I need to diagnose a Win10 PC. The AUR has many version of teamviewer. Is that the best way to remotely connect to a win10 PC?
Easiest for sure
After installation don’t forget to start teamviewerd
service , it won’t work without it
Which version is best?
I usually use just latest non beta:
yay -S teamviewer
Anydesk also works well.
+1 for Anydesk
Supremo Free also works, but requires Wine on the linux client.
If the machine is always on and well firewalled ( and best behind a VPN), then you could possible set up a connection via tightvnc or RDP.
teamviewer is the one to go for on this task…
