Brother MFC-J3939DW printer issue in EndeavourOS
I have also installed ipp-usb.
The only one missing was qpdfview, which I have installed. No changes. Still the same error message. Thank you again for your kindness Joe :slightly_smiling_face:
I can confirm that the issue is not related to EndeavourOS, as I initially said. It now occurs in all Arch linux based distros. I have to apologize for it, thank you once more. I could not solve it yet.
Here is the CUPS error_log
 [24/Aug/2026:10:48:48 +0300] [Client 79] GET /printers/Brother_MFC-J3930DW HTTP/1.1
D [24/Aug/2026:10:48:48 +0300] cupsdSetBusyState: newbusy="Active clients, printing jobs, and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:48 +0300] [Client 79] Read: status=200, state=3
D [24/Aug/2026:10:48:48 +0300] [Client 79] Authorized as "bogdan" using Basic.
D [24/Aug/2026:10:48:48 +0300] [Client 79] Processing GET /printers/Brother_MFC-J3930DW
D [24/Aug/2026:10:48:48 +0300] [CGI] argv[0] = "/usr/lib/cups/cgi-bin/printers.cgi"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[0] = "CUPS_CACHEDIR=/var/cache/cups"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[1] = "CUPS_DATADIR=/usr/share/cups"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[2] = "CUPS_DOCROOT=/usr/share/cups/doc"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[3] = "CUPS_REQUESTROOT=/var/spool/cups"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[4] = "CUPS_SERVERBIN=/usr/lib/cups"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[5] = "CUPS_SERVERROOT=/etc/cups"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[6] = "CUPS_STATEDIR=/run/cups"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[7] = "HOME=/var/spool/cups/tmp"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[8] = "PATH=/usr/lib/cups/filter:/usr/bin:/usr/bin:/bin:/usr/bin"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[9] = "SERVER_ADMIN=root@Yoggy24"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[10] = "SOFTWARE=CUPS/2.4.19"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[11] = "TMPDIR=/var/spool/cups/tmp"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[12] = "USER=root"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[13] = "CUPS_MAX_MESSAGE=2047"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[14] = "CUPS_SERVER=/run/cups/cups.sock"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[15] = "CUPS_ENCRYPTION=IfRequested"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[16] = "IPP_PORT=631"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[17] = "AUTH_TYPE=Basic"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[18] = "LANG=en_US.UTF8"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[19] = "REDIRECT_STATUS=1"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[20] = "GATEWAY_INTERFACE=CGI/1.1"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[21] = "SERVER_NAME=localhost"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[22] = "SERVER_PORT=631"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[23] = "REMOTE_ADDR=[v1.::1]"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[24] = "REMOTE_HOST=localhost"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[25] = "SCRIPT_NAME=/printers/Brother_MFC-J3930DW"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[26] = "SCRIPT_FILENAME=/usr/share/cups/doc/printers/Brother_MFC-J3930DW"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[27] = "PATH_INFO=/Brother_MFC-J3930DW"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[28] = "REMOTE_USER=bogdan"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[29] = "SERVER_PROTOCOL=HTTP/1.1"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[30] = "HTTP_COOKIE=org.cups.sid=9c941631c475df9d4fd34730a531cfec"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[31] = "HTTP_USER_AGENT=Mozilla/5.0 (X11; Linux x86_64; rv:156.0) Gecko/20100101 Firefox/156.0"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[32] = "HTTP_REFERER=http://localhost:631/printers/Brother_MFC-J3930DW"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[33] = "REQUEST_METHOD=GET"
D [24/Aug/2026:10:48:48 +0300] [CGI] envp[34] = "QUERY_STRING="
D [24/Aug/2026:10:48:48 +0300] cupsdAddCert: Adding certificate for PID 72685
D [24/Aug/2026:10:48:48 +0300] [CGI] Started /usr/lib/cups/cgi-bin/printers.cgi (PID 72685)
I [24/Aug/2026:10:48:48 +0300] [Client 79] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=72685, file=15)
D [24/Aug/2026:10:48:48 +0300] [Client 79] Waiting for CGI data.
D [24/Aug/2026:10:48:48 +0300] [CGI] org.cups.sid cookie is \"9c941631c475df9d4fd34730a531cfec\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: SECTION=\"printers\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: REFRESH_PAGE=\"\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: PRINTER_NAME=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] cupsdSetBusyState: newbusy="Active clients, printing jobs, and dirty files", busy="Active clients, printing jobs, and dirty files"
D [24/Aug/2026:10:48:48 +0300] [Client 94] Server address is "/run/cups/cups.sock".
D [24/Aug/2026:10:48:48 +0300] [Client 94] Accepted from localhost (Domain)
D [24/Aug/2026:10:48:48 +0300] [Client 94] Waiting for request.
D [24/Aug/2026:10:48:48 +0300] [Client 94] POST / HTTP/1.1
D [24/Aug/2026:10:48:48 +0300] [Client 94] Read: status=200, state=6
D [24/Aug/2026:10:48:48 +0300] [Client 94] No authentication data provided.
D [24/Aug/2026:10:48:48 +0300] [Client 94] 2.0 CUPS-Get-Default 1
D [24/Aug/2026:10:48:48 +0300] CUPS-Get-Default
D [24/Aug/2026:10:48:48 +0300] CUPS-Get-Default client-error-not-found: No default printer.
D [24/Aug/2026:10:48:48 +0300] [Client 94] Returning IPP client-error-not-found for CUPS-Get-Default (no URI) from localhost.
D [24/Aug/2026:10:48:48 +0300] [Client 94] Content-Length: 113
D [24/Aug/2026:10:48:48 +0300] [Client 94] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [24/Aug/2026:10:48:48 +0300] [Client 94] con->http=0x55a685b40c60
D [24/Aug/2026:10:48:48 +0300] [Client 94] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=113, response=0x55a685b320a0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [24/Aug/2026:10:48:48 +0300] [Client 94] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [24/Aug/2026:10:48:48 +0300] [Client 94] bytes=0, http_state=0, data_remaining=113
D [24/Aug/2026:10:48:48 +0300] [Client 94] Flushing write buffer.
D [24/Aug/2026:10:48:48 +0300] [Client 94] New state is HTTP_STATE_WAITING
D [24/Aug/2026:10:48:48 +0300] [Client 94] 2.0 Get-Printer-Attributes 2
D [24/Aug/2026:10:48:48 +0300] Get-Printer-Attributes ipp://localhost/printers/Brother_MFC-J3930DW
D [24/Aug/2026:10:48:48 +0300] [Client 94] Returning IPP successful-ok for Get-Printer-Attributes (ipp://localhost/printers/Brother_MFC-J3930DW) from localhost.
D [24/Aug/2026:10:48:48 +0300] [Client 94] Content-Length: 739
D [24/Aug/2026:10:48:48 +0300] [CGI] show_printer(http=0x559e8c80bf00, printer=\"Brother_MFC-J3930DW\")
D [24/Aug/2026:10:48:48 +0300] [Client 94] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=739, response=0x55a685a9d3b0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [24/Aug/2026:10:48:48 +0300] [Client 94] bytes=0, http_state=0, data_remaining=739
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: SERVER_NAME=\"localhost\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: REMOTE_USER=\"bogdan\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: CUPS_VERSION=\"CUPS v2.4.19\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_is_accepting_jobs[0]=\"1\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_is_shared[0]=\"1\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_state[0]=\"4\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: admin_uri[0]=\"/admin/\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_uri_supported[0]=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_name[0]=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_location[0]=\"Local Printer\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_info[0]=\"Brother MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_sheets_default[0]=\"none, none\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: device_uri[0]=\"dnssd://Brother%20MFC-J3930DW._ipp._tcp.local/?uuid=e3248000-80ce-11db-8000-b422005f0bdc\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: color_supported[0]=\"1\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_make_and_model[0]=\"MFC-J3930DW - IPP Everywhere\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: media_default[0]=\"iso_a4_210x297mm\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: sides_supported[0]=\"one-sided, two-sided-long-edge, two-sided-short-edge\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: sides_default[0]=\"one-sided\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: printer_commands[0]=\"none\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: server_is_sharing_printers[0]=\"0\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: refresh_page=\"10;URL=/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: TITLE=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [Client 79] CGI data ready to be sent.
D [24/Aug/2026:10:48:48 +0300] [Client 79] con->http=0x55a685a05490
D [24/Aug/2026:10:48:48 +0300] [Client 79] cupsdWriteClient error=0, used=0, state=HTTP_STATE_GET_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=2147483647, response=(nil)(), pipe_pid=72685, file=15
D [24/Aug/2026:10:48:48 +0300] [Client 79] Script header: Content-Type: text/html;charset=utf-8
D [24/Aug/2026:10:48:48 +0300] [Client 79] Sending status 200 for CGI.
