I am brand new to EndeavourOS but not new to GNU/Linux, I am loving this distro so far as well as the bspwm edition.
I normally don’t bother ppl especially when it comes to GNU/Linux, I can’t seem to figure out how to make the icons bigger on the left side of polybar, I did change one of the font sizes which changed the font size on right hand side which is fine, any help would be appreciated.
You need to find out which one of the fonts are used for icons and change the size in the polybar config for it. A quick look at Github, there seems to be two fonts, so test both and reload the config - it should be one of them. Here’s the section:
Alternatively, find the modules you want to change and set the font manually with either label-font or format-font. Note that Polybars font property is a 1-based index of the fonts listed above, so if you want font-1, set it to font-0 in the module.
If neither work, it would be helpful if you could post a screenshot of the icons you want to alter.
Yes as i said I tried to change both of these and the only thing it changed for me was the text size on the right hand side, have a look at my config file from polybar
What Celty and Venom told should work; but If icons still aren’t scaling the way you want, you could add extra font definition and use that for icons you want to change.
font-0 = "Iosevka Term:pixelsize=13;4"
font-1 = "Iosevka Term:pixelsize=6;1"
font-2 = "Iosevka Term:pixelsize=16:5" ; 16 is size, 5 is top offset
Thank you for the reply, sorry my link didnt work, here is my polybar config file:, I tried extra definitions as well and still didn’t scale for me:
[colors]
fg-blue = #5294e2
focus-dark = #1b2124
blue = #73d0ff
blue-darker = #0771ed
green = #bae67e
dark-green = #75c933
red = #ff3333
bg = #800A0E14
fg = #bfbab0
cyan = #95e6cb
alpha = #00000000
white = #fff
[bar/top]
;monitor = VGA-1
override-redirect = false
; Put the bar at the bottom of the screen
bottom = false
; Prefer fixed center position for the `modules-center` block
fixed-center = true
width = 100%
height = 29
offset-x =
offset-y =
; Background ARGB color (e.g. #f00, #ff992a, #ddff1023)
background = ${colors.bg}
; Foreground ARGB color (e.g. #f00, #ff992a, #ddff1023)
foreground = ${colors.fg}
line-size = 0
line-color = #fff
; Number of spaces to add at the beginning/end of the bar
; Individual side values can be defined using:
; padding-{left,right}
padding-right = 1
padding-left = 0
; Number of spaces to add before/after each module
; module-margin-{left,right}
module-margin = 0
; Define modules fot the bar
; All modules need not be added here
modules-left = powermenu bspwm sps keyhint
modules-center = title
modules-right = backlight sps battery sps pulseaudio sps memory sps cpu sps caps sps num sps scroll sps date
; Following modules are not enabled by default in Endeavour OS Bspwm Edition
; 1. mpd - Shows current playing track info.
; Need to set host and port in module definition.
; 2. mpd_control - Shows previous, play/pause, next button to
; control music playback via mpd.
; 3. netspeed - Displays real time network speed
; Need to set correct interface name in module definition.
; The separator will be inserted between the output of each module
separator =
; This value is used to add extra spacing between elements
; @deprecated: This parameter will be removed in an upcoming version
spacing = 0
; Opacity value between 0.0 and 1.0 used on fade in/out
dim-value = 1.0
wm-name = i3
tray-position = right
; If true, the bar will not shift its
; contents when the tray changes
tray-detached = false
; Tray icon max size
tray-maxsize = 16
tray-background = ${colors.bg}
;offset defined as pixel value (e.g. 35) or percentage (e.g. 50%)
tray-offset-x = 0
tray-offset-y = 0
; Pad the sides of each tray icon
tray-padding = 2
; Scale factor for tray clients
tray-scale = 1
wm-restack = bspwm
dpi-x = 133
dpi-y = 133
enable-ipc = false
;border-left-size = 1%
;border-right-size = 1%
;border-top-size = 1%
;border-bottom-size = 25
border-color = ${colors.alpha}
[module/bspwm]
type = internal/bspwm
; Only show workspaces defined on the same output as the bar
; NOTE: The bspwm and XRandR monitor names must match, which they do by default.
