Boot Stuck wpa supplicant
I’m added th is option using “e” key after that didn’t know how to save it so using crtl+x to boot and the problem exist I don’t know if doing right but btw I export a log too if help…
journal.odt (190.7 KB)
2022-10-24_12-03_1
it is used as i can see…
and nvidia is still failing:
systemd-coredump[1180]: Process 1049 (Xorg) of user 0 dumped core.
Module libnvidia-glcore.so.515.76 with build-id adb7541feaf87c8fbb8f48f94f6687c535eee896
If you have internet conmnection make sure you do system update to latest packages… if not try that and reboot… and if it still not load x session go remove nvidia driver and us nouveau to see if this is leading to a working x-system.
use nvidia-inst tool:
yay -Syu --needed nvidia-inst
nvidia-inst -n to reset to nvidia open source drivers.
Problem exist.
jou.odt (365.7 KB)
still xorg core dumps on you also now running nouveau drivers… must be something else screwed and without knowing what exatly you see on booting i can not help much…
How can I show you that?
you can write what exactly happens i have no connection to what you see or what happen when you boot up…