D [24/Aug/2026:10:48:48 +0300] [Client 79] cupsdSendHeader: code=200, type="(null)", auth_type=0
D [24/Aug/2026:10:48:48 +0300] [Client 79] cupsdWriteClient error=0, used=0, state=HTTP_STATE_GET_SEND, data_encoding=HTTP_ENCODING_CHUNKED, data_remaining=0, response=(nil)(), pipe_pid=72685, file=15
D [24/Aug/2026:10:48:48 +0300] [Client 94] 2.0 Get-Jobs 3
D [24/Aug/2026:10:48:48 +0300] Get-Jobs ipp://localhost:631/printers/Brother_MFC-J3930DW
D [24/Aug/2026:10:48:48 +0300] [Client 94] Returning IPP successful-ok for Get-Jobs (ipp://localhost:631/printers/Brother_MFC-J3930DW) from localhost.
D [24/Aug/2026:10:48:48 +0300] [Client 94] Content-Length: 415
D [24/Aug/2026:10:48:48 +0300] [Client 94] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=415, response=0x55a685b33370(IPP_STATE_DATA), pipe_pid=0, file=-1
D [24/Aug/2026:10:48:48 +0300] [Client 94] bytes=0, http_state=0, data_remaining=415
D [24/Aug/2026:10:48:48 +0300] [CGI] Regular expression \".*Clean.*\"
D [24/Aug/2026:10:48:48 +0300] [CGI] Regular expression \".*PrintSelfTestPage.*\"
D [24/Aug/2026:10:48:48 +0300] [Client 79] con->http=0x55a685a05.
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiClearVariables called.
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: TOTAL=\"1\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_printer_name[0]=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_printer_uri[0]=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: time_at_completed[0]=\"novalue\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: time_at_creation[0]=\"Mon 24 Aug 2026 10:48:46 AM EEST\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: time_at_processing[0]=\"Mon 24 Aug 2026 10:48:46 AM EEST\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_id[0]=\"9\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_state[0]=\"5\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_impressions_completed[0]=\"0\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_k_octets[0]=\"1\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_hold_until[0]=\"no-hold\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetArray: job_printer_state_message[0]=\"cfFilterChain: pdftopdf (PID 72678) stopped with status 1\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: PRINTER_URI_SUPPORTED=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: THISURL=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [CGI] cgiSetVariable: SEARCH_DEST=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:48 +0300] [Client 94] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:10:48:48 +0300] [Client 94] Closing connection.
D [24/Aug/2026:10:48:48 +0300] PID 72685 (/usr/lib/cups/cgi-bin/printers.cgi) exited with no errors.
D [24/Aug/2026:10:48:48 +0300] [Client 79] Sending 0-length chunk.
D [24/Aug/2026:10:48:48 +0300] [Client 79] Flushing write buffer.
D [24/Aug/2026:10:48:48 +0300] [Client 79] New state is HTTP_STATE_WAITING
D [24/Aug/2026:10:48:48 +0300] [Client 79] Waiting for request.
D [24/Aug/2026:10:48:48 +0300] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Active clients, printing jobs, and dirty files"
D [24/Aug/2026:10:48:48 +0300] [Job 9] IPP/2.0 Get-Printer-Attributes #10
D [24/Aug/2026:10:48:48 +0300] [Job 9] ---- operation-attributes-tag ----
D [24/Aug/2026:10:48:48 +0300] [Job 9] attributes-charset charset utf-8
D [24/Aug/2026:10:48:48 +0300] [Job 9] attributes-natural-language naturalLanguage en-us
D [24/Aug/2026:10:48:48 +0300] [Job 9] printer-uri uri ipp://BRWF889D2A4AE15.local:631/ipp/print
D [24/Aug/2026:10:48:48 +0300] [Job 9] requesting-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:48 +0300] [Job 9] requested-attributes 1setOf keyword compression-supported,copies-supported,cups-version,document-format-supported,job-password-encryption-supported,marker-colors,marker-high-levels,marker-levels,marker-low-levels,marker-message,marker-names,marker-types,media-col-supported,multiple-document-handling-supported,operations-supported,print-color-mode-supported,print-scaling-supported,printer-alert,printer-alert-description,printer-is-accepting-jobs,printer-mandatory-job-attributes,printer-state,printer-state-message,printer-state-reasons
D [24/Aug/2026:10:48:48 +0300] [Job 9] ---- end-of-attributes-tag ----
D [24/Aug/2026:10:48:48 +0300] [Job 9] IPP/2.0 Get-Printer-Attributes #11
D [24/Aug/2026:10:48:49 +0300] [Job 9] update_reasons(attr=1(none), s=\"(null)\")
D [24/Aug/2026:10:48:49 +0300] [Job 9] Get-Printer-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:49 +0300] [Job 9] ---- operation-attributes-tag ----
D [24/Aug/2026:10:48:49 +0300] [Job 9] attributes-charset charset utf-8
D [24/Aug/2026:10:48:49 +0300] [Job 9] attributes-natural-language naturalLanguage en-us
D [24/Aug/2026:10:48:49 +0300] [Job 9] ---- unsupported-attributes-tag ----
D [24/Aug/2026:10:48:49 +0300] [Job 9] requested-attributes 1setOf keyword cups-version,job-password-encryption-supported,marker-message,multiple-document-handling-supported,printer-mandatory-job-attributes,printer-state-message
D [24/Aug/2026:10:48:49 +0300] [Job 9] ---- printer-attributes-tag ----
D [24/Aug/2026:10:48:49 +0300] [Job 9] compression-supported keyword none
D [24/Aug/2026:10:48:49 +0300] [Job 9] copies-supported rangeOfInteger 1-99
D [24/Aug/2026:10:48:49 +0300] [Job 9] document-format-supported 1setOf mimeMediaType application/octet-stream,image/urf,image/jpeg,image/pwg-raster,application/vnd.brother-hbp
D [24/Aug/2026:10:48:49 +0300] [Job 9] marker-colors 1setOf nameWithLanguage #FF00FF[en],#00FFFF[en],#FFFF00[en],#000000[en]
D [24/Aug/2026:10:48:49 +0300] [Job 9] marker-high-levels 1setOf integer 100,100,100,100
D [24/Aug/2026:10:48:49 +0300] [Job 9] marker-levels 1setOf integer 42,61,29,44
D [24/Aug/2026:10:48:49 +0300] [Job 9] marker-low-levels 1setOf integer 16,16,16,15
D [24/Aug/2026:10:48:49 +0300] [Job 9] marker-names 1setOf nameWithLanguage M[en],C[en],Y[en],BK[en]
D [24/Aug/2026:10:48:49 +0300] [Job 9] marker-types 1setOf keyword ink-cartridge,ink-cartridge,ink-cartridge,ink-cartridge
D [24/Aug/2026:10:48:49 +0300] [Job 9] media-col-supported 1setOf keyword media-type,media-size,media-top-margin,media-left-margin,media-right-margin,media-bottom-margin,media-source,media-auto-dimension,media-source-propaties
D [24/Aug/2026:10:48:49 +0300] [Job 9] operations-supported 1setOf enum Print-Job,Validate-Job,Create-Job,Send-Document,Cancel-Job,Get-Job-Attributes,Get-Jobs,Get-Printer-Attributes,Close-Job,Identify-Printer
D [24/Aug/2026:10:48:49 +0300] [Job 9] print-color-mode-supported 1setOf keyword auto,color,monochrome,auto-monochrome
D [24/Aug/2026:10:48:49 +0300] [Job 9] print-scaling-supported 1setOf keyword auto,auto-fit,fill,fit,none
D [24/Aug/2026:10:48:49 +0300] [Job 9] printer-alert octetString code=other
D [24/Aug/2026:10:48:49 +0300] [Job 9] printer-alert-description textWithLanguage Ready[en]
D [24/Aug/2026:10:48:49 +0300] [Job 9] printer-is-accepting-jobs boolean true
D [24/Aug/2026:10:48:49 +0300] [Job 9] printer-state enum idle
D [24/Aug/2026:10:48:49 +0300] [Job 9] printer-state-reasons keyword none
D [24/Aug/2026:10:48:49 +0300] [Job 9] ---- end-of-attributes-tag ----
D [24/Aug/2026:10:48:49 +0300] [Job 9] IPP/2.0 Get-Job-Attributes #12
D [24/Aug/2026:10:48:49 +0300] [Job 9] printer-uri uri ipp://BRWF889D2A4AE15.local:631/ipp/print
D [24/Aug/2026:10:48:49 +0300] [Job 9] job-id integer 861
D [24/Aug/2026:10:48:49 +0300] [Job 9] requesting-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:49 +0300] [Job 9] requested-attributes 1setOf keyword job-id,job-impressions-completed,job-media-sheets-completed,job-name,job-originating-user-name,job-state,job-state-reasons
D [24/Aug/2026:10:48:49 +0300] [Job 9] Get-Job-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:49 +0300] [Job 9] requested-attributes keyword job-media-sheets-completed
D [24/Aug/2026:10:48:49 +0300] [Job 9] ---- job-attributes-tag ----
D [24/Aug/2026:10:48:49 +0300] [Job 9] job-impressions-completed integer 0
D [24/Aug/2026:10:48:49 +0300] [Job 9] job-name nameWithoutLanguage Test Page
D [24/Aug/2026:10:48:49 +0300] [Job 9] job-originating-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:49 +0300] [Job 9] job-state enum processing
D [24/Aug/2026:10:48:49 +0300] [Job 9] job-state-reasons 1setOf keyword job-incoming,job-printing
D [24/Aug/2026:10:48:49 +0300] [Job 9] PAGE: total 0
D [24/Aug/2026:10:48:49 +0300] Discarding unused job-progress event...
