Installed this using pacseek and also installed the daemon so that it automatically optimizes CPU usage.
https://github.com/AdnanHodzic/auto-cpufreq
Is there a better way to set this up? How would I set this up gnome?
EDIT: For context, I’ve been trying to set up this machine…
…to run games well and have run into issues where higher end GPU intensive games run the computers heat up WAY too high (87-95c). I’ve been told on the discord for ASUS linux gamers that the linked app would help but after installing it with pacseek and setting up the daemon it seems my heat levels are still out of control when running bigger games.
EDIT 2: I’ve attempted setting the g14 kernel as prescribed via this link to NO avail as far as bringing the temps down. Set up a custom fan curve and everything but it’s still blistering hot.
