Hi, I have been scouring forums and websites and guides for the last two weeks since I have installed endeavourOS because I cannot get any sound to come from my lap top so at this point I do not even know where to go anymore so I figured I will just directly ask here. I know the sound is unmuted and the system shows that there should be sound coming from my laptop if I am playing something but nothing comes out. I do have sof-firmware installed as well as ALSA and am running PipeWire. This is what comes up when I run inxi -Aa
First up, let see whether sound is actually running but not coming out or not.
In terminal,
type speaker-test and return the output.
If it shows something like :
┬─[deweshk@HomeDesktop:~]─[09:33:30 PM IST]
╰─>$ speaker-test
speaker-test 1.2.7
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 128 to 2097152
Period size range from 64 to 1048576
Using max buffer size 2097152
Periods = 4
was set period_size = 524288
was set buffer_size = 2097152
0 - Mono
Time per period = 11.219079
0 - Mono
Time per period = 11.007013
0 - Mono
Time per period = 11.007174
0 - Mono
Then speakers are working and issues are with PulseAudio.