D [24/Aug/2026:10:48:49 +0300] cupsdMarkDirty(---J-)
D [24/Aug/2026:10:48:49 +0300] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:49 +0300] [Job 9] (monitor) Get-Job-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:49 +0300] [Job 9] (monitor) job-state = processing
D [24/Aug/2026:10:48:50 +0300] [Job 9] IPP/2.0 Get-Printer-Attributes #14
D [24/Aug/2026:10:48:50 +0300] [Job 9] ---- operation-attributes-tag ----
D [24/Aug/2026:10:48:50 +0300] [Job 9] attributes-charset charset utf-8
D [24/Aug/2026:10:48:50 +0300] [Job 9] attributes-natural-language naturalLanguage en-us
D [24/Aug/2026:10:48:50 +0300] [Job 9] printer-uri uri ipp://BRWF889D2A4AE15.local:631/ipp/print
D [24/Aug/2026:10:48:50 +0300] [Job 9] requesting-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:50 +0300] [Job 9] requested-attributes 1setOf keyword compression-supported,copies-supported,cups-version,document-format-supported,job-password-encryption-supported,marker-colors,marker-high-levels,marker-levels,marker-low-levels,marker-message,marker-names,marker-types,media-col-supported,multiple-document-handling-supported,operations-supported,print-color-mode-supported,print-scaling-supported,printer-alert,printer-alert-description,printer-is-accepting-jobs,printer-mandatory-job-attributes,printer-state,printer-state-message,printer-state-reasons
D [24/Aug/2026:10:48:50 +0300] [Job 9] ---- end-of-attributes-tag ----
D [24/Aug/2026:10:48:50 +0300] [Job 9] update_reasons(attr=1(none), s=\"(null)\")
D [24/Aug/2026:10:48:50 +0300] [Job 9] Get-Printer-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:50 +0300] [Job 9] ---- unsupported-attributes-tag ----
D [24/Aug/2026:10:48:50 +0300] [Job 9] requested-attributes 1setOf keyword cups-version,job-password-encryption-supported,marker-message,multiple-document-handling-supported,printer-mandatory-job-attributes,printer-state-message
D [24/Aug/2026:10:48:50 +0300] [Job 9] ---- printer-attributes-tag ----
D [24/Aug/2026:10:48:50 +0300] [Job 9] compression-supported keyword none
D [24/Aug/2026:10:48:50 +0300] [Job 9] copies-supported rangeOfInteger 1-99
D [24/Aug/2026:10:48:50 +0300] [Job 9] document-format-supported 1setOf mimeMediaType application/octet-stream,image/urf,image/jpeg,image/pwg-raster,application/vnd.brother-hbp
D [24/Aug/2026:10:48:50 +0300] [Job 9] marker-colors 1setOf nameWithLanguage #FF00FF[en],#00FFFF[en],#FFFF00[en],#000000[en]
D [24/Aug/2026:10:48:50 +0300] [Job 9] marker-high-levels 1setOf integer 100,100,100,100
D [24/Aug/2026:10:48:50 +0300] [Job 9] marker-levels 1setOf integer 42,61,29,44
D [24/Aug/2026:10:48:50 +0300] [Job 9] marker-low-levels 1setOf integer 16,16,16,15
D [24/Aug/2026:10:48:50 +0300] [Job 9] marker-names 1setOf nameWithLanguage M[en],C[en],Y[en],BK[en]
D [24/Aug/2026:10:48:50 +0300] [Job 9] marker-types 1setOf keyword ink-cartridge,ink-cartridge,ink-cartridge,ink-cartridge
D [24/Aug/2026:10:48:50 +0300] [Job 9] media-col-supported 1setOf keyword media-type,media-size,media-top-margin,media-left-margin,media-right-margin,media-bottom-margin,media-source,media-auto-dimension,media-source-propaties
D [24/Aug/2026:10:48:50 +0300] [Job 9] operations-supported 1setOf enum Print-Job,Validate-Job,Create-Job,Send-Document,Cancel-Job,Get-Job-Attributes,Get-Jobs,Get-Printer-Attributes,Close-Job,Identify-Printer
D [24/Aug/2026:10:48:50 +0300] [Job 9] print-color-mode-supported 1setOf keyword auto,color,monochrome,auto-monochrome
D [24/Aug/2026:10:48:50 +0300] [Job 9] print-scaling-supported 1setOf keyword auto,auto-fit,fill,fit,none
D [24/Aug/2026:10:48:50 +0300] [Job 9] printer-alert octetString code=other
D [24/Aug/2026:10:48:50 +0300] [Job 9] printer-alert-description textWithLanguage Ready[en]
D [24/Aug/2026:10:48:50 +0300] [Job 9] printer-is-accepting-jobs boolean true
D [24/Aug/2026:10:48:50 +0300] [Job 9] printer-state enum idle
D [24/Aug/2026:10:48:50 +0300] [Job 9] printer-state-reasons keyword none
D [24/Aug/2026:10:48:50 +0300] [Job 9] IPP/2.0 Get-Job-Attributes #15
D [24/Aug/2026:10:48:50 +0300] [Job 9] job-id integer 861
D [24/Aug/2026:10:48:50 +0300] [Job 9] requested-attributes 1setOf keyword job-id,job-impressions-completed,job-media-sheets-completed,job-name,job-originating-user-name,job-state,job-state-reasons
D [24/Aug/2026:10:48:50 +0300] [Job 9] Get-Job-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:50 +0300] [Job 9] requested-attributes keyword job-media-sheets-completed
D [24/Aug/2026:10:48:50 +0300] [Job 9] ---- job-attributes-tag ----
D [24/Aug/2026:10:48:50 +0300] [Job 9] job-impressions-completed integer 0
D [24/Aug/2026:10:48:50 +0300] [Job 9] job-name nameWithoutLanguage Test Page
D [24/Aug/2026:10:48:50 +0300] [Job 9] job-originating-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:50 +0300] [Job 9] job-state enum processing
D [24/Aug/2026:10:48:50 +0300] [Job 9] job-state-reasons 1setOf keyword job-incoming,job-printing
D [24/Aug/2026:10:48:50 +0300] [Job 9] PAGE: total 0
D [24/Aug/2026:10:48:50 +0300] Discarding unused job-progress event...
