my hdajackretask:
I didn’t change anything as it doesnt look like there is anything to really change. I am not sure why it only shows the Intel Skylake HDMI codec. I am ultra novice with this type of stuff ![]()
In the top box for codec it say’s HDMI. Is there no other?
There is no other, no.
What does advance overide show?
What does this show
pactl info
pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 2971
Tile Size: 65472
User Name: n1nj4
Host Name: gibson
Server Name: PulseAudio (on PipeWire 0.3.49)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.pro-output-8
Default Source: alsa_output.pci-0000_00_1f.3.pro-output-3.monitor
Cookie: 3364:442c
I’m sure it’s not using the right device.
Hmm. Ill have to read some documentation on how to switch devices then. Any inputs on where to search?
What does this show?
lsmod | grep snd
lsmod | grep snd
snd_seq_dummy 16384 0
snd_hrtimer 16384 1
snd_seq 94208 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
snd_hda_codec_hdmi 81920 1
snd_hda_intel 61440 2
snd_intel_dspcfg 32768 1 snd_hda_intel
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
snd_hda_codec 180224 2 snd_hda_codec_hdmi,snd_hda_intel
snd_hda_core 114688 3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_hwdep 16384 1 snd_hda_codec
snd_pcm 159744 5 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 49152 3 snd_seq,snd_hrtimer,snd_pcm
snd 126976 13 snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm
soundcore 16384 1 snd
Is this a recent install or long time running it?
Edit: Have you ever had sof-firmware installed? I’m not sure if this intel chip needs it?
Edit:
pacman -Qi sof-firmware
It is a relatively recent install
Some Intel chips require it and i think it’s part of the packages now anyway. that’s why i asked.
Version : 2.0-1
Description : Sound Open Firmware
Architecture : x86_64
URL : https://www.sofproject.org/
Licenses : custom:BSD custom:ISC
Groups : None
Provides : None
Depends On : None
Optional Deps : None
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 12.81 MiB
Packager : Jan Alexander Steffens (heftig) heftig@archlinux.org
Build Date : Fri 24 Dec 2021 08:06:36 PM CST
Install Date : Fri 11 Mar 2022 08:17:42 PM CST
Install Reason : Explicitly installed
Install Script : No
Validated By : Signature
This may have been something I installed during my quest to fix
I think it’s part of the packages now anyway.
Edit Have you tried any kernel parameters?
You could try this one added to the command line in grub. Use nano and edit the grub command line.
Add this and save the file and then update grub.
snd-intel-dspcfg.dsp_driver=1
Pardon. What file should I update? Surely not /etc/default/grub right?
Yes try adding it to the default grub command line and save the file. Use nano as an editor. Then update grub with
reboot after
If this doesn’t work you can remove it with the reverse process and update grub again with the entry removed.
