Okay, is the problem solved? If so, please mark the post that solved it as the solution. This way, if others have this problem they can find the fix easily.
I’m not sure. I guess it can be considered. I’m letting baloo run its course, eat the resources, and once it’s finished, I will go back and do everything posted here.
Let me know if you think it is and I will mark it closed. Sorry I didn’t know that was supposed to be done.
No worries. I thought you had solved the issue. The first thing I do on a KDE Arch install is uninstall Discover. Then I nuke Baloo from orbit by uninstalling it. I have never had it work properly for me.
Good choice. Search still works just fine. Baloo, Discover, and the degree in pretzel logic that is required to understand the System Settings are my only complaints with Plasma. Luckily, the first 2 can be nuked and the last one is getting better with each release.
I use top. It shows it works even after disable, and suspend. Weird, no?
Blockquote
balooctl status
Baloo File Indexer is running
Indexer state: Indexing file content
Total files indexed: 604,483
Files waiting for content indexing: 101,420
Files failed to index: 0
Current size of index is 6.54 GiB