D [24/Aug/2026:10:48:50 +0300] cupsdMarkDirty(---J-)
D [24/Aug/2026:10:48:50 +0300] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:51 +0300] [Job 9] IPP/2.0 Get-Printer-Attributes #16
D [24/Aug/2026:10:48:51 +0300] [Job 9] ---- operation-attributes-tag ----
D [24/Aug/2026:10:48:51 +0300] [Job 9] attributes-charset charset utf-8
D [24/Aug/2026:10:48:51 +0300] [Job 9] attributes-natural-language naturalLanguage en-us
D [24/Aug/2026:10:48:51 +0300] [Job 9] printer-uri uri ipp://BRWF889D2A4AE15.local:631/ipp/print
D [24/Aug/2026:10:48:51 +0300] [Job 9] requesting-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:51 +0300] [Job 9] requested-attributes 1setOf keyword compression-supported,copies-supported,cups-version,document-format-supported,job-password-encryption-supported,marker-colors,marker-high-levels,marker-levels,marker-low-levels,marker-message,marker-names,marker-types,media-col-supported,multiple-document-handling-supported,operations-supported,print-color-mode-supported,print-scaling-supported,printer-alert,printer-alert-description,printer-is-accepting-jobs,printer-mandatory-job-attributes,printer-state,printer-state-message,printer-state-reasons
D [24/Aug/2026:10:48:51 +0300] [Job 9] ---- end-of-attributes-tag ----
D [24/Aug/2026:10:48:51 +0300] [Job 9] update_reasons(attr=1(none), s=\"(null)\")
D [24/Aug/2026:10:48:51 +0300] [Job 9] Get-Printer-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:51 +0300] [Job 9] ---- unsupported-attributes-tag ----
D [24/Aug/2026:10:48:51 +0300] [Job 9] requested-attributes 1setOf keyword cups-version,job-password-encryption-supported,marker-message,multiple-document-handling-supported,printer-mandatory-job-attributes,printer-state-message
D [24/Aug/2026:10:48:51 +0300] [Job 9] ---- printer-attributes-tag ----
D [24/Aug/2026:10:48:51 +0300] [Job 9] compression-supported keyword none
D [24/Aug/2026:10:48:51 +0300] [Job 9] copies-supported rangeOfInteger 1-99
D [24/Aug/2026:10:48:51 +0300] [Job 9] document-format-supported 1setOf mimeMediaType application/octet-stream,image/urf,image/jpeg,image/pwg-raster,application/vnd.brother-hbp
D [24/Aug/2026:10:48:51 +0300] [Job 9] marker-colors 1setOf nameWithLanguage #FF00FF[en],#00FFFF[en],#FFFF00[en],#000000[en]
D [24/Aug/2026:10:48:51 +0300] [Job 9] marker-high-levels 1setOf integer 100,100,100,100
D [24/Aug/2026:10:48:51 +0300] [Job 9] marker-levels 1setOf integer 42,61,29,44
D [24/Aug/2026:10:48:51 +0300] [Job 9] marker-low-levels 1setOf integer 16,16,16,15
D [24/Aug/2026:10:48:51 +0300] [Job 9] marker-names 1setOf nameWithLanguage M[en],C[en],Y[en],BK[en]
D [24/Aug/2026:10:48:51 +0300] [Job 9] marker-types 1setOf keyword ink-cartridge,ink-cartridge,ink-cartridge,ink-cartridge
D [24/Aug/2026:10:48:51 +0300] [Job 9] media-col-supported 1setOf keyword media-type,media-size,media-top-margin,media-left-margin,media-right-margin,media-bottom-margin,media-source,media-auto-dimension,media-source-propaties
D [24/Aug/2026:10:48:51 +0300] [Job 9] operations-supported 1setOf enum Print-Job,Validate-Job,Create-Job,Send-Document,Cancel-Job,Get-Job-Attributes,Get-Jobs,Get-Printer-Attributes,Close-Job,Identify-Printer
D [24/Aug/2026:10:48:51 +0300] [Job 9] print-color-mode-supported 1setOf keyword auto,color,monochrome,auto-monochrome
D [24/Aug/2026:10:48:51 +0300] [Job 9] print-scaling-supported 1setOf keyword auto,auto-fit,fill,fit,none
D [24/Aug/2026:10:48:51 +0300] [Job 9] printer-alert octetString code=other
D [24/Aug/2026:10:48:51 +0300] [Job 9] printer-alert-description textWithLanguage Ready[en]
D [24/Aug/2026:10:48:51 +0300] [Job 9] printer-is-accepting-jobs boolean true
D [24/Aug/2026:10:48:51 +0300] [Job 9] printer-state enum idle
D [24/Aug/2026:10:48:51 +0300] [Job 9] printer-state-reasons keyword none
D [24/Aug/2026:10:48:51 +0300] [Job 9] (monitor) Get-Job-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:51 +0300] [Job 9] (monitor) job-state = processing
D [24/Aug/2026:10:48:52 +0300] [Job 9] IPP/2.0 Get-Printer-Attributes #18
D [24/Aug/2026:10:48:52 +0300] [Job 9] ---- operation-attributes-tag ----
D [24/Aug/2026:10:48:52 +0300] [Job 9] attributes-charset charset utf-8
D [24/Aug/2026:10:48:52 +0300] [Job 9] attributes-natural-language naturalLanguage en-us
D [24/Aug/2026:10:48:52 +0300] [Job 9] printer-uri uri ipp://BRWF889D2A4AE15.local:631/ipp/print
D [24/Aug/2026:10:48:52 +0300] [Job 9] requesting-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:52 +0300] [Job 9] requested-attributes 1setOf keyword compression-supported,copies-supported,cups-version,document-format-supported,job-password-encryption-supported,marker-colors,marker-high-levels,marker-levels,marker-low-levels,marker-message,marker-names,marker-types,media-col-supported,multiple-document-handling-supported,operations-supported,print-color-mode-supported,print-scaling-supported,printer-alert,printer-alert-description,printer-is-accepting-jobs,printer-mandatory-job-attributes,printer-state,printer-state-message,printer-state-reasons
D [24/Aug/2026:10:48:52 +0300] [Job 9] ---- end-of-attributes-tag ----
D [24/Aug/2026:10:48:52 +0300] [Job 9] update_reasons(attr=1(none), s=\"(null)\")
D [24/Aug/2026:10:48:52 +0300] [Job 9] Get-Printer-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:52 +0300] [Job 9] ---- unsupported-attributes-tag ----
D [24/Aug/2026:10:48:52 +0300] [Job 9] requested-attributes 1setOf keyword cups-version,job-password-encryption-supported,marker-message,multiple-document-handling-supported,printer-mandatory-job-attributes,printer-state-message
D [24/Aug/2026:10:48:52 +0300] [Job 9] ---- printer-attributes-tag ----
D [24/Aug/2026:10:48:52 +0300] [Job 9] compression-supported keyword none
D [24/Aug/2026:10:48:52 +0300] [Job 9] copies-supported rangeOfInteger 1-99
D [24/Aug/2026:10:48:52 +0300] [Job 9] document-format-supported 1setOf mimeMediaType application/octet-stream,image/urf,image/jpeg,image/pwg-raster,application/vnd.brother-hbp
D [24/Aug/2026:10:48:52 +0300] [Job 9] marker-colors 1setOf nameWithLanguage #FF00FF[en],#00FFFF[en],#FFFF00[en],#000000[en]
D [24/Aug/2026:10:48:52 +0300] [Job 9] marker-high-levels 1setOf integer 100,100,100,100
D [24/Aug/2026:10:48:52 +0300] [Job 9] marker-levels 1setOf integer 42,61,29,44
D [24/Aug/2026:10:48:52 +0300] [Job 9] marker-low-levels 1setOf integer 16,16,16,15
D [24/Aug/2026:10:48:52 +0300] [Job 9] marker-names 1setOf nameWithLanguage M[en],C[en],Y[en],BK[en]
D [24/Aug/2026:10:48:52 +0300] [Job 9] marker-types 1setOf keyword ink-cartridge,ink-cartridge,ink-cartridge,ink-cartridge
D [24/Aug/2026:10:48:52 +0300] [Job 9] media-col-supported 1setOf keyword media-type,media-size,media-top-margin,media-left-margin,media-right-margin,media-bottom-margin,media-source,media-auto-dimension,media-source-propaties
D [24/Aug/2026:10:48:52 +0300] [Job 9] operations-supported 1setOf enum Print-Job,Validate-Job,Create-Job,Send-Document,Cancel-Job,Get-Job-Attributes,Get-Jobs,Get-Printer-Attributes,Close-Job,Identify-Printer
D [24/Aug/2026:10:48:52 +0300] [Job 9] print-color-mode-supported 1setOf keyword auto,color,monochrome,auto-monochrome
D [24/Aug/2026:10:48:52 +0300] [Job 9] print-scaling-supported 1setOf keyword auto,auto-fit,fill,fit,none
D [24/Aug/2026:10:48:52 +0300] [Job 9] printer-alert octetString code=other
D [24/Aug/2026:10:48:52 +0300] [Job 9] printer-alert-description textWithLanguage Ready[en]
D [24/Aug/2026:10:48:52 +0300] [Job 9] printer-is-accepting-jobs boolean true
D [24/Aug/2026:10:48:52 +0300] [Job 9] printer-state enum idle
D [24/Aug/2026:10:48:52 +0300] [Job 9] printer-state-reasons keyword none
D [24/Aug/2026:10:48:52 +0300] [Job 9] IPP/2.0 Get-Job-Attributes #19
D [24/Aug/2026:10:48:52 +0300] [Job 9] job-id integer 861
D [24/Aug/2026:10:48:52 +0300] [Job 9] requested-attributes 1setOf keyword job-id,job-impressions-completed,job-media-sheets-completed,job-name,job-originating-user-name,job-state,job-state-reasons
D [24/Aug/2026:10:48:52 +0300] [Job 9] Get-Job-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:52 +0300] [Job 9] requested-attributes keyword job-media-sheets-completed
D [24/Aug/2026:10:48:52 +0300] [Job 9] ---- job-attributes-tag ----
D [24/Aug/2026:10:48:52 +0300] [Job 9] job-impressions-completed integer 0
D [24/Aug/2026:10:48:52 +0300] [Job 9] job-name nameWithoutLanguage Test Page
D [24/Aug/2026:10:48:52 +0300] [Job 9] job-originating-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:52 +0300] [Job 9] job-state enum processing
D [24/Aug/2026:10:48:52 +0300] [Job 9] job-state-reasons 1setOf keyword job-incoming,job-printing
D [24/Aug/2026:10:48:52 +0300] [Job 9] PAGE: total 0
D [24/Aug/2026:10:48:52 +0300] Discarding unused job-progress event...
D [24/Aug/2026:10:48:52 +0300] cupsdMarkDirty(---J-)
D [24/Aug/2026:10:48:52 +0300] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:53 +0300] [Client 79] POST /jobs/ HTTP/1.1
D [24/Aug/2026:10:48:53 +0300] cupsdSetBusyState: newbusy="Active clients, printing jobs, and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:53 +0300] [Client 79] Read: status=200, state=6
D [24/Aug/2026:10:48:53 +0300] [Client 79] Authorized as "bogdan" using Basic.