; But if you rename your bspwm monitors with bspc -n this option will no longer
; behave correctly.
; Default: true
pin-workspaces = true
; Output mode flags after focused state label
; Default: false
inline-mode = false
; Create click handler used to focus workspace
; Default: true
enable-click = true
; Create scroll handlers used to cycle workspaces
; Default: true
enable-scroll = true
; Set the scroll cycle direction
; Default: true
reverse-scroll = false
; Use fuzzy (partial) matching on labels when assigning
; icons to workspaces
; Example: code;♚ will apply the icon to all workspaces
; containing 'code' in the label
; Default: false
fuzzy-match = true
; ws-icon-[0-9]+ = <label>;<icon>
; Note that the <label> needs to correspond with the bspwm workspace name
; Neither <label> nor <icon> can contain a semicolon (;)
label-font="Iosevka Term:pixelsize=16;4"
ws-icon-0 = "I;%{T1} %{T-}"
ws-icon-1 = "II;%{T1} %{T-}"
ws-icon-2 = "III;%{T1} %{T-}"
ws-icon-3 = "IV;%{T1} %{T-}"
ws-icon-4 = "V;%{T1} %{T-}"
ws-icon-5 = "VI;%{T1} %{T-}"
ws-icon-6 = "VII;%{T1} %{T-}"
ws-icon-7 = "VIII;%{T1} %{T-}"
ws-icon-8 = "IX;%{T1} %{T-}"
ws-icon-9 = "X;%{T1} %{T-}"
ws-icon-default = %{T1} %{T-}
; Available tags:
; <label-monitor>
; <label-state> - gets replaced with <label-(focused|urgent|occupied|empty)>
; <label-mode> - gets replaced with <label-(monocle|tiled|fullscreen|floating|locked|sticky|private)>
; Default: <label-state>
format = <label-state> <label-mode>
; Available tokens:
; %name%
; Default: %name%
label-monitor = %name%
; If any values for label-dimmed-N are defined, the workspace/mode
; colors will get overridden with those values if the monitor is out of focus
; To only override workspaces in a specific state, use:
; label-dimmed-focused
; label-dimmed-occupied
; label-dimmed-urgent
; label-dimmed-empty
label-dimmed-foreground = #555
label-dimmed-underline = ${bar/top.background}
label-dimmed-focused-background = #f00
; Available tokens:
; %name%
; %icon%
; %index%
; Default: %icon% %name%
label-focused = %icon%
label-focused-foreground = ${colors.focus-dark}
label-focused-background = ${colors.fg-blue}
label-focused-underline = #fba922
; Available tokens:
; %name%
; %icon%
; %index%
label-occupied = %icon%
label-occupied-padding = 0
label-occupied-foreground = ${colors.fg-blue}
; Available tokens:
; %name%
; %icon%
; %index%
label-urgent = %icon%
label-urgent-foreground = ${colors.red}
; Available tokens:
; %name%
; %icon%
; %index%
label-empty = %icon%
label-empty-foreground = #55
label-empty-padding = 0
; Separator in between workspaces
label-separator =
label-separator-padding = 0
label-separator-foreground = #ffb52a
[module/date]
type = internal/date
; Seconds to sleep between updates
interval = 1.0
; See "http://en.cppreference.com/w/cpp/io/manip/put_time" for details on how to format the date string
; NOTE: if you want to use syntax tags here you need to use %%{...}
date = %{T1}%{T-}%{T2} %d/%a%{T-}
; Optional time format
time = %{T2} %H:%M%{T-}
; if `date-alt` or `time-alt` is defined, clicking
; the module will toggle between formats
date-alt = %{T1}%{T-}%{T2} %a, %d %b %y%{T-}
time-alt = %{T2} %H:%M:%S%{T-}
label = %date%%time%
label-font = 0
label-foreground = ${colors.green}
[module/cpu]
type = internal/cpu
; Default: 1
interval = 0.5
label = %{T1}%{T-}%{T2} %percentage:2%%%{T-}
label-foreground = ${colors.cyan}
[module/memory]
type = internal/memory
; Default: 1
interval = 0.5
format = <label>
; Available tokens:
; %percentage_used% (default)
