Bluetooth headphone keeps disconnecting
One more thing to add and that is I have the Soundcore Space One Pro’s and they expressly require BlueTooth 5.4.
I have never used bluetooth for anything, but here goes nothing.
What DE are you using? There are different bluetooth drivers, such as bluez, bluefish, blueman, bluedevil, and maybe more. Have you tried any of these?
Pudge
Ooops, sorry @Locutus, I used the wrong Reply arrow.
I’m using Plasma. I have bluedevil and blueman installed. I’ve tried both.
No worries, I’ll reply as well in case it helps. I’m currently using RebornOS with Plasma 6.5.4. On a side note the default Bluetooth apps that most Arch based distros include should work without issue with any Soundcore headphones.
Seems related - still a problem:
and:
I got the same issues, constatnt reconnecting of BT headphones. lastest everything for totay, fresh instalation of the latest build. the same in cachyos
Edit:
nano ~/.config/kdeconnect/config
add this line in [General] section:
[General]
disabled_providers=AsyncLinkProvider
this will solve the issue with KDE and BT in Arch.
