Battery stays on 92%
Hi all,
I am on Bspwm, and I just figured that battery is always on 92%, while my laptop is on charger.
  Kernel: 5.12.9-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux
  root=UUID=574fa5e5-e713-44af-b74e-38874d97dc0d rw quiet loglevel=3
  nowatchdog
  Desktop: bspwm 0.9.10 info: polybar vt: 7 dm: LightDM 1.30.0
  Type: Convertible System: HP product: HP ENVY x360 Convertible 13-ar0xxx
  v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.23
  date: 02/05/2021
Battery:
  ID-1: BAT0 charge: 33.3 Wh (93.0%) condition: 35.8/655.4 Wh (5.5%)
  volts: 17.2 min: 15.4 model: 333-2B-49-A KC04053XL type: Li-ion
  serial: <filter> status: Unknown
  Device-1: hid-0018:04F3:23B9.0001-battery model: ELAN2514:00 04F3:23B9
  serial: N/A charge: N/A status: N/A
Memory:
  RAM: total: 5.74 GiB used: 1.44 GiB (25.0%)
  RAM Report:
  missing: Required tool dmidecode not installed. Check --recommends
  Info: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
  bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
  model-id: 18 (24) stepping: 1 microcode: 8108109 cache: L2: 2 MiB
  bogomips: 33550
  Speed: 2374 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
  1: 2374 2: 2087 3: 1386 4: 1398 5: 1239 6: 1262 7: 1261 8: 1300
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
  bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
  cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
  mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
  npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
  perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
  rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
  smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
  topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
  xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Vulnerabilities: Type: itlb_multihit status: Not affected
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP:
  disabled, RSB filling
  Device-1: AMD Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel
  bus-ID: 04:00.0 chip-ID: 1002:15d8 class-ID: 0300
  Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
  bus-ID: 3-1:2 chip-ID: 04ca:709d class-ID: 0e02
  Display: x11 server: X.Org 1.20.11 compositor: picom v: git-dac85 driver:
  loaded: amdgpu,ati unloaded: fbdev,modesetting,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2")
  s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 166 size: 293x165mm (11.5x6.5")
  diag: 336mm (13.2")
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
  class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
  vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel
  alternate: snd_rn_pci_acp3x bus-ID: 04:00.5 chip-ID: 1022:15e2
  class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
  class-ID: 0403
  Sound Server-1: ALSA v: k5.12.9-arch1-1 running: yes
  Sound Server-2: JACK v: 0.125.0 running: no
  Sound Server-3: PulseAudio v: 14.2 running: yes
  Sound Server-4: PipeWire v: 0.3.29 running: no
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
  vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
  port: f000 bus-ID: 02:00.0 chip-ID: 10ec:b822 class-ID: 0280
  IP v4: <filter> type: dynamic noprefixroute scope: global
  broadcast: <filter>
  IP v6: <filter> type: dynamic noprefixroute scope: global
  IP v6: <filter> type: noprefixroute scope: link
  WAN IP: <filter>
Bluetooth:
  Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
  v: 0.8 bus-ID: 3-2:3 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
  Report: This feature requires one of these tools: hciconfig/bt-adapter
Logical:
  Permissions: Unable to run lvs. Root privileges required.
RAID:
  Message: No RAID data was found.
  Local Storage: total: 476.94 GiB used: 6.05 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H
  size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: HPS0 scheme: GPT
  Message: No Optical or Floppy data was found.
  ID-1: / raw-size: 232.3 GiB size: 227.59 GiB (97.97%) used: 5.47 GiB (2.4%)
  fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  uuid: 574fa5e5-e713-44af-b74e-38874d97dc0d
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
  used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: NO_LABEL uuid: 5923-E3DE
  ID-3: /home raw-size: 244.14 GiB size: 239.25 GiB (98.00%)
  used: 592.6 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  label: N/A uuid: 51946a01-b5a0-4a3a-b65c-091e7f9d024d
  Alert: No Swap data was found.
Unmounted:
  Message: No Unmounted partitions found.
USB:
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-3:2 info: Xenta 2.4GHz Receiver (Keyboard and Mouse)
  type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
  speed: 1.5 Mb/s power: 100mA chip-ID: 1d57:32da class-ID: 0300
  Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A
  interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00d2
  class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 3-1:2 info: Lite-On HP Wide Vision HD Camera type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 3-2:3 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth
  driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 53.5 C mobo: 43.0 C gpu: amdgpu temp: 53.0 C
  Fan Speeds (RPM): N/A
  Processes: 237 Uptime: 3h 09m wakeups: 3124 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 772 lib: 203
  Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.03
Check your bios, perhaps it has enabled feature which doesn’t overcharge battery against some limit (it’s used to save battery lifespan on some laptops)
Jeez, i hope it’s reading mistake :sweat_smile:
Otherwise it means your battery is almost dead
Looks like bios / battery for that model is not it’s strongest part…
Wow!
Is this a supermegagigapeta… battery?
:astonished:
I doubt that… because you can check my hardware report before 2 days : http://ix.io/3oFl battery stats :slight_smile:
nah, something is wrong I think… check my previous post
Well then maybe your hardware is reporting wrong stats?
yes , but why ? :slight_smile: bad install or ? maybe I can change kernel ?
Easiest way to find out - run it from live USB and see if it’s the same behavior
I tried now with zen kernel :
> battery:
>   ID-1: BAT0 charge: 47.7 Wh (93.0%) condition: 51.3/51.3 Wh (100.0%)
>   volts: 17.5 min: 15.4 model: 333-2B-49-A KC04053XL type: Li-ion
>   serial: <filter> status: Charging
>   Device-1: hid-0018:04F3:23B9.0004-battery model: ELAN2514:00 04F3:23B9
seems good now…weird
Then report this to Kernel maintainers if it’s not known, and use LTS / zen :upside_down_face:
So is the problem solved then?
I found that on my laptop (MSI) the only way to change the battery max charge limit is through the manufacturer provided windows utility. No setting in BIOS (even when I activate the hidden settings). I have to dual boot in Windows, change the setting and then get back to doing my work in Linux, where the changes done in Window to the battery charging behaviour persist.
Yes, it is solved… I tried different kernel and everything is fine now :slight_smile:
