I appreciate all the work and effort the devs have put into the EOS Calamari installation and with BTRFS setup. I’m not using any encryption. Just a regular BTRFS default setup and Timeshift for system backup.
I just had a thought that if EOS project halts or discontinues, how can I have have a same bare-bone BTRFS installation?
Is there an installation guide that offers the same BTRFS setup? I’ve looked through many guides but without trying, I wasn’t sure which one I could use.
I am also okay with another Arch distro that offers similar BTRFS setup without much bloat.
Barring unforeseen circumstances, that is unlikely in the near future.
I would recommend:
Arch and their install script
Archfi and their install script.
Garuda has what they call bare bones that is a very minimal basic install. With the caveat they don’t offer support for it as it’s absolutely not intended for anyone even close to a “beginner.”
I believe Arco has something similar where you can do a base minimal install.
I’m 99% sure all of those options (maybe not Arco) are available with btrfs.
Again, is unlikely you will see the current project halt any time soon. Although nothing is impossible.
