as the title says. Using GNOME, I cannot turn Bluetooth on. It’s like it’s disabled permanently. Inbuilt bluetooth controller on Motherboard.
Check the output of rfkill
If it says Bluetooth is hard blocked then you have a physical switch somewhere, or you disabled it in the BIOS.
Nooo. It works out of the box on 3 other distros I’ve tried so incorrect
I had this same post like 6 months ago.
“It’s like de je vu all over again”
Yogi Berra
