Yes, I agree with all the points. But what I meant is if I add EOS repo and make it identify itself as Endeavour instead of Arch, is it Endeavour after all or I am missing something it does when installed “normally”?
It still says Arch in inxi for example though.
No, you can’t. It omits quite a bit of details, so you are supposed to have a bit of understanding what you are doing…
Did you also pull in and trigger the os-release.hook?
Maybe try it first, then provide advice?
If you have more than one computer, you never have to type the commands manually. You can enable ssh and ssh in. I do this even when installing in a vm because a terminal is generally easier to work in than a tty.
Their contributions are excellent and very well argued
This sums up hours of work, although I must admit that I have never used it → ssh and ssh in
Regarding using a console, it does have more scope than a tty indeed!
