Have you tried
sudo modprobe btusb
Have you tried
sudo modprobe btusb
Yes. Every time I try something I reboot then Ctrl+R to this command: sudo modprobe btusb && sudo modprobe btrtl && sudo systemctl enable --now bluetooth && sleep 2 && sudo bluetoothctl
When you get done trying all this do you remove those packages and blacklist edits and reboot? Maybe you can do that if no progress and make sure WiFi is working and provide the following.
sudo dmesg | eos-sendlog
journalctl -b | eos-sendlog
Blacklists removed, packages removed, Iām sending this via WiFi haha, here they are:
sudo dmesg
: https://0x0.st/okJt.txt
journalctl -b
: https://0x0.st/okJx.txt
Btw I really appreciate the quick responses thanks a lot
Did you also check rfkill for anything being blocked?
I tried rfkill
just now (with no packages), same output as here ^
I see this so far.
[ 27.029644] Bluetooth: Core ver 2.22
[ 27.029664] NET: Registered PF_BLUETOOTH protocol family
[ 27.029665] Bluetooth: HCI device and connection manager initialized
[ 27.029668] Bluetooth: HCI socket layer initialized
[ 27.029670] Bluetooth: L2CAP socket layer initialized
[ 27.029672] Bluetooth: SCO socket layer initialized
[ 27.045012] usbcore: registered new interface driver btusb
Do you have dual boot with Windows?
Have you tried disabling usb auto suspend? You can use a kernel parameter in the default grub command line in /etc/default/grub
then you need to update grub with sudo grub-mkconfig -o /boot/grub/grub.cfg
Then reboot and see if any cahnge.
I donāt really see anything that shows why it shouldnāt be working. Is this a laptop? Do you have bluetooth turned on?
I canāt find any line with āusbā or āsuspendā inside /etc/default/grub
. What should I type exactly? I searched online a couple minutes but I see different options
Yes itās a HP laptop. As for the second questionā¦Iād say I donāt know for sure haha, Iād guess so because sudo systemctl status bluetooth
says bluetooth.service is enabled. What else can I check if you need a more definite answer?
You use nano to edit the default grub command line.
sudo nano /etc/default/grub
In the default grub command line add the following.
usbcore.autosuspend=-1
ctrl + o then enter to save
ctrl + x to exit nano
Then update grub
Then reboot and see.
Edit: I donāt know if this is going to work but itās worth the try.
Nope, same result as before unfortunately
Can you tell me which HP model it is? Maybe i can look up what keys turn on the bluetooth?
Edit:
systemctl status bluetoothd
Unit bluetoothd.service could not be found.
Ya the problem is with HP unless you have the model and serail number they donāt give you any info on the website.
Do you know the model name?
Edit:
rfkill list all
The model name is HP 15-dw0xxx, Iāll send you the serial number to avoid sharing it here.
$ rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
Try
sudo modprobe -r btusb
sudo modprobe btusb
