After the kernel update and moving to pipewire, I couldn’t be able to power on the bluetooth. I tried restarting service and system, but couldn’t figure out the problem from logs.
Thanks
bluetoothctl
[bluetooth]# power on
Failed to set power on: org.bluez.Error.Failed
systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Wed 2021-07-28 11:30:55 IST; 16min ago
Docs: man:bluetoothd(8)
Main PID: 10972 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 9317)
Memory: 940.0K
CPU: 75ms
CGroup: /system.slice/bluetooth.service
└─10972 /usr/lib/bluetooth/bluetoothd
Jul 28 11:30:55 ceph bluetoothd[10972]: Endpoint registered: sender=:1.30 path=/MediaEndpoint/A2D>
Jul 28 11:30:55 ceph bluetoothd[10972]: Failed to add UUID: Busy (0x0a)
Jul 28 11:31:54 ceph bluetoothd[10972]: Path / reserved for Adv Monitor app :1.113
Jul 28 11:32:40 ceph bluetoothd[10972]: Failed to set mode: Failed (0x03)
Jul 28 11:33:42 ceph bluetoothd[10972]: Adv Monitor app :1.113 disconnected from D-Bus
rfkill list
0: asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: asus-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 13d3:56dd IMC Networks USB2.0 HD UVC WebCam
Bus 001 Device 002: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 004: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
journalctl -b | grep blue
http://ix.io/3uhA
inxi -Fxzmc0 --no-host
System: Kernel: 5.13.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.22.4 Distro: EndeavourOS base: Arch Linux
Machine: Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412FAC_X412FA v: 1.0
serial: <filter>
Mobo: ASUSTeK model: X412FAC v: 1.0 serial: <filter> UEFI: American Megatrends
v: X412FAC.303 date: 07/17/2020
CPU: Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake
note: check rev: C cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33599
Speed: 800 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel bus-ID: 00:02.0
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3
Display: x11 server: X.org 1.20.12 driver: loaded: intel
unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
Audio: Device-1: Intel Comet Lake PCH-LP cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.13.5-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.19 running: no
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.32 running: yes
Network: Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel port: 3000
bus-ID: 00:14.3
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb
v: 0.8 bus-ID: 1-10:4
Report: bt-adapter ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
rfk-block: hardware: no software: no address: <filter>
hwinfo --bluetooth
01: USB 00.0: 11500 Bluetooth Device
[Created at usb.122]
Unique ID: fHJ1.l3v0gVevrhC
Parent ID: k4bc.2DFUsyrieMD
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-10/1-10:1.0
SysFS BusID: 1-10:1.0
Hardware Class: bluetooth
Model: "Intel Bluetooth 9460/9560 Jefferson Peak (JfP)"
Hotplug: USB
Vendor: usb 0x8087 "Intel Corp."
Device: usb 0x0aaa "Bluetooth 9460/9560 Jefferson Peak (JfP)"
Revision: "0.02"
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v8087p0AAAd0002dcE0dsc01dp01icE0isc01ip01in00"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #4 (Hub)
paru -Qs blue
local/bluedevil 1:5.22.4-1 (plasma)
Integrate the Bluetooth technology within KDE workspace and applications
local/bluez-git 1:5.60.r17.gb497b5942-1
Libraries and tools for the Bluetooth protocol stack
local/bluez-qt 5.84.0-1 (kf5)
Qt wrapper for Bluez 5 DBus API
local/bluez-tools 0.2.0-5
A set of tools to manage Bluetooth devices for Linux
local/hidapi 0.10.1-1
Simple library for communicating with USB and Bluetooth HID devices
local/libldac 2.0.2.3-1
LDAC Bluetooth encoder library
local/pipewire-pulse 1:0.3.32-1
Low-latency audio/video router and processor - PulseAudio replacement
local/sbc 1.5-2
Bluetooth Subband Codec (SBC) library