; %percentage_free%
; %gb_used%
; %gb_free%
; %gb_total%
; %mb_used%
; %mb_free%
; %mb_total%
; %percentage_swap_used%
; %percentage_swap_free%
; %mb_swap_total%
; %mb_swap_free%
; %mb_swap_used%
; %gb_swap_total%
; %gb_swap_free%
; %gb_swap_used%
label = %{T1}%{T-}%{T2} %gb_used%%{T-}
[module/mpd]
type = internal/mpd
host = 0.0.0.0
port = 6600
interval = 2
format-online = <label-song>
format-online-background = ${colors.bg}
format-online-foreground = ${colors.fg-blue}
#format-online-padding = 20
label-song = %{T2}%artist% - %title%%{T-}
label-song-maxlen = 55
label-song-ellipsis = true
label-offline = "MPD is offline"
[module/mpd_control]
type = internal/mpd
interval = 2
format-online = <icon-prev> <toggle> <icon-next>
; Only applies if <icon-X> is used
icon-play = %{T1}奈%{T-}
icon-pause = %{T1}%{T-}
icon-stop = %{T1}%{T-}
icon-prev = %{T1}ﭣ%{T-}
icon-next = %{T1}ﭡ%{T-}
;An empty module used to add 1 unit spacings whenever needed
[module/sps]
type = custom/text
content = " "
content-padding = 0
[module/netspeed]
type = internal/network
; Set correct interface name for the module to work
; Try eth0 for ethernet or wlan0 for wireless
; You can also run ifconfig in a terminal
; to know the interace names on your system.
interface = wlan0
interval = 1.0
label-connected = "%{T1}龍%{T-}%{T2} %downspeed% | %upspeed%%{T-}"
label-disconnected = "%{T2}0/0%{T-}"
label-connected-background = ${colors.bg}
label-connected-foreground = ${colors.blue}
label-disconnected-foreground = ${colors.red}
[module/title]
type = internal/xwindow
; Available tags:
; <label> (default)
format = <label>
format-background = ${colors.bg}
format-foreground = ${colors.green}
format-padding = 4
; Available tokens:
; %title%
; Default: %title%
label = "%{T1}类%{T-}%{T2} %title%%{T-}"
label-maxlen = 65
; Used instead of label when there is no window title
; Available tokens:
; None
label-empty =%{T2}EndeavourOS Bspwm%{T-}
label-empty-foreground = #707880
[module/pulseaudio]
type = internal/pulseaudio
; Sink to be used, if it exists (find using `pacmd list-sinks`, name field)
; If not, uses default sink
; sink = alsa_output.pci-0000_12_00.3.analog-stereo
; sink = alsa_output.pci-0000_00_1b.0.analog-stereo
; Use PA_VOLUME_UI_MAX (~153%) if true, or PA_VOLUME_NORM (100%) if false
; Default: true
use-ui-max = false
; Interval for volume increase/decrease (in percent points)
; Default: 5
interval = 5
; Available tags:
; <label-volume> (default)
; <ramp-volume>
; <bar-volume>
format-volume = <label-volume>
; Available tags:
; <label-muted> (default)
; <ramp-volume>
; <bar-volume>
format-muted = <label-muted>
; Available tokens:
; %percentage% (default)
; %decibels% (unreleased)
label-volume = %{T1}墳%{T-} %{T2}%percentage%%%{T-}
label-volume-foreground = ${colors.dark-green}
; Available tokens:
label-muted = %{T1}ﱝ%{T-} %{T2}shhh!%{T-}
label-muted-foreground = ${colors.dark-green}
; Only applies if <ramp-volume> is used
ramp-volume-0 = %{T1}%{T-}
ramp-volume-1 = %{T1}奔%{T-}
ramp-volume-2 = %{T1}墳%{T-}
; Right and Middle click (unreleased)
click-right = pavucontrol &
; click-middle =
[module/backlight]
type = internal/backlight
; Use the following command to list available cards:
; $ ls -1 /sys/class/backlight/
card = intel_backlight
; Enable changing the backlight with the scroll wheel
; NOTE: This may require additional configuration on some systems. Polybar will
; write to `/sys/class/backlight/${self.card}/brightness` which requires polybar
; to have write access to that file.