D [24/Aug/2026:10:48:53 +0300] [CGI] argv[0] = "/usr/lib/cups/cgi-bin/jobs.cgi"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[0] = "CUPS_CACHEDIR=/var/cache/cups"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[1] = "CUPS_DATADIR=/usr/share/cups"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[2] = "CUPS_DOCROOT=/usr/share/cups/doc"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[3] = "CUPS_REQUESTROOT=/var/spool/cups"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[4] = "CUPS_SERVERBIN=/usr/lib/cups"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[5] = "CUPS_SERVERROOT=/etc/cups"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[6] = "CUPS_STATEDIR=/run/cups"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[7] = "HOME=/var/spool/cups/tmp"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[8] = "PATH=/usr/lib/cups/filter:/usr/bin:/usr/bin:/bin:/usr/bin"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[9] = "SERVER_ADMIN=root@Yoggy24"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[10] = "SOFTWARE=CUPS/2.4.19"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[11] = "TMPDIR=/var/spool/cups/tmp"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[12] = "USER=root"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[13] = "CUPS_MAX_MESSAGE=2047"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[14] = "CUPS_SERVER=/run/cups/cups.sock"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[15] = "CUPS_ENCRYPTION=IfRequested"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[16] = "IPP_PORT=631"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[17] = "AUTH_TYPE=Basic"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[18] = "LANG=en_US.UTF8"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[19] = "REDIRECT_STATUS=1"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[20] = "GATEWAY_INTERFACE=CGI/1.1"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[21] = "SERVER_NAME=localhost"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[22] = "SERVER_PORT=631"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[23] = "REMOTE_ADDR=[v1.::1]"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[24] = "REMOTE_HOST=localhost"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[25] = "SCRIPT_NAME=/jobs/"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[26] = "SCRIPT_FILENAME=/usr/share/cups/doc/jobs/"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[27] = "REMOTE_USER=bogdan"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[28] = "SERVER_PROTOCOL=HTTP/1.1"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[29] = "HTTP_COOKIE=org.cups.sid=9c941631c475df9d4fd34730a531cfec"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[30] = "HTTP_USER_AGENT=Mozilla/5.0 (X11; Linux x86_64; rv:156.0) Gecko/20100101 Firefox/156.0"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[31] = "HTTP_REFERER=http://localhost:631/printers/Brother_MFC-J3930DW"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[32] = "REQUEST_METHOD=POST"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[33] = "CONTENT_LENGTH=118"
D [24/Aug/2026:10:48:53 +0300] [CGI] envp[34] = "CONTENT_TYPE=application/x-www-form-urlencoded"
D [24/Aug/2026:10:48:53 +0300] cupsdAddCert: Adding certificate for PID 72689
D [24/Aug/2026:10:48:53 +0300] [CGI] Started /usr/lib/cups/cgi-bin/jobs.cgi (PID 72689)
I [24/Aug/2026:10:48:53 +0300] [Client 79] Started "/usr/lib/cups/cgi-bin/jobs.cgi" (pid=72689, file=16)
D [24/Aug/2026:10:48:53 +0300] [Client 79] Waiting for CGI data.
D [24/Aug/2026:10:48:53 +0300] [CGI] org.cups.sid cookie is \"9c941631c475df9d4fd34730a531cfec\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: org.cups.sid=\"9c941631c475df9d4fd34730a531cfec\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: OP=\"cancel-job\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: job_id=\"9\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: job_printer_uri=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: SECTION=\"jobs\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: REFRESH_PAGE=\"\"
D [24/Aug/2026:10:48:53 +0300] cupsdSetBusyState: newbusy="Active clients, printing jobs, and dirty files", busy="Active clients, printing jobs, and dirty files"
D [24/Aug/2026:10:48:53 +0300] [Client 95] Server address is "/run/cups/cups.sock".
D [24/Aug/2026:10:48:53 +0300] [Client 95] Accepted from localhost (Domain)
D [24/Aug/2026:10:48:53 +0300] [Client 95] Waiting for request.
D [24/Aug/2026:10:48:53 +0300] [Client 95] POST /jobs HTTP/1.1
D [24/Aug/2026:10:48:53 +0300] [Client 95] Read: status=200, state=6
D [24/Aug/2026:10:48:53 +0300] [Client 95] No authentication data provided.
D [24/Aug/2026:10:48:53 +0300] [Client 95] 2.0 Cancel-Job 1
D [24/Aug/2026:10:48:53 +0300] Cancel-Job ipp://localhost/jobs/9
D [24/Aug/2026:10:48:53 +0300] cupsdIsAuthorized: requesting-user-name="bogdan"
D [24/Aug/2026:10:48:53 +0300] [Job 9] time-at-completed=1787557733
D [24/Aug/2026:10:48:53 +0300] cupsdMarkDirty(---J-)
D [24/Aug/2026:10:48:53 +0300] Discarding unused job-completed event...
I [24/Aug/2026:10:48:53 +0300] [Job 9] Job canceled by \"bogdan\"
I [24/Aug/2026:10:48:53 +0300] [Job 9] Canceled by "bogdan".
D [24/Aug/2026:10:48:53 +0300] [Client 95] Returning IPP successful-ok for Cancel-Job (ipp://localhost/jobs/9) from localhost.
D [24/Aug/2026:10:48:53 +0300] [Client 95] Content-Length: 75
D [24/Aug/2026:10:48:53 +0300] [Client 95] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [24/Aug/2026:10:48:53 +0300] [Client 95] con->http=0x55a685b40c60
D [24/Aug/2026:10:48:53 +0300] [Client 95] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=75, response=0x55a685a9bd80(IPP_STATE_DATA), pipe_pid=0, file=-1
D [24/Aug/2026:10:48:53 +0300] [Client 95] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [24/Aug/2026:10:48:53 +0300] [Client 95] bytes=0, http_state=0, data_remaining=75
D [24/Aug/2026:10:48:53 +0300] [Client 95] Flushing write buffer.
D [24/Aug/2026:10:48:53 +0300] [Client 95] New state is HTTP_STATE_WAITING
D [24/Aug/2026:10:48:53 +0300] [Job 9] Got SIGTERM.
D [24/Aug/2026:10:48:53 +0300] [Job 9] sigterm_handler: job_canceled = 1.
D [24/Aug/2026:10:48:53 +0300] [Job 9] Canceling print job.
D [24/Aug/2026:10:48:53 +0300] Discarding unused job-progress event...
D [24/Aug/2026:10:48:53 +0300] Discarding unused printer-state-changed event...
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: refresh_page=\"5;URL=http://localhost:631/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: TITLE=\"Jobs\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: SERVER_NAME=\"localhost\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: REMOTE_USER=\"bogdan\"
D [24/Aug/2026:10:48:53 +0300] [CGI] cgiSetVariable: CUPS_VERSION=\"CUPS v2.4.19\"
D [24/Aug/2026:10:48:53 +0300] [Client 79] CGI data ready to be sent.
D [24/Aug/2026:10:48:53 +0300] [Client 79] con->http=0x55a685a05490
D [24/Aug/2026:10:48:53 +0300] [Client 79] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=2147483647, response=(nil)(), pipe_pid=72689, file=16
D [24/Aug/2026:10:48:53 +0300] [Client 79] Script header: Content-Type: text/html;charset=utf-8
D [24/Aug/2026:10:48:53 +0300] [Client 79] Sending status 200 for CGI.
D [24/Aug/2026:10:48:53 +0300] [Client 79] cupsdSendHeader: code=200, type="(null)", auth_type=0
D [24/Aug/2026:10:48:53 +0300] [Client 95] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:10:48:53 +0300] [Client 95] Closing connection.
D [24/Aug/2026:10:48:53 +0300] [Client 79] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_CHUNKED, data_remaining=0, response=(nil)(), pipe_pid=72689, file=16
D [24/Aug/2026:10:48:53 +0300] PID 72689 (/usr/lib/cups/cgi-bin/jobs.cgi) exited with no errors.
D [24/Aug/2026:10:48:53 +0300] [Client 79] Sending 0-length chunk.
D [24/Aug/2026:10:48:53 +0300] [Client 79] Flushing write buffer.
D [24/Aug/2026:10:48:53 +0300] [Client 79] New state is HTTP_STATE_WAITING
D [24/Aug/2026:10:48:53 +0300] [Client 79] Waiting for request.
