Bluetooth adapters are not recognized
Hi. After today update I have got two problem.
❯ uname -a
Linux stey 6.6.51-1-lts #1 SMP PREEMPT_DYNAMIC Thu, 12 Sep 2024 11:23:10 +0000 x86_64 GNU/Linux
  1. On boot and getting SDDM welcome screen both keyboard and mouse don’t work (of course, the do in BIOS). To “resolve” the problem I need to remove Bluetooth USB adapter on booting (yes, it is very strang magic, but I have tried fiew times, and it doesn’t depend on concrete adapter, I have got few different of them).
  2. After booting wityout BT adapter and inserting it after entering a system (KDE) I don’t get bluetooth. Fragment of dmesg:
[ 8321.677794] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8321.677796] usb 1-1.4: Product: TP-Link UB500 Adapter
[ 8321.677798] usb 1-1.4: Manufacturer:
[ 8321.677799] usb 1-1.4: SerialNumber: E848B8C82000
And from systemd status:
○ bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: inactive (dead)
       Docs: man:bluetoothd(8)
окт 01 21:13:57 stey systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
окт 01 23:10:00 stey systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
окт 01 23:12:00 stey systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Please, any ideas?
Are you able to try booting with the standard kernel and see if the issue remains consistent?
@student975
sudo systemctl enable --now bluetooth
Yes, and keyboard with mouse lock on SDDM regardless adapter presence.
Nothing changes.
Probably it is another sign of the problem: on KDE session logout (or shutdown) I get black screen with mouse cursor. So I am forced to Ctrl-Alt-Fn to go to termianl and restart sddm (or use poweroff to shutdown.). X11 is in use.
Ok, magic has gone. There were a problem (probably introduced by mine) with kernel update. I have resolved it (in fact reinstalled kernels and few eos packages), and everything does work.
