Bluedevil says adaptors not found
My laptop had Manjaro xfce and hyprland until yesterday 20th may 2024. Bluetooth worked fabulously.
Shifting to endeavour now shows that bluetooth adapters are not found.
Probably relevant logs:
lsusb
Bus 001 Device 003: ID 0489:e0cd Foxconn / Hon Hai MediaTek Bluetooth Adapter
sudo dmesg | grep blue
[ 5.905751] bluetooth hci0: Direct firmware load for mediatek/BT_RAM_CODE_MT7961_1a_2_hdr.bin failed with error -2
lsmod | grep btusb
btusb 86016 0
btrtl 32768 1 btusb
btintel 65536 1 btusb
btbcm 24576 1 btusb
btmtk 12288 1 btusb
bluetooth 1122304 15 btrtl,btmtk,btintel,btbcm,bnep,btusb
inxi -Fza --no-host
Bluetooth:
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3
chip-ID: 0489:e0cd class-ID: e001 serial:
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
I am dual booting and bluetooth never worked on windows, but that’s a gaming part only so I never cared about bluetooth there.
Not being in the best state of mid will reference you to here
https://wiki.archlinux.org/title/bluetooth
As a sidenote have seen a few people over the last day or so post about BT issues, have you tried using a different kernel?
changing to LTS kernel solved the problem
Nice that you could solve this, when the next update comes out maybe try the mainline kernel again and if it don’t work as you know now you can easily select the LTS one (this is what I stick to as there have been shutdown/reboot issues on my sysytem in the past)