D [24/Aug/2026:10:48:53 +0300] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Active clients, printing jobs, and dirty files"
D [24/Aug/2026:10:48:53 +0300] [Job 9] IPP/2.0 Get-Printer-Attributes #21
D [24/Aug/2026:10:48:53 +0300] [Job 9] ---- operation-attributes-tag ----
D [24/Aug/2026:10:48:53 +0300] [Job 9] attributes-charset charset utf-8
D [24/Aug/2026:10:48:53 +0300] [Job 9] attributes-natural-language naturalLanguage en-us
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-uri uri ipp://BRWF889D2A4AE15.local:631/ipp/print
D [24/Aug/2026:10:48:53 +0300] [Job 9] requesting-user-name nameWithoutLanguage bogdan
D [24/Aug/2026:10:48:53 +0300] [Job 9] requested-attributes 1setOf keyword compression-supported,copies-supported,cups-version,document-format-supported,job-password-encryption-supported,marker-colors,marker-high-levels,marker-levels,marker-low-levels,marker-message,marker-names,marker-types,media-col-supported,multiple-document-handling-supported,operations-supported,print-color-mode-supported,print-scaling-supported,printer-alert,printer-alert-description,printer-is-accepting-jobs,printer-mandatory-job-attributes,printer-state,printer-state-message,printer-state-reasons
D [24/Aug/2026:10:48:53 +0300] [Job 9] ---- end-of-attributes-tag ----
D [24/Aug/2026:10:48:53 +0300] [Job 9] update_reasons(attr=1(none), s=\"(null)\")
D [24/Aug/2026:10:48:53 +0300] [Job 9] Get-Printer-Attributes: successful-ok-ignored-or-substituted-attributes (successful-ok-ignored-or-substituted-attributes)
D [24/Aug/2026:10:48:53 +0300] [Job 9] ---- unsupported-attributes-tag ----
D [24/Aug/2026:10:48:53 +0300] [Job 9] requested-attributes 1setOf keyword cups-version,job-password-encryption-supported,marker-message,multiple-document-handling-supported,printer-mandatory-job-attributes,printer-state-message
D [24/Aug/2026:10:48:53 +0300] [Job 9] ---- printer-attributes-tag ----
D [24/Aug/2026:10:48:53 +0300] [Job 9] compression-supported keyword none
D [24/Aug/2026:10:48:53 +0300] [Job 9] copies-supported rangeOfInteger 1-99
D [24/Aug/2026:10:48:53 +0300] [Job 9] document-format-supported 1setOf mimeMediaType application/octet-stream,image/urf,image/jpeg,image/pwg-raster,application/vnd.brother-hbp
D [24/Aug/2026:10:48:53 +0300] [Job 9] marker-colors 1setOf nameWithLanguage #FF00FF[en],#00FFFF[en],#FFFF00[en],#000000[en]
D [24/Aug/2026:10:48:53 +0300] [Job 9] marker-high-levels 1setOf integer 100,100,100,100
D [24/Aug/2026:10:48:53 +0300] [Job 9] marker-levels 1setOf integer 42,61,29,44
D [24/Aug/2026:10:48:53 +0300] [Job 9] marker-low-levels 1setOf integer 16,16,16,15
D [24/Aug/2026:10:48:53 +0300] [Job 9] marker-names 1setOf nameWithLanguage M[en],C[en],Y[en],BK[en]
D [24/Aug/2026:10:48:53 +0300] [Job 9] marker-types 1setOf keyword ink-cartridge,ink-cartridge,ink-cartridge,ink-cartridge
D [24/Aug/2026:10:48:53 +0300] [Job 9] media-col-supported 1setOf keyword media-type,media-size,media-top-margin,media-left-margin,media-right-margin,media-bottom-margin,media-source,media-auto-dimension,media-source-propaties
D [24/Aug/2026:10:48:53 +0300] [Job 9] operations-supported 1setOf enum Print-Job,Validate-Job,Create-Job,Send-Document,Cancel-Job,Get-Job-Attributes,Get-Jobs,Get-Printer-Attributes,Close-Job,Identify-Printer
D [24/Aug/2026:10:48:53 +0300] [Job 9] print-color-mode-supported 1setOf keyword auto,color,monochrome,auto-monochrome
D [24/Aug/2026:10:48:53 +0300] [Job 9] print-scaling-supported 1setOf keyword auto,auto-fit,fill,fit,none
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-alert octetString code=other
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-alert-description textWithLanguage Ready[en]
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-is-accepting-jobs boolean true
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-state enum idle
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-state-reasons keyword none
D [24/Aug/2026:10:48:53 +0300] [Job 9] ATTR: auth-info-required=none
D [24/Aug/2026:10:48:53 +0300] load_ppd: Loading /var/cache/cups/Brother_MFC-J3930DW.data...
D [24/Aug/2026:10:48:53 +0300] Brother_MFC-J3930DW: pdl='application/pdf,application/postscript,image/jpeg,image/png,image/pwg-raster,image/urf'
D [24/Aug/2026:10:48:53 +0300] cupsdRegisterPrinter(p=0x55a685b26b90(Brother_MFC-J3930DW))
D [24/Aug/2026:10:48:53 +0300] cupsdMarkDirty(P----)
D [24/Aug/2026:10:48:53 +0300] cupsdSetBusyState: newbusy="Printing jobs and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:53 +0300] [Job 9] PID 72676 (/usr/lib/cups/backend/ipp) exited with no errors.
D [24/Aug/2026:10:48:53 +0300] [Job 9] The following messages were recorded from 10:48:46 to 10:48:53
D [24/Aug/2026:10:48:53 +0300] [Job 9] op=\'-\', new_reasons=1, state_reasons=1
D [24/Aug/2026:10:48:53 +0300] [Job 9] op=\' \', new_reasons=0, state_reasons=1
D [24/Aug/2026:10:48:53 +0300] [Job 9] op=\' \', new_reasons=0, state_reasons=0
D [24/Aug/2026:10:48:53 +0300] [Job 9] End of messages
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-state=3(idle)
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-state-message="Canceling print job."
D [24/Aug/2026:10:48:53 +0300] [Job 9] printer-state-reasons=none
D [24/Aug/2026:10:48:54 +0300] [Job 9] Unloading...
D [24/Aug/2026:10:48:57 +0300] [Client 79] GET /admin HTTP/1.1
D [24/Aug/2026:10:48:57 +0300] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Printing jobs and dirty files"
D [24/Aug/2026:10:48:57 +0300] [Client 79] Read: status=200, state=3
D [24/Aug/2026:10:48:57 +0300] [Client 79] Authorized as "bogdan" using Basic.
D [24/Aug/2026:10:48:57 +0300] cupsdIsAuthorized: username="bogdan"
D [24/Aug/2026:10:48:57 +0300] [Client 79] Processing GET /admin
D [24/Aug/2026:10:48:57 +0300] [CGI] argv[0] = "/usr/lib/cups/cgi-bin/admin.cgi"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[0] = "CUPS_CACHEDIR=/var/cache/cups"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[1] = "CUPS_DATADIR=/usr/share/cups"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[2] = "CUPS_DOCROOT=/usr/share/cups/doc"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[3] = "CUPS_REQUESTROOT=/var/spool/cups"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[4] = "CUPS_SERVERBIN=/usr/lib/cups"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[5] = "CUPS_SERVERROOT=/etc/cups"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[6] = "CUPS_STATEDIR=/run/cups"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[7] = "HOME=/var/spool/cups/tmp"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[8] = "PATH=/usr/lib/cups/filter:/usr/bin:/usr/bin:/bin:/usr/bin"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[9] = "SERVER_ADMIN=root@Yoggy24"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[10] = "SOFTWARE=CUPS/2.4.19"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[11] = "TMPDIR=/var/spool/cups/tmp"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[12] = "USER=root"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[13] = "CUPS_MAX_MESSAGE=2047"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[14] = "CUPS_SERVER=/run/cups/cups.sock"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[15] = "CUPS_ENCRYPTION=IfRequested"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[16] = "IPP_PORT=631"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[17] = "AUTH_TYPE=Basic"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[18] = "LANG=en_US.UTF8"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[19] = "REDIRECT_STATUS=1"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[20] = "GATEWAY_INTERFACE=CGI/1.1"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[21] = "SERVER_NAME=localhost"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[22] = "SERVER_PORT=631"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[23] = "REMOTE_ADDR=[v1.::1]"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[24] = "REMOTE_HOST=localhost"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[25] = "SCRIPT_NAME=/admin"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[26] = "SCRIPT_FILENAME=/usr/share/cups/doc/admin"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[27] = "REMOTE_USER=bogdan"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[28] = "SERVER_PROTOCOL=HTTP/1.1"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[29] = "HTTP_COOKIE=org.cups.sid=9c941631c475df9d4fd34730a531cfec"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[30] = "HTTP_USER_AGENT=Mozilla/5.0 (X11; Linux x86_64; rv:156.0) Gecko/20100101 Firefox/156.0"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[31] = "HTTP_REFERER=http://localhost:631/jobs/"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[32] = "REQUEST_METHOD=GET"
D [24/Aug/2026:10:48:57 +0300] [CGI] envp[33] = "QUERY_STRING="
D [24/Aug/2026:10:48:57 +0300] cupsdAddCert: Adding certificate for PID 72693
D [24/Aug/2026:10:48:57 +0300] [CGI] Started /usr/lib/cups/cgi-bin/admin.cgi (PID 72693)
I [24/Aug/2026:10:48:57 +0300] [Client 79] Started "/usr/lib/cups/cgi-bin/admin.cgi" (pid=72693, file=15)
D [24/Aug/2026:10:48:57 +0300] [Client 79] Waiting for CGI data.
