Broadcom NIC not bringing up second port
What firmware level do you get from ethtool -i?
driver: bnx2x
version: 5.15.16-200.fc35.x86_64
firmware-version: 6.2.15 bc 6.2.10 phy aa0.406
expansion-rom-version:
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
You have a different firmware version but the exact same issue. Do you have the Broadcom software to flash the card firmware?
I did back when it was a windows machine. As long as they have a linux version i can try and flash it.
They do have a linux version as well.
I saw there was two new firmware updates?
Flashing the device may help.
Does it have firmware on the device that can be upgraded?
I believe it does. Broadcom mentioned a few options to try.
I think this issue might be fixed in the kernel. https://lore.kernel.org/all/20220316214613.6884-1-manishc@marvell.com/
Is someone able to test?