; DO NOT RUN POLYBAR AS ROOT.
; The recommended way is to add the user to the
; `video` group and give that group write-privileges for the `brightness` file.
; See the ArchWiki for more information:
; https://wiki.archlinux.org/index.php/Backlight#ACPI
; Default: false
; Available tags:
; <label> (default)
; <ramp>
; <bar>
format = <label>
format-foreground = ${colors.blue}
; Available tokens:
label = %{T2} %percentage%%%{T-}
[module/battery]
type = internal/battery
; This is useful in case the battery never reports 100% charge
full-at = 99
; Use the following command to list batteries and adapters:
; $ ls -1 /sys/class/power_supply/
battery = BAT0
adapter = ADP1
; If an inotify event haven't been reported in this many
; seconds, manually poll for new values.
; Needed as a fallback for systems that don't report events
; on sysfs/procfs.
; Disable polling by setting the interval to 0.
; Default: 5
poll-interval = 5
; Available tags:
; <label-charging> (default)
; <bar-capacity>
; <ramp-capacity>
; <animation-charging>
format-charging = <label-charging>
; Available tags:
; <label-discharging> (default)
; <bar-capacity>
; <ramp-capacity>
; <animation-discharging>
format-discharging = <label-discharging>
; Available tags:
; <label-full> (default)
; <bar-capacity>
; <ramp-capacity>
;format-full = <ramp-capacity> <label-full>
; Available tokens:
; %percentage% (default) - is set to 100 if full-at is reached
; %percentage_raw%
; %time%
; %consumption% (shows current charge rate in watts)
label-charging = %{T2}%{T-} %{T2}%percentage%%%{T-}
label-charging-foreground = ${colors.blue}
; Available tokens:
; %percentage_raw%
; %time%
; %consumption% (shows current discharge rate in watts)
label-discharging = %{T1}%{T-} %{T2}%percentage%%%{T-}
label-discharging-foreground = ${colors.blue}
; Available tokens:
; %percentage_raw%
label-full = %{T1}%{T-} %{T2}Full!%{T-}
label-full-foreground = ${colors.blue}
;[settings]
;pseudo-transparency = true
[module/caps]
type = custom/script
interval = 0.5s
exec = ~/.config/polybar/scripts/cns.sh -c
[module/num]
interval = 0.5s
exec = ~/.config/polybar/scripts/cns.sh -n
[module/scroll]
interval = 0.5s
exec = ~/.config/polybar/scripts/cns.sh -s
[module/powermenu]
type = custom/text
content = "襤"
click-left = ~/.config/rofi/powermenu.sh
content-background = ${colors.blue-darker}
content-foreground = ${colors.white}
content-padding = 1
margin-right = 0
[module/keyhint]
type = custom/text
content = ""
click-left = xfce4-terminal -e "less /home/$USER/.config/bspwm/keybindings" --hold
content-foreground = ${colors.blue-darker}
content-padding = 1
margin-right = 0
[module/checkupdates]
interval = 900s
exec = ~/.config/polybar/scripts/checkupdates.sh
Ok for the workspace icons it still didnt work here is my screenshot , and changed the workspace icons as you indicated by replacing {T1} with {T3}:
[colors]
fg-blue = #5294e2
blue = #73d0ff
green = #bae67e
red = #ff3333
bg = #800A0E14
fg = #bfbab0
cyan = #95e6cb
alpha = #00000000
white = #fff
[bar/top]
;monitor = VGA-1
bottom = false
fixed-center = true
width = 100%
height = 29
offset-x =
offset-y =
line-size = 0
line-color = #fff
padding-right = 1
padding-left = 0
module-margin = 0
font-s = "Iosevka Term:pixelsize=16;5"
separator =
spacing = 0
dim-value = 1.0
wm-name = i3
tray-maxsize = 16
tray-offset-x = 0
tray-offset-y = 0
tray-padding = 2
tray-scale = 1
wm-restack = bspwm
dpi-x = 133
dpi-y = 133
enable-ipc = false
[module/bspwm]
; behave correctly.
