Hi I want to ask everyone where do you report about a audio driver, I use Endeavor OS KDE wayland on a ASUS Zenbook 14 OLED UX3405. Everything works but the audio driver only use 2 of the speakers, I cant remember how many speakers there in this new laptop. But there is only treble and mid range but no bass at all. So the sound is pretty flat and I would like to report this so hopefully there would be a fix for this. In case where can I find the correct driver for this laptop ? is there any fix for this ?
Since you are using KDE, here is one thing you can try. Navigate to:
Apps launcher * Multimedia * Volume Control.
Go to the “configuration” tab and click on the down arrow. This shows a list of recognized drivers.
Choose one of the drivers, “Pro Audio” works best for me.
Go to the “output devices” Tab and if music is playing, the one that is active will have the level meter wiggling back an forth.
Go to the “Playback” tab and set to the appropriate device.
Pudge
Hi I went into sound and from play hifi quality to pro audio, and when I enable pro audio there is no sound at all only in hifi quality, I hope I went to the correct settings ?