D [24/Aug/2026:10:48:57 +0300] [CGI] admin.cgi started...
D [24/Aug/2026:10:48:57 +0300] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files"
D [24/Aug/2026:10:48:57 +0300] [Client 96] Server address is "/run/cups/cups.sock".
D [24/Aug/2026:10:48:57 +0300] [Client 96] Accepted from localhost (Domain)
D [24/Aug/2026:10:48:57 +0300] [Client 96] Waiting for request.
D [24/Aug/2026:10:48:57 +0300] [CGI] http=0x5558095c7c70
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: SECTION=\"admin\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: REFRESH_PAGE=\"\"
D [24/Aug/2026:10:48:57 +0300] [CGI] org.cups.sid cookie is \"9c941631c475df9d4fd34730a531cfec\"
D [24/Aug/2026:10:48:57 +0300] [CGI] No form data, showing main menu...
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: DEBUG_LOGGING=\"CHECKED\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: REMOTE_ADMIN=\"\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: REMOTE_ANY=\"\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: SHARE_PRINTERS=\"CHECKED\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: USER_CANCEL_ANY=\"\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: KERBEROS=\"\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: BROWSE_WEB_IF=\"\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: PRESERVE_JOBS=\"CHECKED\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: PRESERVE_JOB_HISTORY=\"Yes\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: PRESERVE_JOB_FILES=\"1d\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: MAX_CLIENTS=\"100\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: MAX_JOBS=\"500\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: MAX_LOG_SIZE=\"0\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: TITLE=\"Administration\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: SERVER_NAME=\"localhost\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: REMOTE_USER=\"bogdan\"
D [24/Aug/2026:10:48:57 +0300] [CGI] cgiSetVariable: CUPS_VERSION=\"CUPS v2.4.19\"
D [24/Aug/2026:10:48:57 +0300] [Client 79] CGI data ready to be sent.
D [24/Aug/2026:10:48:57 +0300] [Client 79] con->http=0x55a685a05490
D [24/Aug/2026:10:48:57 +0300] [Client 79] cupsdWriteClient error=0, used=0, state=HTTP_STATE_GET_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=2147483647, response=(nil)(), pipe_pid=72693, file=15
D [24/Aug/2026:10:48:57 +0300] [Client 79] Script header: Content-Type: text/html;charset=utf-8
D [24/Aug/2026:10:48:57 +0300] [Client 79] Sending status 200 for CGI.
D [24/Aug/2026:10:48:57 +0300] [Client 79] cupsdSendHeader: code=200, type="(null)", auth_type=0
D [24/Aug/2026:10:48:57 +0300] [Client 79] cupsdWriteClient error=0, used=0, state=HTTP_STATE_GET_SEND, data_encoding=HTTP_ENCODING_CHUNKED, data_remaining=0, response=(nil)(), pipe_pid=72693, file=15
D [24/Aug/2026:10:48:57 +0300] [Client 96] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:10:48:57 +0300] [Client 96] Closing connection.
D [24/Aug/2026:10:48:57 +0300] PID 72693 (/usr/lib/cups/cgi-bin/admin.cgi) exited with no errors.
D [24/Aug/2026:10:48:57 +0300] [Client 79] Sending 0-length chunk.
D [24/Aug/2026:10:48:57 +0300] [Client 79] Flushing write buffer.
D [24/Aug/2026:10:48:57 +0300] [Client 79] New state is HTTP_STATE_WAITING
D [24/Aug/2026:10:48:57 +0300] [Client 79] Waiting for request.
D [24/Aug/2026:10:48:57 +0300] cupsdSetBusyState: newbusy="Dirty files", busy="Active clients and dirty files"
D [24/Aug/2026:10:49:07 +0300] [Client 79] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:10:49:07 +0300] [Client 79] Closing connection.
D [24/Aug/2026:10:49:07 +0300] cupsdSetBusyState: newbusy="Dirty files", busy="Dirty files"
I [24/Aug/2026:10:49:10 +0300] Saving printers.conf...
I [24/Aug/2026:10:49:10 +0300] Saving job.cache...
D [24/Aug/2026:10:49:10 +0300] cupsdSetBusyState: newbusy="Not busy", busy="Dirty files"
D [24/Aug/2026:10:49:10 +0300] Report: clients=0
D [24/Aug/2026:10:49:10 +0300] Report: jobs=2
D [24/Aug/2026:10:49:10 +0300] Report: jobs-active=0
D [24/Aug/2026:10:49:10 +0300] Report: printers=1
D [24/Aug/2026:10:49:10 +0300] Report: stringpool-string-count=1009
D [24/Aug/2026:10:49:10 +0300] Report: stringpool-alloc-bytes=8648
D [24/Aug/2026:10:49:10 +0300] Report: stringpool-total-bytes=17320
D [24/Aug/2026:10:57:24 +0300] cupsdSetBusyState: newbusy="Active clients", busy="Not busy"
D [24/Aug/2026:10:57:24 +0300] [Client 97] Server address is "[v1.::1]".
D [24/Aug/2026:10:57:24 +0300] [Client 97] Accepted from localhost:50214 (IPv6)
D [24/Aug/2026:10:57:24 +0300] [Client 97] Waiting for request.
D [24/Aug/2026:10:57:24 +0300] cupsdAddCert: Adding certificate for PID 0
D [24/Aug/2026:10:57:24 +0300] Report: clients=1
D [24/Aug/2026:10:57:24 +0300] Report: jobs=2
D [24/Aug/2026:10:57:24 +0300] Report: jobs-active=0
D [24/Aug/2026:10:57:24 +0300] Report: printers=1
D [24/Aug/2026:10:57:24 +0300] Report: stringpool-string-count=1009
D [24/Aug/2026:10:57:24 +0300] Report: stringpool-alloc-bytes=8648
D [24/Aug/2026:10:57:24 +0300] Report: stringpool-total-bytes=17320
D [24/Aug/2026:10:57:30 +0300] [Client 97] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:10:57:30 +0300] [Client 97] Closing connection.
D [24/Aug/2026:10:57:30 +0300] cupsdSetBusyState: newbusy="Not busy", busy="Active clients"490
Dear @ricklinux,
I had version 2.2.3 of the driver from Brother. I have updated to version 2.6.0 which you have supplied the link. Thank you, but it still does not work.
Sometimes the simplest things get overlooked. Have you tried with a different printer cable?
I have also tried to connect the printer by USB cable, but
lsusb
shows me
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 413c:2119 Dell Computer Corp. Dell Secure Link Receiver
Bus 001 Device 016: ID 1bcf:28c4 Sunplus Innovation Technology Inc. 4K Webcam
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 002: ID 0bda:c832 Realtek Semiconductor Corp. 802.11ax WLAN Adapter
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 041e:3289 Creative Technology, Ltd Creative Stage SE
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
This means my USB printer cable is out of order. I have both usbutils and ipp-usb installed. I will change it.
sudo dmesg | grep -i usb
outputs
[ 1166.733403] rtw89_8852cu 4-2:1.0: 2.4 GHz performance may be better in a USB 2 port
[ 1167.685930] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 1168.637934] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 1168.639825] usb usb1-port8: attempt power cycle
[ 1169.654948] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 1170.605955] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 1170.607840] usb usb1-port8: unable to enumerate USB device
[ 3963.042622] usb 1-6: USB disconnect, device number 3
[ 3976.975044] usb usb1-port6: Cannot enable. Maybe the USB cable is bad?
[ 3977.927009] usb usb1-port6: Cannot enable. Maybe the USB cable is bad?
[ 3977.928519] usb usb1-port6: attempt power cycle
[ 3978.942969] usb usb1-port6: Cannot enable. Maybe the USB cable is bad?
[ 3979.894967] usb usb1-port6: Cannot enable. Maybe the USB cable is bad?
[ 3979.896474] usb usb1-port6: unable to enumerate USB device
[ 4168.158484] usb 1-6: new high-speed USB device number 16 using xhci_hcd
[ 4168.367269] usb 1-6: New USB device found, idVendor=1bcf, idProduct=28c4, bcdDevice= 4.18
[ 4168.480278] usb 1-6: New USB device strings: Mfr=1, Product=4, SerialNumber=3
[ 4168.480283] usb 1-6: Product: 4K Webcam
[ 4168.480285] usb 1-6: Manufacturer: SunplusIT Inc
[ 4168.480287] usb 1-6: SerialNumber: 01.00.00
[ 4169.109603] usb 1-6: 3:1: cannot get freq at ep 0x86
[ 4169.499652] usb 1-6: 3:2: cannot get freq at ep 0x86
[ 4169.889699] usb 1-6: 3:3: cannot get freq at ep 0x86
[ 4171.905710] usb 1-6: Warning! Unlikely big volume step count (=3896), linear volume or wrong cval->res?