; Default: true
; Default: false
inline-mode = false
; Default: true
enable-click = true
; Default: true
; Default: true
; Default: false
fuzzy-match = true
ws-icon-0 = "I;%{T3} %{T-}"
ws-icon-1 = "II;%{T3} %{T-}"
ws-icon-2 = "III;%{T3} %{T-}"
ws-icon-3 = "IV;%{T3} %{T-}"
ws-icon-4 = "V;%{T3} %{T-}"
ws-icon-5 = "VI;%{T3} %{T-}"
ws-icon-6 = "VII;%{T3} %{T-}"
ws-icon-7 = "VIII;%{T3} %{T-}"
ws-icon-8 = "IX;%{T3} %{T-}"
ws-icon-9 = "X;%{T3} %{T-}"
ws-icon-default = %{T3} %{T-}
; Available tags:
; <label-monitor>
; Available tokens:
; %name%
; Default: %name%
; Available tokens:
; %name%
; %icon%
; %index%
; Available tokens:
; %name%
; %icon%
; %index%
; Available tokens:
; %name%
; %icon%
; %index%
; Available tokens:
; %name%
; %icon%
; %index%
label-separator =
[module/date]
interval = 1.0
label-font = 0
[module/cpu]
type = internal/cpu
; Default: 1
interval = 0.5
[module/memory]
; Default: 1
interval = 0.5
format = <label>
; Available tokens:
; %percentage_free%
; %gb_used%
; %gb_free%
; %gb_total%
; %mb_used%
; %mb_free%
; %mb_total%
; %mb_swap_total%
; %mb_swap_free%
; %mb_swap_used%
; %gb_swap_total%
; %gb_swap_free%
; %gb_swap_used%
[module/mpd]
type = internal/mpd
host = 0.0.0.0
port = 6600
interval = 2
type = internal/mpd
interval = 2
[module/sps]
type = custom/text
content = " "
content-padding = 0
[module/netspeed]
interface = wlan0
interval = 1.0
[module/title]
; Available tags:
; <label> (default)
format = <label>
format-padding = 4
; Available tokens:
; %title%
; Default: %title%
label-maxlen = 65
; Available tokens:
; None
[module/pulseaudio]
; Default: true
use-ui-max = false
; Default: 5
interval = 5
; Available tags:
; <ramp-volume>
; <bar-volume>
; Available tags:
; <ramp-volume>
; <bar-volume>
; Available tokens:
; Available tokens:
; click-middle =
[module/backlight]
; Default: false
; Available tags:
; <label> (default)
; <ramp>
; <bar>
format = <label>
; Available tokens:
[module/battery]
full-at = 99
battery = BAT0
adapter = ADP1
; on sysfs/procfs.
; Default: 5
poll-interval = 5
; Available tags:
; <bar-capacity>
; <ramp-capacity>
; Available tags:
; <bar-capacity>
; <ramp-capacity>
; Available tags:
; <bar-capacity>
; <ramp-capacity>
; Available tokens:
; %percentage_raw%
; %time%
; Available tokens:
; %percentage_raw%
; %time%
; Available tokens:
; %percentage_raw%
;[settings]
[module/caps]
interval = 0.5s
[module/num]
interval = 0.5s
[module/scroll]
interval = 0.5s
[module/powermenu]
type = custom/text
content = "襤"
content-padding = 1
margin-right = 0
[module/keyhint]
type = custom/text
content = ""
content-padding = 1
margin-right = 0
interval = 900s
