Boot delay troubleshooting and fix (pmouse)
Hi all, since a week or 2 after a kernel update i had alot of weird boots delays. After some digging and using ChatGPT to rule things out “we” managed to track down the issue. Anyone knows what got changed in the kernel ? i never got this issue before.
Here are the results, maybe someone has the same issue and can make use of this post.
EndeavourOS – MSI Crosshair 15 boot delay troubleshooting and fix
System
  • Laptop: MSI Crosshair 15 B12UGSZ
  • OS: EndeavourOS / Arch Linux
  • Kernel: 7.2.7-arch1-1
  • Initramfs: dracut 112
  • NVIDIA driver: 615.71.09
  • Storage: 2× Samsung 990 PRO 4 TB
  • Bootloader: systemd-boot
  • Desktop: KDE Wayland
  • Touchpad: I²C, disabled
  • Mouse: USB G5 mouse
1. Identify the boot delay
The laptop originally took approximately 21 seconds to boot.
We checked the boot time with:
systemd-analyze
Original result:
Startup finished in 5.409s (firmware)
+ 0.842s (loader)
+ 1.981s (kernel)
+ 8.353s (initrd)
+ 4.557s (userspace)
= 21.145s
The main problem was clearly the 8.353 seconds spent in the initrd.
2. Inspect the boot log
We checked the boot log with:
journalctl -b 0 -o short-monotonic --no-pager
The important messages were related to psmouse and serio1.
For example:
psmouse serio1: Failed to reset mouse on isa0060/serio1: -71
Later:
psmouse serio1: Failed to deactivate mouse on isa0060/serio1: -71
and:
psmouse serio1: Failed to enable mouse on isa0060/serio1
The timing showed that the PS/2 mouse initialization was taking several seconds.
A PS/2 Generic Mouse was eventually detected as well.
3. Check which input devices are actually present
We checked the input devices with:
cat /proc/bus/input/devices | grep -A6 -B2 -i 'mouse\|ps/2'
The system has:
USB mouse
USB Optical Mouse
Vendor=30fa Product=0400
This is the USB G5 mouse.
I²C touchpad
MSNB0001:00 06CB:7E7E Mouse
This is the laptop’s I²C touchpad.
PS/2 mouse
The problematic device appeared as:
PS/2 Generic Mouse
This was associated with the serio1 interface and psmouse.
4. Check the input device nodes
We also checked:
ls -l /sys/class/input/
Before the fix, a PS/2 mouse device was present as a mouse3 device.
The important distinction was:
serio0 → PS/2/AT keyboard
serio1 → PS/2 mouse
We did not want to disable the entire i8042 controller because the keyboard still uses serio0.
5. Check the psmouse module
We inspected the module with:
modinfo psmouse
and checked whether it was loaded:
lsmod | grep psmouse
It showed:
psmouse 245760 0
This confirmed that the Linux psmouse driver was loaded.
6. Perform a temporary test
Before making any permanent changes, we tested whether psmouse was actually responsible for the delay.
A temporary kernel parameter was added during boot:
modprobe.blacklist=psmouse
After booting, we verified it with:
cat /proc/cmdline
and:
The latter returned no output.
We then measured the boot time again:
systemd-analyze
The initrd time dropped from approximately:
8.35 seconds
to approximately:
2.89 seconds
This was the decisive test.
The temporary psmouse blacklist removed roughly 5.5 seconds from the initrd boot time.
7. Make the fix permanent with dracut
Because the system uses dracut, we did not modify mkinitcpio.
We created:
sudo nano /etc/dracut.conf.d/20-no-psmouse.conf
The file contains:
omit_drivers+=" psmouse "
This tells dracut:
Do not include the psmouse module in the initramfs.
The kernel module itself was not removed from the system.
