After today’s updates gtk-xfce-engine can’t be found in AUR anymore. Do i have to update it manually, or should i just remove it?
I’m still pretty new to arch, so i’d really appreciate the help. Thanks!
https://www.archlinux.org/packages/extra/x86_64/gtk-xfce-engine/
what for you have it installed? as it was in [extra] before… but i would simple remove it…
hello,the package is gtk2, no
I removed that one this morning ‘yay -R gtk-xfce-engine’…along with xf86-video-intel
dunno why I had that intel carp installed as I’ve got a AMD cpu with integrated graphics…
with this new xfce 4.14 can all the ‘old’ gtk2 stuff be removed now?
no
so no it can not be uninstalled or it was not on extra repo ? and it is not only gtk2:
https://github.com/xfce-mirror/gtk-xfce-engine
This package provides the Xfce Gtk+-2.0 and Gtk+-3.0 engines, which allows
for homogeneity in applications for both business and personal desktops.
Minimum required Gtk+-2.0 version is currently Gtk+-2.20.0.
Minimum required Gtk+-3.0 version is currently Gtk+-3.2.0.
Gtk+-3.4.0 is not supported by the default themes.
Package gtk-xfce-engine is deprecated by the Xfce team and no more available from the Arch repos.
So ti should be OK to remove it, I already did that.
Does anyone have any issues after removing it?
I removed it and have no issues!
Neither here !
please uninstall gtk-xfce-engine.
It is not needed anymore:
sudo pacman -R gtk-xfce-engine
