Borked config in /home, can't open gnome settings
Hey,
I have a strange issue with gnome atm and can’t figure out what’s going on. Here’s what happend:
Today I tried some tiling window managers, namely hypr, sway and swayfx. I installed all with yay, except for sway for which I used the install script for the sway community edition of EndeavourOS.
edit. Here’s the script I used: https://github.com/EndeavourOS-Community-Editions/sway, and the configs it copied: https://github.com/EndeavourOS-Community-Editions/sway/tree/main/.config. I don’t see anything in there which would result in this behaviour.
After I was done with testing I decided to log in back to Gnome.
Everything seemed fine, expect for some reason gnome-control-center would not start. I tried reinstalling, rebooting, everything but finally gave up and reinstalled EndeavourOS itself.
After booting everything was fine again so I decided to mount my /home on another partition. All my settings were back but again - I just can’t start gnome settings. Some more information:
  • I tried a full reset of gnome with dconf reset -f /org/gnome/, which wiped all my themes etc just fine but still, no gnome settings
  • Trying to launch gnome-control-center with a terminal doesn’t work either, I don’t even get an error message
  • Everything else works fine. Nautilus, gnome extensions manager, gnome-text-editor, the calculator…
  • When launching settings with Activities or by right-clicking on my desktop I get a spinner for a while
Given that my issue reappeared as soon as I mounted my /home I suspect some borked configs are the culprit.
I would appreciate any help as I do not want to wipe my /home - nor do I want to switch to KDE. Please let me now if you need more information, and if I don’t answer within an hour I probably went to bed. It’s already 1am.
If you run from a terminal does it give any useful messages?
Nothing, no error or any indication that something went wrong.
~$: gnome-control-center
edit.
top > o > command:gnome-control-center doesn’t show anything, too.
a couple thoughts…
Can it launch from the terminal with sudo?
Rename .local and .cache to say .local_OLD and .cache_OLD and see if it launches and rebuilds those folders. (If not, put back your original .local and .cache).
Sudo gives me the same output:
syrma@syrma56x-iota:~$ sudo gnome-control-center
[sudo] password for syrma:
I tried renaming .local first, rebooted - nothing. Tried .cache afterwards and again, nothing. This is so weird. Both folders were rebuild. What happens if I rename .config, will that f- something up?
edit. Just found this file in my /home
.profile
export MOZ_ENABLE_WAYLAND=1
export XDG_CURRENT_DESKTOP=sway
export XDG_SESSION_TYPE=wayland
export WLR_NO_HARDWARE_CURSORS=1
#export WLR_NO_HARDWARE_CURSORS=0
export WLR_RENDERER_ALLOW_SOFTWARE=1
Success! I changed XDG_CURRENT_DESKTOP=sway to XDG_CURRENT_DESKTOP=GNOME, rebooted and now Settings starts again.
Lesson learned: A backup of / is not enough :smiley: Thank you for your help, I appreciate it!
Glad you found it :). You should probably put your original .cache and .local files back the way they were just in case.