[ 4171.905716] usb 1-6: [7] FU [Mic Capture Volume] ch = 1, val = 200/4096/1
[ 4189.461440] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 4190.413393] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 4190.415277] usb usb1-port8: attempt power cycle
[ 4191.429384] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 4192.381292] usb usb1-port8: Cannot enable. Maybe the USB cable is bad?
[ 4192.383185] usb usb1-port8: unable to enumerate USB device
I have always printed via Wi-Fi, I own the printer since 2021
lpinfo -v
returns
network beh
network http
network https
network ipp
network ipps
network lpd
file cups-pdf:/
network socket
network smb
network dnssd://Brother%20MFC-J3930DW._ipp._tcp.local/?uuid=e3248000-80ce-11db-8000-b422005f0bdc
network ipp://Brother%20MFC-J3930DW._ipp._tcp.local/
It works now, but I did not install anything extra. Which puzzles me once more. Thank you @joekamprad,@jrichard326, @ricklinux, @xircon. Best wishes from here :slightly_smiling_face: :waving_hand:
sudo tail -n 100 /var/log/cups/error_log
[sudo] password for bogdan:
D [24/Aug/2026:17:28:50 +0300] [Client 237] 2.0 Get-Jobs 1
D [24/Aug/2026:17:28:50 +0300] Get-Jobs ipp://localhost/
I [24/Aug/2026:17:28:50 +0300] [Client 237] Limiting Get-Jobs response to 500 jobs.
D [24/Aug/2026:17:28:50 +0300] [Job 36] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 34] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 29] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 28] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 27] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 26] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 25] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Job 22] Loading attributes...
D [24/Aug/2026:17:28:50 +0300] [Client 237] Returning IPP successful-ok for Get-Jobs (ipp://localhost/) from localhost.
D [24/Aug/2026:17:28:50 +0300] [Client 237] Content-Length: 804
D [24/Aug/2026:17:28:50 +0300] [Client 237] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [24/Aug/2026:17:28:50 +0300] [Client 235] con->http=0x55d15c4c0f80
D [24/Aug/2026:17:28:50 +0300] [Client 235] cupsdWriteClient error=0, used=0, state=HTTP_STATE_GET_SEND, data_encoding=HTTP_ENCODING_CHUNKED, data_remaining=0, response=(nil)(), pipe_pid=11727, file=15
D [24/Aug/2026:17:28:50 +0300] [Client 235] Waiting for CGI data.
D [24/Aug/2026:17:28:50 +0300] [Client 237] con->http=0x55d15c4b5220
D [24/Aug/2026:17:28:50 +0300] [Client 237] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=804, response=0x55d15c4745e0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [24/Aug/2026:17:28:50 +0300] [Client 237] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [24/Aug/2026:17:28:50 +0300] [Client 237] bytes=0, http_state=0, data_remaining=804
D [24/Aug/2026:17:28:50 +0300] [Client 237] Flushing write buffer.
D [24/Aug/2026:17:28:50 +0300] [Client 237] New state is HTTP_STATE_WAITING
D [24/Aug/2026:17:28:50 +0300] [Client 237] Waiting for request.
D [24/Aug/2026:17:28:50 +0300] cupsdSetBusyState: newbusy="Active clients", busy="Active clients"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiClearVariables called.
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: SECTION=\"jobs\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: TOTAL=\"2\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: WHICH_JOBS=\"completed\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: SERVER_NAME=\"localhost\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: REMOTE_USER=\"bogdan\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: CUPS_VERSION=\"CUPS v2.4.19\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_preserved[0]=\"1\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_printer_name[0]=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_printer_uri[0]=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: time_at_completed[0]=\"Mon 24 Aug 2026 05:27:48 PM EEST\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: time_at_creation[0]=\"Mon 24 Aug 2026 05:27:20 PM EEST\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: time_at_processing[0]=\"Mon 24 Aug 2026 05:27:20 PM EEST\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_id[0]=\"36\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_state[0]=\"9\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_impressions_completed[0]=\"4\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_k_octets[0]=\"243\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_hold_until[0]=\"no-hold\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_printer_state_message[0]=\"Unable to detect print-quality, using \'normal\'!\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_preserved[1]=\"0\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_printer_name[1]=\"Brother_MFC-J3930DW\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_printer_uri[1]=\"/printers/Brother_MFC-J3930DW\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: time_at_completed[1]=\"Mon 24 Aug 2026 05:10:30 PM EEST\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: time_at_creation[1]=\"Mon 24 Aug 2026 04:59:37 PM EEST\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: time_at_processing[1]=\"Mon 24 Aug 2026 04:59:37 PM EEST\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_id[1]=\"34\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_state[1]=\"7\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_impressions_completed[1]=\"0\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_k_octets[1]=\"1\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_hold_until[1]=\"no-hold\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetArray: job_printer_state_message[1]=\"cfFilterChain: pdftopdf (PID 5390) stopped with status 1\"
D [24/Aug/2026:17:28:50 +0300] [CGI] cgiSetVariable: THISURL=\"/jobs/\"
D [24/Aug/2026:17:28:50 +0300] [Client 235] CGI data ready to be sent.
D [24/Aug/2026:17:28:50 +0300] [Client 237] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:17:28:50 +0300] [Client 237] Closing connection.
D [24/Aug/2026:17:28:50 +0300] PID 11727 (/usr/lib/cups/cgi-bin/jobs.cgi) exited with no errors.
D [24/Aug/2026:17:28:50 +0300] [Client 235] Sending 0-length chunk.
D [24/Aug/2026:17:28:50 +0300] [Client 235] Flushing write buffer.
D [24/Aug/2026:17:28:50 +0300] [Client 235] New state is HTTP_STATE_WAITING
D [24/Aug/2026:17:28:50 +0300] [Client 235] Waiting for request.
D [24/Aug/2026:17:28:50 +0300] cupsdSetBusyState: newbusy="Not busy", busy="Active clients"
D [24/Aug/2026:17:28:51 +0300] Expiring subscriptions...
D [24/Aug/2026:17:29:00 +0300] [Client 235] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [24/Aug/2026:17:29:00 +0300] [Client 235] Closing connection.
D [24/Aug/2026:17:29:00 +0300] cupsdSetBusyState: newbusy="Not busy", busy="Not busy"
D [24/Aug/2026:17:29:00 +0300] Expiring subscriptions...
D [24/Aug/2026:17:29:01 +0300] Expiring subscriptions...
If you connect it via usb cable then you have to add the printer from cups using usb.
Aug 24 20:24:18 sway-prvt kernel: usb 1-10.4: new high-speed USB device number 14 using xhci_hcd
Aug 24 20:24:19 sway-prvt kernel: usb 1-10.4: New USB device found, idVendor=04f9, idProduct=009e, bcdDevice= 1.00
Aug 24 20:24:19 sway-prvt kernel: usb 1-10.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 24 20:24:19 sway-prvt kernel: usb 1-10.4: Product: HL-L2350DW series
Aug 24 20:24:19 sway-prvt kernel: usb 1-10.4: Manufacturer: Brother
Aug 24 20:24:19 sway-prvt kernel: usb 1-10.4: SerialNumber: E78XXXXX799
Aug 24 20:24:19 sway-prvt systemd[1626]: Reached target Printer.
Aug 24 20:24:19 sway-prvt kernel: usblp 1-10.4:1.0: usblp0: USB Bidirectional printer dev 14 if 0 alt 0 proto 2 vid 0x04F9 pid 0x009E
Aug 24 20:24:19 sway-prvt kernel: usbcore: registered new interface driver usblp
Aug 24 20:24:19 sway-prvt kernel: usblp0: removed
this shows if i plug my HL-L2350DW via usb.
lsusb should indeed show it too:
Bus 001 Device 014: ID 04f9:009e Brother Industries, Ltd HL-L2350DW series
It shows the same up in print dialogue with usb postfix in the name:
[20:34:03] joekamprad :: sway-prvt  ➜  ~ » lpinfo -v
network beh
network http
network https
network ipp
file cups-pdf:/
network socket
network lpd
network ipps
network smb
network dnssd://Brother%20HL-L2350DW%20series._ipp._tcp.local/?uuid=XXXXXX-80ce-11db-8000-XXXXX
network ipp://Brother%20HL-L2350DW%20series._ipp._tcp.local/
And i do not have any PPD package installed at all.
That`s under IPP driverless also still using cups-browsed for comfort.
And to stun you even more, the printer gives the well known error “cfFilterChain: pdftopdf (PID xxxx) stopped with status 1” when I try to print a test page within CUPS (it does not print at all), but prints when used under LibreOffice. I use Arch since 2013, but I’m missing any reasonable explanation :zany_face: . Best wishes to you all.
This looks like a library issue not really printer driver and setup. You triggered Testside print from cups Webinterface ? Or printer settings of Desktop or were?
Yes, I tried to print a test page within the CUPS web interface. All I am trying to understand is why it happens, or if there is a library mismatch
the cups testprint is known to fail in cases. if you can print from office apps and browser without that issue i would not mind.
you may try printing a PDF over browser to validate.
