Hello!
I am having an issue where I am unable to play audio through my bluetooth headphones (the sony 1000mx3). I understand so far that the issue is due to the fact that these are noise cancelling headphones so there might be some issues there, and I have to do something with audio sinks, which I am unsure of.
I have already tried this to no avail.
, the arch wiki is your friend! Generally better than Manjaro forum, because Manjaro sometimes uses their own twist of commands etc. and packages, slightly different from arch.
yes in a lot cases it helps to do the connection the first time with bluetoothctl (using sudo), after this was working it should work just fine from GUI next timeβ¦
