Arc A750 and playing Halo Infinite
See this also:
https://www.reddit.com/r/linux_gaming/comments/16ecj09/halo_infinite_fails_to_start_on_arc_a750/
I think only manually compiling, which i advice against, especially since 6.8 seems to be very problematic so far, because you’ll likely mess something up - it’s best to wait until it will come to Arch, it will be almost the second it’s out of rc.
Where are the steps that I can read about to manual recompile the kernel? At this point I don’t care if it messes up the system as I will just re-install. It is either that or I go back to windows.
isn’t there also an option that I can have multiple kernels on the system and I just choose the one that I would like to use at the startup of the OS?
Whatever… :roll_eyes:
I’ve warned you, don’t say i haven’t.
Knock yourself out reading the f manual :joy:
https://wiki.archlinux.org/title/Kernel/Traditional_compilation
Of course, once you have more than one Kernel installed - you just hold ESC on startup and it will let you choose one to load.
there are also some -git and -rc kernel packages in the AUR, for example
https://aur.archlinux.org/packages/linux-rc
https://aur.archlinux.org/packages/linux-mainline
but that definitely applies:
Although after rc2 most extremely heavy bugs are usually ironed out - but there are always bugs that are only detected later on.
Edit: Before trying those, you should definitely check that:https://wiki.archlinux.org/title/Arch_User_Repository
especially the part about Getting Started
I get errors when trying to make the kernel even when I only added (M) to Intel XE graphics. I guess I wait, I would literally probably have to have someone over my shoulder guiding me through this.
Try AUR packages above, it should probably work.
Well, 6.8-rc2 is working on my system now from the AUR listed, but I don’t think that they put in the Intel XE driver into the modules.
when I run the command lsmod | grep xe, or lsmod | grep intel, nothing stands out as being on the display driver. That and the game still faults at the same place. Guess at this point have to wait until I can actually build the kernel myself, or confirm it was built with this one.
depending on which AUR-helper you used, you can find the kernel’s buildfiles in its folder. For yay it is ~/.cache/yay/ and there a subfolder with the name of the package you built. You can check and edit the config, rename/delete the packages that were already build and build the package again with makepkg - afterwards you can install the relevant packages with sudo pacman -U FILENAME FILENAME-headers
You need to know which configs need to be set for that.
