I also push whenever I can. That method is superior. I only pull when the backup source is somewhere that I either can’t or don’t want to run borg on. For example, a NAS device.
These things on Borg really makes me reconsider and try to set it one more time.
I am just struggling with restic, where for 160 GB of data it mounts a drive with more than 1 TB (there are a multitude of folders inside the mount, like hosts
, ids
and snapshots
Currently I have just two snapshots, so I first thought I would have around 320 GB of data, but no almost 1 TB. Strange.
Is it actually using 1TB or is just presenting as 1TB?
Just presenting, as I saw through file manager (I was not able to run ncdu
to check that, because it returned the following error:
thread 2329043 panic: reached unreachable code - Unwind information for :0x58adbdb53d77 was not available, trace may be incomplete).
I prefer restic
and kopia
I was using borgmatic, but found emborg is even simpler and answer my needs (/etc+few home directories backups on local disk).
restic is proving to be fantastic here. Right to my needs.
No restic doesn’t use borg on the back end so you will have to create a fresh back up with it. I switched because I was having some issues with my borg backups getting corrupt. Restic is purely a cli so you will end up having to write your own scripts to automate it. Not that difficult really I have a couple of helper scripts I wrote for myself to keep my setups easy for myself and then I just write a systemd service and timer to fully automate my backups.
Yes, it is really great. Started using it a couple days ago and I am surprised with how easy to setup and great it is.
I am already automating somethings with the first repo via cron and everything looks very good.
I was already “saved” one time through that mount restore feature: just mounted the latest snapshot and was able to pick up a little modified file from there. Really amazing!