8. Rebuild the kernel/initramfs
We rebuilt the kernel images with:
sudo reinstall-kernels
The output included:
Installing kernel 7.2.7-arch1-1
9. Verify that psmouse was removed from the initramfs
First we located the correct initramfs:
find /efi -name 'initrd*' -o -name '*7.2.7*'
The normal initramfs was:
/efi/38fdd1fb90724b55b7ba0eb5f909633d/7.2.7-arch1-1/initrd
We then checked its contents:
sudo lsinitrd /efi/38fdd1fb90724b55b7ba0eb5f909633d/7.2.7-arch1-1/initrd | grep psmouse
There was no output.
This confirmed that psmouse was no longer included in the normal initramfs.
10. Reboot and measure the result
After rebooting, we ran:
systemd-analyze
The new result was:
Startup finished in 5.578s (firmware)
+ 733ms (loader)
+ 1.849s (kernel)
+ 2.880s (initrd)
+ 3.848s (userspace)
= 14.890s
Comparison:
Component Before After
Firmware 5.409 s 5.578 s
Loader 0.842 s 0.733 s
Kernel 1.981 s 1.849 s
Initrd 8.353 s 2.880 s
Userspace 4.557 s 3.848 s
Total 21.145 s 14.890 s
The total boot time improved by approximately:
21.145 - 14.890 = 6.255 seconds
So the laptop now boots approximately 6.3 seconds faster.
11. Verify that the psmouse errors are gone
We checked the new boot log with:
journalctl -b 0 -o short-monotonic --no-pager | grep -E 'psmouse|serio1|dracut'
The dracut initqueue now completed much earlier:
2.444789 Starting dracut initqueue hook
4.476815 Finished dracut initqueue hook
There were no longer any psmouse or serio1 errors.
12. Check why psmouse still appears in lsmod
After the reboot:
still showed:
psmouse 245760 0
We investigated this rather than immediately changing anything.
First:
systemctl status systemd-modules-load.service --no-pager
It showed:
Active: active (exited)
status=0/SUCCESS
Then:
journalctl -b 0 | grep -i psmouse
returned no output.
And:
grep -Rni psmouse /etc/modprobe.d /etc/modules-load.d 2>/dev/null
also returned no output.
So there was no explicit configuration loading psmouse.
13. Check the actual input devices again
We ran:
The current mouse devices were:
mouse0 → USB Optical Mouse
mouse1 → I²C touchpad
mouse2 → I²C touchpad
There was no mouse3 anymore.
We also checked:
and confirmed that only:
mouse0
mouse1
mouse2
were present.
The old PS/2 Generic Mouse device was gone.
The PS/2 keyboard was still present through:
i8042/serio0
so the keyboard was unaffected.
Final result
The original boot problem was caused by the PS/2 mouse / psmouse initialization on serio1 during the dracut/initramfs stage.
The problematic sequence was essentially:
i8042
 ├── serio0 → keyboard → OK
 └── serio1 → PS/2 mouse → psmouse errors/delay
The permanent solution was:
containing:
followed by:
The result was:
21.145 seconds → 14.890 seconds
or approximately:
6.3 seconds faster boot time.
The initrd itself improved from:
8.353 seconds → 2.880 seconds
The USB mouse, keyboard and other input devices remain functional.
Commands used for the final fix
The essential commands were:
systemd-analyze
modinfo psmouse
Temporary test:
Permanent configuration:
with:
Rebuild:
Verify initramfs:
Verify after reboot:
And finally:
Final status: problem solved.
Very nice methodology! Glad you got to the bottom of your lag. I have the opposite problem on my desktop system, all my delay is in the firmware (12s before I even see the boot menu), although I can shave a few seconds off the initrd times. When I find some free time I’ll dig into optimizing.
Startup finished in 12.786s (firmware)
+5.653s (loader)
+548ms (kernel)
+7.229s (initrd)
+3.877s (userspace) = 30.095s
My laptop has a very different boot sequence where there’s a huge delay in the userspace. Interesting…
Startup finished in 7.855s (firmware)
+ 3.858s (loader)
+ 1.669s (kernel)
+ 1.685s (initrd)
+ 21.231s (userspace) = 36.299s
