Booting takes long time issue
so this is the output of a boot without any USB Devices connected - at all. Just Ethernet + Screens:
Blame:
3.133s systemd-journald.service
2.518s upower.service
 799ms \x2esnapshots.mount
 758ms NetworkManager.service
 303ms systemd-modules-load.service
 274ms dev-nvme1n1p2.device
 107ms systemd-udev-trigger.service
  99ms systemd-journal-flush.service
  99ms user@1000.service
  82ms systemd-vconsole-setup.service
  67ms udisks2.service
critical-chain:
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @4.372s
└─sddm.service @4.372s
  └─systemd-user-sessions.service @4.366s +3ms
    └─network.target @4.366s
      └─wpa_supplicant.service @4.342s +23ms
        └─basic.target @3.561s
          └─dbus-broker.service @3.543s +17ms
            └─dbus.socket @3.540s
              └─sysinit.target @3.540s
                └─systemd-timesyncd.service @3.494s +45ms
                  └─systemd-tmpfiles-setup.service @3.431s +62ms
                    └─run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount @3.459s
cricitcal-chain systemd-journald.service:
systemd-journald.service +3.133s
└─systemd-journald.socket @190ms
  └─-.mount @157ms
    └─-.slice @157ms
journalctl -b output:
Aug 14 20:22:40 NALX kernel: nvme nvme0: pci function 0000:02:00.0
Aug 14 20:22:40 NALX kernel: nvme nvme1: pci function 0000:05:00.0
Aug 14 20:22:40 NALX kernel: nvme nvme0: D3 entry latency set to 10 seconds
Aug 14 20:22:40 NALX kernel: nvme nvme0: 16/0/0 default/read/poll queues
Aug 14 20:22:40 NALX kernel:  nvme0n1: p1 p2 p3 p4 p5 p6
Aug 14 20:22:40 NALX kernel: nvme nvme1: 16/0/0 default/read/poll queues
Aug 14 20:22:40 NALX kernel:  nvme1n1: p1 p2
Aug 14 20:22:40 NALX kernel: xhci_hcd 0000:0a:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000000200000010
Aug 14 20:22:40 NALX kernel: xhci_hcd 0000:0a:00.0: xHCI Host Controller
Aug 14 20:22:40 NALX kernel: xhci_hcd 0000:0a:00.0: new USB bus registered, assigned bus number 2
Aug 14 20:22:40 NALX kernel: xhci_hcd 0000:0a:00.0: Host supports USB 3.2 Enhanced SuperSpeed
Aug 14 20:22:43 NALX kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.10
Aug 14 20:22:43 NALX kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Aug 14 20:22:43 NALX kernel: usb usb1: Product: xHCI Host Controller
Aug 14 20:22:43 NALX kernel: usb usb1: Manufacturer: Linux 6.10.4-1-cachyos-eevdf xhci-hcd
Aug 14 20:22:43 NALX kernel: usb usb1: SerialNumber: 0000:0a:00.0
Aug 14 20:22:43 NALX kernel: hub 1-0:1.0: USB hub found
Aug 14 20:22:43 NALX kernel: hub 1-0:1.0: 12 ports detected
dmesg:
[    6.577012] systemd-journald[417]: Received client request to flush runtime journal.
[    6.633783] snd_hda_codec_hdmi hdaudioC0D0: HDMI: invalid ELD data byte 41
[    9.652890] block nvme1n1: No UUID available providing old NGUID
[    9.752773] igc 0000:08:00.0 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[   12.186252] usbcore: registered new interface driver snd-usb-audio
[   12.226819] Bluetooth: Core ver 2.22
[   12.226837] NET: Registered PF_BLUETOOTH protocol family
[   12.226838] Bluetooth: HCI device and connection manager initialized
[   12.226843] Bluetooth: HCI socket layer initialized
[   12.226844] Bluetooth: L2CAP socket layer initialized
[   12.226847] Bluetooth: SCO socket layer initialized
[   12.241048] usbcore: registered new interface driver btusb
[   12.257433] Bluetooth: hci0: HW/SW Version: 0x008a008a, Build Time: 20240716163633
[   33.083896] Bluetooth: hci0: Device setup in 20354358 usecs
[   33.083902] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
[   33.369339] Bluetooth: hci0: AOSP extensions version v1.00
[   33.369345] Bluetooth: hci0: AOSP quality report is supported
[   58.820039] usb 5-2.4: new full-speed USB device number 3 using xhci_hcd
idk, I feel out of luck somehow… thinking about giving EOS a shot and see how (if?) it behaves differently.
BIOS is up to date as well, idk what more it could be (other than a HW failure of the USB Bus, but a bit suspicious, since its working absolutely fine once booted)…
it seems solved. I started up just now, had a Kernel Update (to 6.10.5-1) rebooted and…its gone!
825ms \x2esnapshots.mount
756ms NetworkManager.service
316ms systemd-modules-load.service
256ms dev-nvme1n1p2.device
105ms user@1000.service
103ms systemd-udev-trigger.service
 89ms systemd-vconsole-setup.service
 80ms systemd-tmpfiles-setup-dev-early.service
 79ms upower.service
 69ms udisks2.service
systemd-journald.service +64ms
└─systemd-journald.socket @183ms
  └─-.mount @165ms
    └─-.slice @165ms
and no strange timegaps in dmesg / journalctl -b
seems like t’was a kernel issue somehow :man_shrugging:
anyways:
Thank you very much for taking your time and looking into it and trying to help. Very very very much appreciated!
@ricklinux
Wanted to mark the post as solved, but I don’t seem to have the rights to edit my original post anymore? maybe you can help me out? :upside_down_face:
Just mark your last post as the solution.
Where did you get that from?
It is not even in the Testing repo yet.
it’s the cachyos (eevdf) one, they’re always ahead of the “rolling” ones … when I started using Linux, I got told to use their kernel, as it is the best in terms of (gaming) performance, so as a newb did that and was always happy with it … so yeah
I see.
It would be good then to state that when you’re asking for assistance for a system that by standard uses the kernels from the official repos. So in this case it was CachyOS’ kernel issue then not Arch/EnOS.
I like your thinking. Most would be telling you to use lts. I like rolling or better. :rofl:
sincere apologies then, I stated it in the original post, that I’m using the CachyOS Kernel:
I’m not using EOS (yet? ;)) using Arch with the CachyOS Kernel (…)
Since I had the issue as well on the Standard, LTS and Zen Kernel, I didn’t feel the need to go into more detail …
I must have forgotten that. Bad memory, sorry!
A fair point. I think I would have come to the same conclusion :+1:
I did the same thing so don’t feel bad. :wink:
