/8) checking for file conflicts [------------------------------------] 100%
(8/8) checking available disk space [------------------------------------] 100%
(1/8) installing ninja [------------------------------------] 100%
(2/8) installing meson [------------------------------------] 100%
(3/8) installing c-ares [------------------------------------] 100%
(4/8) installing nodejs [------------------------------------] 100%
Optional dependencies for nodejs
npm: nodejs package manager [pending]
(5/8) installing nodejs-nopt [------------------------------------] 100%
(6/8) installing semver [------------------------------------] 100%
(7/8) installing node-gyp [------------------------------------] 100%
(8/8) installing npm [------------------------------------] 100%
==> Retrieving sources...
-> Downloading touche-1.0.6.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
100 126 100 126 0 0 540 0 --:--:-- --:--:-- --:--:-- 543
100 373k 0 373k 0 0 502k 0 --:--:-- --:--:-- --:--:-- 913k
==> Validating source files with sha256sums...
touche-1.0.6.tar.gz ... Passed
==> Extracting sources...
-> Extracting touche-1.0.6.tar.gz with bsdtar
==> Starting build()...
npm audit fix
Run `npm audit` for details.
+ exec meson setup --prefix /usr --libexecdir lib --sbindir bin --buildtype plain --auto-features enabled --wrap-mode nodownload -D b_lto=true -D b_pie=true . build -Dtarget-de=gnome
The Meson build system
Version: 0.59.1
Source dir: /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6
Build dir: /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build
Build type: native build
Project name: com.github.joseexposito.touche
Project version: 1.0.6
Host machine cpu family: x86_64
Host machine cpu: x86_64
Program gjs found: YES (/usr/bin/gjs)
Program npm found: YES (/usr/bin/npm)
Program node found: YES (/usr/bin/node)
Program g-ir-scanner found: YES (/usr/bin/g-ir-scanner)
Program desktop-file-validate found: YES (/usr/bin/desktop-file-validate)
Program appstream-util found: YES (/usr/bin/appstream-util)
Program glib-compile-schemas found: YES (/usr/bin/glib-compile-schemas)
Program xgettext found: YES (/usr/bin/xgettext)
Executing subproject libtouche
libtouche| Project name: libtouche
libtouche| Project version: 1.0.0
libtouche| C++ compiler for the host machine: c++ (gcc 11.1.0 "c++ (GCC) 11.1.0")
libtouche| C++ linker for the host machine: c++ ld.bfd 2.36.1
libtouche| Found pkg-config: /usr/bin/pkg-config (1.7.3)
libtouche| Run-time dependency glib-2.0 found: YES 2.68.4
libtouche| Run-time dependency gobject-2.0 found: YES 2.68.4
libtouche| Run-time dependency x11 found: YES 1.7.2
libtouche| Run-time dependency gobject-introspection-1.0 found: YES 1.68.0
libtouche| Dependency gobject-introspection-1.0 found: YES 1.68.0 (cached)
libtouche| Program g-ir-scanner found: YES (/usr/bin/g-ir-scanner)
libtouche| Program g-ir-compiler found: YES (/usr/bin/g-ir-compiler)
libtouche| Build targets in project: 3
libtouche| Subproject libtouche finished.
Configuring desktop.in using configuration
Configuring app.appdata.xml.in using configuration
WARNING: Project targeting '>= 0.49.0' but tried to use feature introduced in '0.50.0': install arg in configure_file.
Configuring com.github.joseexposito.touche.gschema.xml using configuration
Configuring data.gresource.xml using configuration
Program glib-compile-resources found: YES (/usr/bin/glib-compile-resources)
Message: Building the application entry point: bin/com.github.joseexposito.touche
Configuring com.github.joseexposito.touche using configuration
Message: Building the application JavaScript bundle with Webpack...
Configuring src.gresource.xml using configuration
Program bundle/scripts/postinstall.py found: YES (/home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/bundle/scripts/postinstall.py)
Build targets in project: 11
WARNING: Project specifies a minimum meson_version '>= 0.49.0' but uses features which were added in newer versions:
* 0.50.0: {'install arg in configure_file'}
com.github.joseexposito.touche 1.0.6
Subprojects
libtouche: YES
Found ninja-1.10.2 at /usr/bin/ninja
ninja: Entering directory `build'
[6/9] Generating Touche-1.0.0.gir with a custom command
g-ir-scanner: link: gcc -pthread -o /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/tmp-introspectguud_u80/Touche-1.0.0 -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/tmp-introspectguud_u80/Touche-1.0.0.o -L. -Wl,-rpath,. -Wl,--no-as-needed -L/home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/subprojects/libtouche -Wl,-rpath,/home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/subprojects/libtouche -ltouche -lglib-2.0 -lgobject-2.0 -lX11 -lgirepository-1.0 -lgio-2.0 -lgobject-2.0 -Wl,--export-dynamic -lgmodule-2.0 -pthread -lglib-2.0 -lglib-2.0 -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now
[8/9] Generating build-application-bundle with a custom command
Browserslist: caniuse-lite is outdated. Please run:
npx browserslist@latest --update-db
Why you should do it regularly:
https://github.com/browserslist/browserslist#browsers-data-updating
[9/9] Generating com.github.joseexposito.touche.src_gresource with a custom command
==> Starting check()...
ninja: Entering directory `/home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build'
ninja: no work to do.
1/3 Validate desktop file OK 0.02s
2/3 Validate schema file OK 0.00s
3/3 Validate appstream file OK 0.85s
Ok: 3
Expected Fail: 0
Fail: 0
Unexpected Pass: 0
Skipped: 0
Timeout: 0
Full log written to /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/meson-logs/testlog.txt
==> Entering fakeroot environment...
==> Starting package()...
[1/2] Generating build-application-bundle with a custom command
Installing subprojects/libtouche/libtouche.so to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/lib
Installing subprojects/libtouche/Touche-1.0.0.gir to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/gir-1.0
Installing subprojects/libtouche/Touche-1.0.0.typelib to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/lib/girepository-1.0
Installing data/com.github.joseexposito.touche.desktop to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/applications
Installing data/com.github.joseexposito.touche.appdata.xml to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/appdata
Installing data/com.github.joseexposito.touche.data.gresource to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/com.github.joseexposito.touche
Installing bundle/com.github.joseexposito.touche.src.gresource to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/com.github.joseexposito.touche
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/subprojects/libtouche/touche.h to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/include
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/data/com.github.joseexposito.touche.gschema.xml to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/glib-2.0/schemas
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/16/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/16x16/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/16/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/16x16@2/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/24/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/24x24/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/24/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/24x24@2/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/32/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/32x32/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/32/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/32x32@2/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/48/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/48x48/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/48/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/48x48@2/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/64/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/64x64/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/64/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/64x64@2/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/128/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/128x128/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/data/icons/128/app.svg to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/share/icons/hicolor/128x128@2/apps
Installing /home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/build/bundle/com.github.joseexposito.touche to /home/pebcak/Downloads/tmp/touche/pkg/touche/usr/bin
Running custom install script '/usr/bin/meson --internal gettext install --subdir=po --localedir=share/locale --pkgname=com.github.joseexposito.touche'
Running custom install script '/home/pebcak/Downloads/tmp/touche/src/touche-1.0.6/bundle/scripts/postinstall.py'
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "touche"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: touche 1.0.6-5 (Sat 04 Sep 2021 01:13:05 PM CEST)
